[Plugin Library] LibFredo6 - v14.4c - 18 May 24
i cant extract my downloaded libfredo to my sketchup8 plugin folder i got error while doing it it said cant find a libfredo file
i need more help
i need more help
i got it already
and all of plug-ins i download is working except the curviloft, example is when i make a 2 circle with different size on both end and i do the procedure and on transition part theres no output all i can see is the to circle
and if i use the button with the face icon my su8 turn to not responding state
i think i follow the right steps but all i can got is error -
Merci!
Thanks a lot! Very helpful and capable plugin!
Thanks for sharing.
NEW RELEASE: LibFredo6 3.6b - 13 Jan 11
This new release is mainly driven by Curviloft 1.1 (and to anticipate on some future scripts). It also includes fixes for SU8 and other evolutions for all my scripts (including support a two-phase loading for Curviloft, FredoScale, RoundCorner and Tools on Surface).
So it is advised to download it.
See main post for download.
Hi friedo06
first of thank u for developing such useful plugin
Nice work dude keep it up!I'm now exicted to learn more & more abouth Ruby script
take care -
Thank you!I have downloaded the plugins.
I've copied paste libfredo6 in my plugins folder...Can the following folders be safely deleted....??
LIBFREDO6_Dir_34
LIBFREDO6_Dir_35
LIBFREDO6_Dir_34
LIBFREDO6_Dir_35
YES.
Same for the plugin folders where you can remove the older folders.Fredo
I must be doing something wrong here. I downloaded version 3.6 and unzipped as instructed, and sure enough, I've got the folder LIBFREDO6_Dir_36 and the file LibFredo6.rb in my \Plugins directory. But when I run Sketchup, nothing new shows up in the Window menu. Any ideas?
The Lib is support for other tools by Fredo!
Many of these are Extensions and need activating from menu Window > Preferences > Extensions...... -
i'm beginer. thk you!
thank you!!! ^^
have a nice day -
Fantastic
when i try to unzip this i just get 100 error messages...what am i doing wrong?
Could you indicate which kind of error you get.
thanks
@ohsleeper said:
You just have problem of Security with Write access to the SU Plugins folder. This should be true for all plugins.
You will have to sort it out first to have proper access.Fredo
I've reported this quite a while ago (months) and the issue still exists. O my first iMac(Core2Duo 2.4 GHz) this plugin performed so sluggish that it was unusable. The menu items and 3D space updates when selecting edges took several seconds to update and that lag between user action and reaction of the tool rendered it not usable.
Now I have a 27" iMac 2.93 GHz Intel Core i7 with 12GB Ram (even though I doubt the latter makes any difference in this case). And while naturally this machine is much faster there still is a very definite lag between user input and reaction of the tool. Usable but really only barely. Noting for continued use.
I also have a Windows XP running in VMware fusion on the same machine and have don't have these problems there. Even though it's running in a VM reaction to user input is instantaneous. No perceivable lag whatsoever!
I've worked some with the Skindigo exporter plugin in OSX and that works smooth as butter. Quite strange!
