    Hardware recommendations
    409 Posts 97 Posters 92.7k Views 97 Watching
      By pixels. Like extremely large texture files (thousands of pixels) can drive SU crazy when there are a lot of them and max texture size is checked.
      The poly count does no seem to be large IF you also checked "show nested components" on the top of the statistics window.
      • F Offline
        FIRFIRIKIS
        ฮŸฮŸฮŸPS!!!
        i ve just clicked on the nested components...
        edges : 1.683.524
        faces : 633.283
        do i have to worry????!!!!
        the texture size is the standard su texture size (su stone, su bricks, etc etc...)
          @firfirikis said:
          ฮŸฮŸฮŸPS!!!
          edges : 1.683.524
          faces : 633.283
          With that kind of size you have to expect Shadows, Edge Styles, Textures and Geometry to degrade while orbiting. Save your money. Optimize your model. (Purge, erase unnecessary geometry, reduce detail you don't see.)
          • F Offline
            FIRFIRIKIS
            did i reach the limits of su?
            you think that there is no GPU wich can handle my job?
            what can i do then for my presentation ???!!!
              You're pushing it, yes. 500K faces+ is very heavy. I have had some models like that, up to a million or two faces, but it's been either crazy experiments or interior models with lots of high poly furniture.
              Remove all you don't see in the model. Reduce detail unless you see it up close.
              If you need real time performance you must think like game modellers do.
              • F Offline
                FIRFIRIKIS
                maybe i should try another gpu (if some friend can give me a quadro) to see what happens...
                thank u so much for your comments!
                  I have Quadro FX 3800 (I've had 3500, 3700) and I still see degrading with such models.
                  • brodieB Offline
                    brodie
                    I'd agree with thomthom. GPU helps some, but with sketchup it won't help much.
                    -Brodie
                    • F Offline
                      FIRFIRIKIS
                      ok!!! but if a SU-user (like me) wants to upgrade his gpu what's your advice???
                      someone talked about the fx1800 and the fx3800.
                      i cannot understand the diffs of opengl support and opengl hardware... is that true that the opengl hardware of the quadros makes the difference in SU?
                      • brodieB Offline
                        brodie
                        You can take a look at this website. It was a test done awhile back (within the past year or so) testing various graphics cards and how they respond within viewports. Be sure and read his conclusions at the bottom.
                        http://www.cgarchitect.com/news/Reviews/Review076_1.asp
                        The long and short of it is that although you can pretty well chart on a linear graph how well a graphics card is going to do in a traditional gpu test like cinebench based on it's price and how new the card is, that gets thrown out the window when it comes to viewports. With the SU viewport in particular, what difference there is between cards is very small. My conclusion is that if you use your computer for anything besides SU, you're probably best off basing your card choice on that other function. As long as you get a card that doesn't cause bugs (like ATI cards used to), then you'll be fine.
                        As for opengl, I think the current version that most cards are supporting is like 4.x or something whereas SU only uses 1.5, as I recall. Point being, if you find a card made within the past 5 years or so, you'll be fine.
                        -Brodie
                        • takesh hT Offline
                          takesh h
                          I often build SU models like 50-60MB. My PC, although it is 64bit, doesn't even have separate graphic card. It's "on chip".
                          When I navigate within models like it, I always turn off shadows and sometimes even turn off "use sun for shading" option.
                          This trick helps me a lot most of the time, however when that is not enough, I turn off textures in "Face Style" (i.e., checking "shaded" or "hidden lines"). BTW I'm totally content with my PC. ๐Ÿ˜‰
                            When modelling (and navigating), do not use shadows at all. They are "enough" when you want to make your final presentation (whatever output)..
                            Use layers to hide parts of the model you are not working on. (Remember; only put grouped geometry/components on layers other than Layer 0).
