    [LIP] Sculptris_SimonLeBon
    Scheduled Pinned Locked Moved Organic Modelling
    98 Posts 15 Posters 62.3k Views 15 Watching
    • michaliszissiouM Offline
      michaliszissiou
      As I can understand; this is the big news, YOU ARE STARTING A CLASSROOM!!
      How could I start a classroom? Where? Any ideas? Always my pleasure to help each other. Just dont ask me how to sculpt a nose - my weak point always. 😆 On ears, my speciality. On abstract structure, my favorite part. On anatomy, I hate it, probably the greatest lie in history of art.
      @pilou
      There is a useful plug for that (non manifolds remover), help please, I need this.
      Please post this link to 3dc forum as well, some SU users there may need it.
      And my post here, a statue of venus I already posted as a podium test render, here the 'original' zbrush render (BPR) at 3M poly this time (5 sec render time) .
        michaliszissiou
        Is Topology the modern armature of digital sculpting?
        How old is this drawing? Albrecht Dürer (1471-1528)
        http://forums.sketchucation.com/download/file.php?id=62568
          @Michalis
          About the remove inner faces 😉
          Direct link to load the RB file 😉
          • simon le bonS Offline
            simon le bon
            Hi guys,
            Since I still don't have much time for doing the tests initiated by Michalis, here is an interlude.
            I had made about 12/13 years ago a serial of 7 or 8 sculptures after I had found pieces of light stone at the output of an old stones carry. Today I have taken pictures for this thread of three sculptures that are left in my possession.
            this one was made into a small piece of an old wooden handrail. The wood is oak.
            http://i274.photobucket.com/albums/jj245/Spendauballet/Sculptris/thSculpt001.jpg
            http://i274.photobucket.com/albums/jj245/Spendauballet/Sculptris/th_RealScuptSim_017.jpg
            http://i274.photobucket.com/albums/jj245/Spendauballet/Sculptris/th_RealScuptSim_018.jpg
            http://i274.photobucket.com/albums/jj245/Spendauballet/Sculptris/th_RealScuptSim_019.jpg
            already a gargoyle
            http://i274.photobucket.com/albums/jj245/Spendauballet/Sculptris/thSculpt002.jpg
            http://i274.photobucket.com/albums/jj245/Spendauballet/Sculptris/th_RealScuptSim_003.jpg
            http://i274.photobucket.com/albums/jj245/Spendauballet/Sculptris/th_RealScuptSim_001.jpg
            http://i274.photobucket.com/albums/jj245/Spendauballet/Sculptris/th_RealScuptSim_002.jpg
            a cube of life?
            http://i274.photobucket.com/albums/jj245/Spendauballet/Sculptris/thSculpt003.jpg
            http://i274.photobucket.com/albums/jj245/Spendauballet/Sculptris/th_RealScuptSim_004.jpg
            http://i274.photobucket.com/albums/jj245/Spendauballet/Sculptris/th_RealScuptSim_005.jpg
            http://i274.photobucket.com/albums/jj245/Spendauballet/Sculptris/th_RealScuptSim_006.jpg
            http://i274.photobucket.com/albums/jj245/Spendauballet/Sculptris/th_RealScuptSim_007.jpg
            http://i274.photobucket.com/albums/jj245/Spendauballet/Sculptris/th_RealScuptSim_008.jpg
            http://i274.photobucket.com/albums/jj245/Spendauballet/Sculptris/th_RealScuptSim_016.jpg
            [img:k9z33o8y]http://i274.photobucket.com/albums/jj245/Spendauballet/Sculptris/th_RealScuptSim_015.jpg[/img:k9z33o8y] [img:k9z33o8y]http://i274.photobucket.com/albums/jj245/Spendauballet/Sculptris/th_RealScuptSim_014.jpg[/img:k9z33o8y] [img:k9z33o8y]http://i274.photobucket.com/albums/jj245/Spendauballet/Sculptris/th_RealScuptSim_013.jpg[/img:k9z33o8y] [url=http://i274.photobucket.com/albums/jj245/Spendauballet/Sculptris/RealScuptSim_011.jpg:k9z33o8y][img:k9z33o8y]http://i274.photobucket.com/albums/jj245/Spendauballet/Sculptris/th_RealScuptSim_011.jpg[/img:k9z33o8y][/url:k9z33o8y] [url=http://i274.photobucket.com/albums/jj245/Spendauballet/Sculptris/RealScuptSim_009.jpg:k9z33o8y][img:k9z33o8y]http://i274.photobucket.com/albums/jj245/Spendauballet/Sculptris/th_RealScuptSim_009.jpg[/img:k9z33o8y][/url:k9z33o8y]
            Cheers,
            Simon.
