    [LIP] Sculptris_SimonLeBon
    Scheduled Pinned Locked Moved Organic Modelling
    98 Posts 15 Posters 62.0k Views 15 Watching
      @Michalis
      About the remove inner faces 😉
      Direct link to load the RB file 😉
      • simon le bonS Offline
        simon le bon
        Hi guys,
        Since I still don't have much time for doing the tests initiated by Michalis, here is an interlude.
        I had made about 12/13 years ago a serial of 7 or 8 sculptures after I had found pieces of light stone at the output of an old stones carry. Today I have taken pictures for this thread of three sculptures that are left in my possession.
        this one was made into a small piece of an old wooden handrail. The wood is oak.
        http://i274.photobucket.com/albums/jj245/Spendauballet/Sculptris/thSculpt001.jpg
        http://i274.photobucket.com/albums/jj245/Spendauballet/Sculptris/th_RealScuptSim_017.jpg
        http://i274.photobucket.com/albums/jj245/Spendauballet/Sculptris/th_RealScuptSim_018.jpg
        http://i274.photobucket.com/albums/jj245/Spendauballet/Sculptris/th_RealScuptSim_019.jpg
        already a gargoyle
        http://i274.photobucket.com/albums/jj245/Spendauballet/Sculptris/thSculpt002.jpg
        http://i274.photobucket.com/albums/jj245/Spendauballet/Sculptris/th_RealScuptSim_003.jpg
        http://i274.photobucket.com/albums/jj245/Spendauballet/Sculptris/th_RealScuptSim_001.jpg
        http://i274.photobucket.com/albums/jj245/Spendauballet/Sculptris/th_RealScuptSim_002.jpg
        a cube of life?
        http://i274.photobucket.com/albums/jj245/Spendauballet/Sculptris/thSculpt003.jpg
        http://i274.photobucket.com/albums/jj245/Spendauballet/Sculptris/th_RealScuptSim_004.jpg
        http://i274.photobucket.com/albums/jj245/Spendauballet/Sculptris/th_RealScuptSim_005.jpg
        http://i274.photobucket.com/albums/jj245/Spendauballet/Sculptris/th_RealScuptSim_006.jpg
        http://i274.photobucket.com/albums/jj245/Spendauballet/Sculptris/th_RealScuptSim_007.jpg
        http://i274.photobucket.com/albums/jj245/Spendauballet/Sculptris/th_RealScuptSim_008.jpg
        http://i274.photobucket.com/albums/jj245/Spendauballet/Sculptris/th_RealScuptSim_016.jpg
        [img:k9z33o8y]http://i274.photobucket.com/albums/jj245/Spendauballet/Sculptris/th_RealScuptSim_015.jpg[/img:k9z33o8y] [img:k9z33o8y]http://i274.photobucket.com/albums/jj245/Spendauballet/Sculptris/th_RealScuptSim_014.jpg[/img:k9z33o8y] [img:k9z33o8y]http://i274.photobucket.com/albums/jj245/Spendauballet/Sculptris/th_RealScuptSim_013.jpg[/img:k9z33o8y] [url=http://i274.photobucket.com/albums/jj245/Spendauballet/Sculptris/RealScuptSim_011.jpg:k9z33o8y][img:k9z33o8y]http://i274.photobucket.com/albums/jj245/Spendauballet/Sculptris/th_RealScuptSim_011.jpg[/img:k9z33o8y][/url:k9z33o8y] [url=http://i274.photobucket.com/albums/jj245/Spendauballet/Sculptris/RealScuptSim_009.jpg:k9z33o8y][img:k9z33o8y]http://i274.photobucket.com/albums/jj245/Spendauballet/Sculptris/th_RealScuptSim_009.jpg[/img:k9z33o8y][/url:k9z33o8y]
        Cheers,
        Simon.
        • numbthumbN Offline
          numbthumb
          Huh? 😲
          Sometimes I wonder if all this 3D hassle is worthy of my time or not. I used to soothe myself thinking how 3D printing would spark my "home manufacturing revolution", but now that I have seen this...A real hand-made that still beats the cr@p out of 3D printing as far as I am concerned.
          Makes me want to build scale models again. Plus the glue fumes...
          Congratulations, Simon! 👍
          Comfortably numb...
          • michaliszissiouM Offline
            michaliszissiou
            This is the kind of sculpture I like Simon.
            Nice 3d printing. 😆
            Great work !!!!
              Ethnologic! 😎
                simon le bon
                Hi guys,
                You're nice and kind 👍 😄
                I have made a speed test with import export .obj
                Native "File/Export as Obj" with SU7 pro works fine.