                            Finally, there are a couple of plugins that can use sort of "proxy" components (degraded versions of your components). There is TIG's Matrix Proximity plugin that (once set up) will swap three versions of your components depending on scenes or Fredo's Ghost Component plugin for instance.
                            In this model of mine I also had some 1.2-1.3 million edges and over 300,000 faces but I made it on a single core (2.7 GHz) machine with a video card (Ati X550 or what, I think) that had such a poor support that in the OpenGL settings I did not even have antialiasing options (but at least did not give errors). The whole file is smaller than 7 Mb however (extensive use of components of course).
                            • sketch3d.deS Offline
                              sketch3d.de
                              ...is that true that the opengl hardware of the quadros makes the difference in SU?
                              no, SU doesn't take advantage of a Quadro FX, go for a fast GeFroce as e.g. GTX 560Ti/570 or maybe 580 if affordable which is much faster than a Quadro FX for the same price.
                              The highest clocked Core i7-2600 CPU combined with a GeForce GTX580 is currently the fastest system on the market, neither a Xeon CPU nor a (paybale) Quadro FX will show any significant improvement for SU.
                              If speed with high poly count models is still an issue for you, you might want evaluate over-clocking the CPU if feasible, fo doing this improving the cooling system (better/bigger fan, water cooling) is often helpful.
                              hth,
                              Norbert
                              • soloS Offline
                                Besides bad modeling (a noobie thing we all guilty of) most folk even experianced modelers do not know when to stop modeling. When is it finished?
                                  And scale - all to easy to get caught up in details when you pan,orbit and zoom around the model. Working out roughly what your camera positions will be is essential in order to know how much one needs to model.
                                    rock1
                                    What is the website where I can view this survey's results? ๐ŸŽ‰
                                    Signature removed by SCF Admin
                                      seanheadrick
                                      i just got the Asus with the i7 processor, 2g nvidia graphics card and oodles of memory. Seems lighting fast to me
                                      DO OR DO NOT, THERE IS NO TRY.
                                        jdadesignstudio
                                        Im running an Xi laptop (not sure if anyone has heard of them) and have been very happy with it. Although calling it a laptop is a bit of a quirk as its a big 17" and weighs a ton. It has a 2.83ghz quad core, 8gb ram, and an nvidia geforce 9800m gtx 1gb. It handles all of my models quite well and I have some that are multi-million face models. That being said, I do still use layers to isolate areas that I am currently working on to help performance. Also, if shadows are turned on it slows down considerably.
                                        Thanks for the survey-hope it helps!
                                          Scooter-C
                                          @kevsterman said:
                                          I've been looking at the pcspecialist website and I've come up with the following spec for ยฃ1300. Is this good value for money? Will it give me a really fast computer capable of dealing with several intense programmes and the internet all running at the same time without any noticeable slowdown? โ“
                                          <SNIP>
                                          [Your Spec list]
                                          <SNIP>
                                          I'm just so clueless about all this stuff. ๐Ÿ˜ฒ
                                          I'm not clueless, but no expert. May I suggest going to TigerDirect.com or get their phone number.
                                          They can put together a base system (or whole System) you can add to. ๐Ÿ‘
                                          I've worked with them for 15+ years in building my own machines. I have not had any major problems in delivery or customer service. If any component doesn't work it is replaced. Even in these hard economical times I rely on their advice. I am totally new to SketchUp. I just started in the 3D world, but have been a Misc. Metals Detailer (Draftsman) for 29 years. My machines MUST work, period and significant downtime is not an option. I am on my 3rd Home Built machine (from Tiger) and each one has been an upgrade from the last, because of the component improvements.
                                          I have absolutely no regrets or complaints.
                                          Good luck and
                                          Take Care,
                                          Scooter
                                            Wow, you definitely have space for new toolbars! ๐Ÿ˜ฒ ๐Ÿ˜ฎ
                                            • 11
                                            • 12
                                            • 13
                                            • 20
                                            • 21
                                            • 11 / 21
