    [LIP] Sculptris_SimonLeBon
    Scheduled Pinned Locked Moved Organic Modelling
    98 Posts 15 Posters 59.6k Views 15 Watching
    • numbthumbN Offline
      numbthumb
      Thanks for keeping us informed, Simon. 👍
      Very interesting workaround for organic modeling.
      Comfortably numb...
      • simon le bonS Offline
        simon le bon
        ☀ Hi!
        If I have verified the import/export abilities between SU and Sculptris,
        And also have verified that tools of Sculptris worked on Su "waterproof" models,
        the "traduction" of Pilou point out better than I had done the rich combination SketchUP/Sculptris to make subdivisions job.!!
        We know how Su and the better quadcore are easily put on their knees by subdivision operations.. Sculptris make the job: "fingers in the nose" so 😉 !!
        See you soon,
        Simon.
        • jason_marantoJ Offline
          jason_maranto
          Very interesting work -- I have used Z-brush and I have contemplated 3-D Coat but Sculptris seems to be a viable alternative.
          The harlequin technique was very appealing as well...
          Best,
          Jason.
            simon le bon
            an exercise to make ears
            Yes I know you know this girl too 😆
            http://i274.photobucket.com/albums/jj245/Spendauballet/Sculptris/th2011-02-04_160550.jpg
            http://i274.photobucket.com/albums/jj245/Spendauballet/Sculptris/th2011-02-04_160658.jpg
            http://i274.photobucket.com/albums/jj245/Spendauballet/Sculptris/th2011-02-04_160807.jpg
            http://i274.photobucket.com/albums/jj245/Spendauballet/Sculptris/th2011-02-04_161211.jpg
            http://i274.photobucket.com/albums/jj245/Spendauballet/Sculptris/th2011-02-04_161519.jpg
            http://i274.photobucket.com/albums/jj245/Spendauballet/Sculptris/th2011-02-04_161644.jpg
            😎 simon
              Beautiful ears! 👍
                numbthumb
                With such auditory input, she´s gonna go bananas. 😄
                Your imagination has no limits, Simon. 👍
                Comfortably numb...
                  rattusNOR
                  cool! a dedicated forum for organic modelling!
                  simon, thank you for posting the sculptris/sketchup combo,
                  i can only get it to work with rounded-corners, i can import a square with
                  sharp corners too, but when subdivide or just touch it with a brush it "explode"
                  and can not keep it's shape like you did here:
                  http://i274.photobucket.com/albums/jj245/Spendauballet/Sculptris/thbiscotte_import_03.jpg
                  just wondered if you had encounter this problem too before you got it right,
                  it may be graphic-card issue.. my sculptris crash a lot.
                  anyway, keep up the good work 👍
                    simon le bon
                    Hi Rattus,
                    I'm pursuing my tests. As I had named the title, it is for me a "learn In Progress" and I'm happy if we are several to search. 👍
                    First, concerning your problem.
                    The point is that Sculptris only accept meshes= triangulated model.
                    You had certainly used the 3D Obj exporting ability of SketchUp "Pro". Doing this, the model is not exported with faces as meshes = they are not triangulated.
                    Using TIG OBJexporter,
                    All Exported Faces are Triangulated,
                    so that Sculptris accept.
                    The other solutions for this:
                    is to use SU pro obj exporter after have triangulated the model with (once again 😆 👍 ) TIG triangulateFaces(take care to follow the link at the end of the first post which lead to the latest version included in page two)
                    http://i274.photobucket.com/albums/jj245/Spendauballet/Sculptris/2011-02-07_145604.jpg
                    http://i274.photobucket.com/albums/jj245/Spendauballet/Sculptris/th2011-02-07_140408.jpg
                    http://i274.photobucket.com/albums/jj245/Spendauballet/Sculptris/th2011-02-07_140947.jpg
                    TIG OBJexporter
                    http://i274.photobucket.com/albums/jj245/Spendauballet/Sculptris/2011-02-07_151031.jpg
                    http://i274.photobucket.com/albums/jj245/Spendauballet/Sculptris/th2011-02-07_151235.jpg
                    The point where my enthusiasm is very lowered is the difficulty (crash,crash,crash) to re-import the sculpture into Su.