                Tig's OBJexporter and Import OBJ with Materials worked perfectly with Su6 free. (thank you a lot dear TIG)
                http://i274.photobucket.com/albums/jj245/Spendauballet/Sculptris/thbiscotte_import_00.jpg
                remind: from Scuptris included documentation
                Import OBJ - Import an existing OBJ file. Useful if you want multiple objects for sculpting, or somewhat more complex topology than a sphere. Compatibility is limited. Use single closed triangulated mesh(es) without sharp corners, and with less than 24 connections per vertex (no high-resolution spheres, unless they are geospheres)
                In Fact, there is no need to produce a model "without sharp corners" after some tries I had mad a simple "hard square" and this worked.
                http://i274.photobucket.com/albums/jj245/Spendauballet/Sculptris/thbiscotte_import_02.jpg
                No need also to subdivide the model into SU. Sculptris do the job itself easily using "Subdivide All" button
                http://i274.photobucket.com/albums/jj245/Spendauballet/Sculptris/thbiscotte_import_03.jpg
                The various tools expend the subdivision in relation with Detail slider.
                http://i274.photobucket.com/albums/jj245/Spendauballet/Sculptris/thbiscotte_import_04.jpg
                There is also a "Reduce Selected" button in order to export back to SU a reduced mesh which works on the full model,
                (4 or 5 iterations:)
                http://i274.photobucket.com/albums/jj245/Spendauballet/Sculptris/thbiscotte_import_05.jpg
                http://i274.photobucket.com/albums/jj245/Spendauballet/Sculptris/thbiscotte_import_06.jpg
                And more handy, I have used "Reduce Brush" button to reduce by zones.
                http://i274.photobucket.com/albums/jj245/Spendauballet/Sculptris/reducebrush.jpg
                http://i274.photobucket.com/albums/jj245/Spendauballet/Sculptris/thbiscotte_import_07.jpg
                http://i274.photobucket.com/albums/jj245/Spendauballet/Sculptris/thbiscotte_import_08.jpg
                At the end, "cherry on the cake" I have used Chris Fullmer's Extrapolate Colors to make a harlequin render.
                http://i274.photobucket.com/albums/jj245/Spendauballet/Sculptris/thbiscotte_import_09.jpg
                http://i274.photobucket.com/albums/jj245/Spendauballet/Sculptris/thbiscotte_import_10.jpg
                http://i274.photobucket.com/albums/jj245/Spendauballet/Sculptris/thbiscotte_import_11.jpg
                Cheers,
                Simon.
                  You have also Random Painter by Chris Fullmer! 😉
                  Else it's a very cool workflow for make "subdivision and Smooth" with SU6! (or up) 😎
                  @ Simon :Je te "pique" le tut, le traduis et te donne l'adresse où je le mets dès qu'il est fait 👍
                  Ok traduction faite 😎
                  Je vais évidemment la mettre aussi sur la "French Section" à SketchEducation 😉
                  • shuraS Offline
                    shura
                    Nice harlequin technique, can also do a good job in case you want to do one of Gaudi's rooftop sculptures...
                      The cool thing of this, is that you can use use the "pressure" inside Sculptis 😉
                        numbthumb
                        Thanks for keeping us informed, Simon. 👍
                        Very interesting workaround for organic modeling.
                        Comfortably numb...
                          simon le bon
                          ☀ Hi!
                          If I have verified the import/export abilities between SU and Sculptris,
                          And also have verified that tools of Sculptris worked on Su "waterproof" models,
                          the "traduction" of Pilou point out better than I had done the rich combination SketchUP/Sculptris to make subdivisions job.!!
                          We know how Su and the better quadcore are easily put on their knees by subdivision operations.. Sculptris make the job: "fingers in the nose" so 😉 !!
                          See you soon,
                          Simon.
                          • jason_marantoJ Offline
                            jason_maranto
                            Very interesting work -- I have used Z-brush and I have contemplated 3-D Coat but Sculptris seems to be a viable alternative.
                            The harlequin technique was very appealing as well...
                            Best,
                            Jason.
                              simon le bon
                              an exercise to make ears
                              Yes I know you know this girl too 😆
                              http://i274.photobucket.com/albums/jj245/Spendauballet/Sculptris/th2011-02-04_160550.jpg
                              http://i274.photobucket.com/albums/jj245/Spendauballet/Sculptris/th2011-02-04_160658.jpg
                              http://i274.photobucket.com/albums/jj245/Spendauballet/Sculptris/th2011-02-04_160807.jpg
                              http://i274.photobucket.com/albums/jj245/Spendauballet/Sculptris/th2011-02-04_161211.jpg
                              http://i274.photobucket.com/albums/jj245/Spendauballet/Sculptris/th2011-02-04_161519.jpg
                              http://i274.photobucket.com/albums/jj245/Spendauballet/Sculptris/th2011-02-04_161644.jpg
                              😎 simon
                                Beautiful ears! 👍
                                  numbthumb
                                  With such auditory input, she´s gonna go bananas. 😄
                                  Your imagination has no limits, Simon. 👍
                                  Comfortably numb...
                                    rattusNOR
                                    cool! a dedicated forum for organic modelling!