            • numbthumbN Offline
              numbthumb
              Huh? 😲
              Sometimes I wonder if all this 3D hassle is worthy of my time or not. I used to soothe myself thinking how 3D printing would spark my "home manufacturing revolution", but now that I have seen this...A real hand-made that still beats the cr@p out of 3D printing as far as I am concerned.
              Makes me want to build scale models again. Plus the glue fumes...
              Congratulations, Simon! 👍
              Comfortably numb...
                michaliszissiou
                This is the kind of sculpture I like Simon.
                Nice 3d printing. 😆
                Great work !!!!
                  Ethnologic! 😎
                    simon le bon
                    Hi guys,
                    You're nice and kind 👍 😄
                    I have made a speed test with import export .obj
                    Native "File/Export as Obj" with SU7 pro works fine.
                    Tig's OBJexporter and Import OBJ with Materials worked perfectly with Su6 free. (thank you a lot dear TIG)
                    http://i274.photobucket.com/albums/jj245/Spendauballet/Sculptris/thbiscotte_import_00.jpg
                    remind: from Scuptris included documentation
                    Import OBJ - Import an existing OBJ file. Useful if you want multiple objects for sculpting, or somewhat more complex topology than a sphere. Compatibility is limited. Use single closed triangulated mesh(es) without sharp corners, and with less than 24 connections per vertex (no high-resolution spheres, unless they are geospheres)
                    In Fact, there is no need to produce a model "without sharp corners" after some tries I had mad a simple "hard square" and this worked.
                    http://i274.photobucket.com/albums/jj245/Spendauballet/Sculptris/thbiscotte_import_02.jpg
                    No need also to subdivide the model into SU. Sculptris do the job itself easily using "Subdivide All" button
                    http://i274.photobucket.com/albums/jj245/Spendauballet/Sculptris/thbiscotte_import_03.jpg
                    The various tools expend the subdivision in relation with Detail slider.
                    http://i274.photobucket.com/albums/jj245/Spendauballet/Sculptris/thbiscotte_import_04.jpg
                    There is also a "Reduce Selected" button in order to export back to SU a reduced mesh which works on the full model,
                    (4 or 5 iterations:)
                    http://i274.photobucket.com/albums/jj245/Spendauballet/Sculptris/thbiscotte_import_05.jpg
                    http://i274.photobucket.com/albums/jj245/Spendauballet/Sculptris/thbiscotte_import_06.jpg
                    And more handy, I have used "Reduce Brush" button to reduce by zones.
                    http://i274.photobucket.com/albums/jj245/Spendauballet/Sculptris/reducebrush.jpg
                    http://i274.photobucket.com/albums/jj245/Spendauballet/Sculptris/thbiscotte_import_07.jpg
                    http://i274.photobucket.com/albums/jj245/Spendauballet/Sculptris/thbiscotte_import_08.jpg
                    At the end, "cherry on the cake" I have used Chris Fullmer's Extrapolate Colors to make a harlequin render.
                    http://i274.photobucket.com/albums/jj245/Spendauballet/Sculptris/thbiscotte_import_09.jpg
                    http://i274.photobucket.com/albums/jj245/Spendauballet/Sculptris/thbiscotte_import_10.jpg
                    http://i274.photobucket.com/albums/jj245/Spendauballet/Sculptris/thbiscotte_import_11.jpg
                    Cheers,
                    Simon.
                      You have also Random Painter by Chris Fullmer! 😉
                      Else it's a very cool workflow for make "subdivision and Smooth" with SU6! (or up) 😎
                      @ Simon :Je te "pique" le tut, le traduis et te donne l'adresse où je le mets dès qu'il est fait 👍
                      Ok traduction faite 😎
                      Je vais évidemment la mettre aussi sur la "French Section" à SketchEducation 😉
                      • shuraS Offline
                        shura
                        Nice harlequin technique, can also do a good job in case you want to do one of Gaudi's rooftop sculptures...
                          The cool thing of this, is that you can use use the "pressure" inside Sculptis 😉
                            numbthumb
                            Thanks for keeping us informed, Simon. 👍
                            Very interesting workaround for organic modeling.
                            Comfortably numb...
                              simon le bon
                              ☀ Hi!
                              If I have verified the import/export abilities between SU and Sculptris,
                              And also have verified that tools of Sculptris worked on Su "waterproof" models,
                              the "traduction" of Pilou point out better than I had done the rich combination SketchUP/Sculptris to make subdivisions job.!!