                    In a bit complex model, despite all my efforts to diminish the number of triangulation Su is unable to accept the import. (If you can wait, I'm looking for a solution.)
                    http://i274.photobucket.com/albums/jj245/Spendauballet/Sculptris/2011-02-07_195339.jpg
                    http://i274.photobucket.com/albums/jj245/Spendauballet/Sculptris/th2011-02-07_135045.jpg
                    http://i274.photobucket.com/albums/jj245/Spendauballet/Sculptris/th2011-02-07_135357.jpg
                    http://i274.photobucket.com/albums/jj245/Spendauballet/Sculptris/th2011-02-07_135945.jpg
                    The avowed purpose is to bridge Sculptris to SketchUp to achieve all these architecture details sculptures for which SU is so low gifted.
                    Well Subdivide&Smooth V2 is not very far to be out and I think it will be very efficient in that purpose...
                    simon
                      no possibility to go to Meshlab, before go to Su? 😉
                        simon le bon
                        Hi Pilou
                        Meshlab is now installed 😉
                        Whao! very powerful = relatively simple but complex by the quantity of possible actions..
                        (haven't found undo command 😞 )
                        I've made a quick test on my initial model (not very perfect: holes (ripped), hidden vertices etc..)
                        305.310 faces:
                        http://i274.photobucket.com/albums/jj245/Spendauballet/Sculptris/th2011-02-07_230327.jpg
                        after cleaning and repairing : -merge close vertices ; -remove duplicate faces
                        I have remeshed : clustered decimation (50%)
                        40.854 faces:!: ❗
                        But we can notice an evident lower quality of the details
                        http://i274.photobucket.com/albums/jj245/Spendauballet/Sculptris/th2011-02-07_235341.jpg
                        (saved as .OBJ)
                        Then,
                        in SU6 free with TIG Import OBJ with Materials
                        (plugins menu- options: import in meters, import mesh only, flip yes)
                        The object loads 😍
                        Re:about 50000 faces, Su is coming slow and we are probably not very far from the limit...
                        http://i274.photobucket.com/albums/jj245/Spendauballet/Sculptris/th2011-02-07_234715.jpg
                        http://i274.photobucket.com/albums/jj245/Spendauballet/Sculptris/th2011-02-07_234832.jpg
                        Yehh! not too bad 😄
                        Thank you Pilou.
                        ++simon
                        Re: May be it is a good occasion for me to try ThomThom Cleanup 😉
                          simon le bon
                          After a night, some reflection and a discuss with SCF guys,
                          Regis wrote in the french Section:
                          I have no pre-conceived upon the technique used by Sculptris but I think it's super polygons gluttonous. Increasing the resolution for more details, polygons count skyrockets.
                          I prefer the standard polygonal technical modeling with faces subdivision, I find that this gives more control over the topology of the mesh and give a better control on the number of polygons.
                          This inspire a conclusion:
                          Régis is probably right on the polygonal modeling technique.
                          Sculptris is really nice but can't be the perfect companion to SketchUp which is so weak to manage a high rate of polygons..
                          😞 simon
                            And the Thomthom clean up don't make some polygones reductions?
                            • mitcorbM Offline
                              mitcorb
                              For my elderly machine, Sculptris is torture. Yes, you can run it, but it just bogs down the CPU with only 1.6GHz. Also, my video card renders the model oddly.
                                jason_maranto
                                It may be 3DCoat it the answer you seek -- you can sculpt freely (voxels) and retopologize easily so the the sculpted form will need the minimum amount of poly's to retain the desired form, which will help in getting it back into a Sketchup file at a reasonable size.
                                I've used ZBrush in the past to do this but topology can be a more painful issue in ZBrush.
                                Best,
                                Jason.
                                • 5 / 5