                                    simon, thank you for posting the sculptris/sketchup combo,
                                    i can only get it to work with rounded-corners, i can import a square with
                                    sharp corners too, but when subdivide or just touch it with a brush it "explode"
                                    and can not keep it's shape like you did here:
                                    just wondered if you had encounter this problem too before you got it right,
                                    it may be graphic-card issue.. my sculptris crash a lot.
                                    anyway, keep up the good work 👍
                                      simon le bon
                                      Hi Rattus,
                                      I'm pursuing my tests. As I had named the title, it is for me a "learn In Progress" and I'm happy if we are several to search. 👍
                                      First, concerning your problem.
                                      The point is that Sculptris only accept meshes= triangulated model.
                                      You had certainly used the 3D Obj exporting ability of SketchUp "Pro". Doing this, the model is not exported with faces as meshes = they are not triangulated.
                                      Using TIG OBJexporter,
                                      All Exported Faces are Triangulated,
                                      so that Sculptris accept.
                                      The other solutions for this:
                                      is to use SU pro obj exporter after have triangulated the model with (once again 😆 👍 ) TIG triangulateFaces(take care to follow the link at the end of the first post which lead to the latest version included in page two)
                                      http://i274.photobucket.com/albums/jj245/Spendauballet/Sculptris/2011-02-07_145604.jpg
                                      http://i274.photobucket.com/albums/jj245/Spendauballet/Sculptris/th2011-02-07_140408.jpg
                                      http://i274.photobucket.com/albums/jj245/Spendauballet/Sculptris/th2011-02-07_140947.jpg
                                      TIG OBJexporter
                                      http://i274.photobucket.com/albums/jj245/Spendauballet/Sculptris/2011-02-07_151031.jpg
                                      http://i274.photobucket.com/albums/jj245/Spendauballet/Sculptris/th2011-02-07_151235.jpg
                                      The point where my enthusiasm is very lowered is the difficulty (crash,crash,crash) to re-import the sculpture into Su.
                                      In a bit complex model, despite all my efforts to diminish the number of triangulation Su is unable to accept the import. (If you can wait, I'm looking for a solution.)
                                      http://i274.photobucket.com/albums/jj245/Spendauballet/Sculptris/2011-02-07_195339.jpg
                                      http://i274.photobucket.com/albums/jj245/Spendauballet/Sculptris/th2011-02-07_135045.jpg
                                      http://i274.photobucket.com/albums/jj245/Spendauballet/Sculptris/th2011-02-07_135357.jpg
                                      http://i274.photobucket.com/albums/jj245/Spendauballet/Sculptris/th2011-02-07_135945.jpg
                                      The avowed purpose is to bridge Sculptris to SketchUp to achieve all these architecture details sculptures for which SU is so low gifted.
                                      Well Subdivide&Smooth V2 is not very far to be out and I think it will be very efficient in that purpose...
                                      simon
                                        no possibility to go to Meshlab, before go to Su? 😉
                                          simon le bon
                                          Hi Pilou
                                          Meshlab is now installed 😉
                                          Whao! very powerful = relatively simple but complex by the quantity of possible actions..
                                          (haven't found undo command 😞 )
                                          I've made a quick test on my initial model (not very perfect: holes (ripped), hidden vertices etc..)
                                          305.310 faces:
                                          http://i274.photobucket.com/albums/jj245/Spendauballet/Sculptris/th2011-02-07_230327.jpg
                                          after cleaning and repairing : -merge close vertices ; -remove duplicate faces
                                          I have remeshed : clustered decimation (50%)
                                          40.854 faces:!: ❗
                                          But we can notice an evident lower quality of the details
                                          http://i274.photobucket.com/albums/jj245/Spendauballet/Sculptris/th2011-02-07_235341.jpg
                                          (saved as .OBJ)
                                          Then,
                                          in SU6 free with TIG Import OBJ with Materials
                                          (plugins menu- options: import in meters, import mesh only, flip yes)
                                          The object loads 😍
                                          Re:about 50000 faces, Su is coming slow and we are probably not very far from the limit...
                                          http://i274.photobucket.com/albums/jj245/Spendauballet/Sculptris/th2011-02-07_234715.jpg
                                          http://i274.photobucket.com/albums/jj245/Spendauballet/Sculptris/th2011-02-07_234832.jpg
                                          Yehh! not too bad 😄
                                          Thank you Pilou.
                                          ++simon
                                          Re: May be it is a good occasion for me to try ThomThom Cleanup 😉
                                            simon le bon
                                            After a night, some reflection and a discuss with SCF guys,
                                            Regis wrote in the french Section:
                                            I have no pre-conceived upon the technique used by Sculptris but I think it's super polygons gluttonous. Increasing the resolution for more details, polygons count skyrockets.
                                            I prefer the standard polygonal technical modeling with faces subdivision, I find that this gives more control over the topology of the mesh and give a better control on the number of polygons.
                                            This inspire a conclusion:
                                            Régis is probably right on the polygonal modeling technique.
                                            Sculptris is really nice but can't be the perfect companion to SketchUp which is so weak to manage a high rate of polygons..
                                            😞 simon
                                            • 5 / 5