                              We know how Su and the better quadcore are easily put on their knees by subdivision operations.. Sculptris make the job: "fingers in the nose" so 😉 !!
                              See you soon,
                              Simon.
                              • jason_marantoJ Offline
                                jason_maranto
                                Very interesting work -- I have used Z-brush and I have contemplated 3-D Coat but Sculptris seems to be a viable alternative.
                                The harlequin technique was very appealing as well...
                                Best,
                                Jason.
                                  simon le bon
                                  an exercise to make ears
                                  Yes I know you know this girl too 😆
                                  http://i274.photobucket.com/albums/jj245/Spendauballet/Sculptris/th2011-02-04_160550.jpg
                                  http://i274.photobucket.com/albums/jj245/Spendauballet/Sculptris/th2011-02-04_160658.jpg
                                  http://i274.photobucket.com/albums/jj245/Spendauballet/Sculptris/th2011-02-04_160807.jpg
                                  http://i274.photobucket.com/albums/jj245/Spendauballet/Sculptris/th2011-02-04_161211.jpg
                                  http://i274.photobucket.com/albums/jj245/Spendauballet/Sculptris/th2011-02-04_161519.jpg
                                  http://i274.photobucket.com/albums/jj245/Spendauballet/Sculptris/th2011-02-04_161644.jpg
                                  😎 simon
                                    Beautiful ears! 👍
                                      numbthumb
                                      With such auditory input, she´s gonna go bananas. 😄
                                      Your imagination has no limits, Simon. 👍
                                      Comfortably numb...
                                        rattusNOR
                                        cool! a dedicated forum for organic modelling!
                                        simon, thank you for posting the sculptris/sketchup combo,
                                        i can only get it to work with rounded-corners, i can import a square with
                                        sharp corners too, but when subdivide or just touch it with a brush it "explode"
                                        and can not keep it's shape like you did here:
                                        just wondered if you had encounter this problem too before you got it right,
                                        it may be graphic-card issue.. my sculptris crash a lot.
                                        anyway, keep up the good work 👍
                                          simon le bon
                                          Hi Rattus,
                                          I'm pursuing my tests. As I had named the title, it is for me a "learn In Progress" and I'm happy if we are several to search. 👍
                                          First, concerning your problem.
                                          The point is that Sculptris only accept meshes= triangulated model.
                                          You had certainly used the 3D Obj exporting ability of SketchUp "Pro". Doing this, the model is not exported with faces as meshes = they are not triangulated.
                                          Using TIG OBJexporter,
                                          All Exported Faces are Triangulated,
                                          so that Sculptris accept.
                                          The other solutions for this:
                                          is to use SU pro obj exporter after have triangulated the model with (once again 😆 👍 ) TIG triangulateFaces(take care to follow the link at the end of the first post which lead to the latest version included in page two)
                                          http://i274.photobucket.com/albums/jj245/Spendauballet/Sculptris/2011-02-07_145604.jpg
                                          http://i274.photobucket.com/albums/jj245/Spendauballet/Sculptris/th2011-02-07_140408.jpg
                                          http://i274.photobucket.com/albums/jj245/Spendauballet/Sculptris/th2011-02-07_140947.jpg
                                          TIG OBJexporter
                                          http://i274.photobucket.com/albums/jj245/Spendauballet/Sculptris/2011-02-07_151031.jpg
                                          http://i274.photobucket.com/albums/jj245/Spendauballet/Sculptris/th2011-02-07_151235.jpg
                                          The point where my enthusiasm is very lowered is the difficulty (crash,crash,crash) to re-import the sculpture into Su.
                                          In a bit complex model, despite all my efforts to diminish the number of triangulation Su is unable to accept the import. (If you can wait, I'm looking for a solution.)
                                          http://i274.photobucket.com/albums/jj245/Spendauballet/Sculptris/2011-02-07_195339.jpg
                                          http://i274.photobucket.com/albums/jj245/Spendauballet/Sculptris/th2011-02-07_135045.jpg
                                          http://i274.photobucket.com/albums/jj245/Spendauballet/Sculptris/th2011-02-07_135357.jpg
                                          http://i274.photobucket.com/albums/jj245/Spendauballet/Sculptris/th2011-02-07_135945.jpg
                                          The avowed purpose is to bridge Sculptris to SketchUp to achieve all these architecture details sculptures for which SU is so low gifted.
                                          Well Subdivide&Smooth V2 is not very far to be out and I think it will be very efficient in that purpose...
                                          simon
                                            no possibility to go to Meshlab, before go to Su? 😉
                                            • 5 / 5
