    [Plugin Library] LibFredo6 - v16.1a - 31 Aug 26
    2.2k Posts 581 Posters 6.7m Views 583 Watching
      πŸ˜†
        Now come on, Thom! You know that I rarely lose my temper (at least in public) 😳
          I'll give you that. You're better than I am.
            rstanley
            its great hearing about all the happy souls using Fredo. Wish I could join you. Instead like many I am unable to get the plug in to work ---at all.
            I am seeing the fredo download in my left most sketchup /preferences/extensions menu but it still spits out large error messages about being unable to read certain LIb and other files.
            Here's the exact error message:
            Error Loading File bezierspline.rb
            no such file to load -- libtraductor.rbError Loading File Z__loader.rb
            undefined method `effective_load' for nil:NilClassError Loading File /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/FREDOSCALE_Dir_20/__loader.rb
            uninitialized constant Traductor::Plugin::MYPLUGINError Loading File ZLoader__FredoScale.rb
            Other plug ins are working fine, (including bezier spline) ...
            Have followed the instructions given by TIG to a "T" .
            Is there anything I am missing seriously ??? The Fredo guy mentions having to install the Fredo round corner plug in to get it to work. Ok , but where is that ? Substantive help needed thanks
              duykim516
              Thanks a lot for this one
              • O Offline
                olbapxpablo
                i cant extract my downloaded libfredo to my sketchup8 plugin folder i got error while doing it it said cant find a libfredo file
                i need more help
                • O Offline
                  olbapxpablo
                  i need more help
                  i got it already
                  and all of plug-ins i download is working except the curviloft, example is when i make a 2 circle with different size on both end and i do the procedure and on transition part theres no output all i can see is the to circle
                  and if i use the button with the face icon my su8 turn to not responding state
                  i think i follow the right steps but all i can got is error
                    axelcohen12345
                    Merci!
                    • Z Offline
                      zervasgr
                      Thanks a lot! Very helpful and capable plugin!
                        taiwan63
                        Thanks for sharing.
                        • fredo6F Offline
                          NEW RELEASE: LibFredo6 3.6b - 13 Jan 11
                          This new release is mainly driven by Curviloft 1.1 (and to anticipate on some future scripts). It also includes fixes for SU8 and other evolutions for all my scripts (including support a two-phase loading for Curviloft, FredoScale, RoundCorner and Tools on Surface).
                          So it is advised to download it.
                          See main post for download.
                            pankaj_tamore
                            Hi friedo06
                            first of thank u for developing such useful plugin
                            Nice work dude keep it up!I'm now exicted to learn more & more abouth Ruby script
                            take care 😎
                              tonyliu52
                              Thank you!I have downloaded the plugins.
                                arjunmax09
                                I've copied paste libfredo6 in my plugins folder...Can the following folders be safely deleted....??
                                LIBFREDO6_Dir_34
                                LIBFREDO6_Dir_35
                                when you fail at something....you haven't really failed...you've found one way the thing will not work out
                                • fredo6F Offline
                                  LIBFREDO6_Dir_34
                                  LIBFREDO6_Dir_35
                                  YES.
                                  Same for the plugin folders where you can remove the older folders.
                                    John P
                                    I must be doing something wrong here. I downloaded version 3.6 and unzipped as instructed, and sure enough, I've got the folder LIBFREDO6_Dir_36 and the file LibFredo6.rb in my \Plugins directory. But when I run Sketchup, nothing new shows up in the Window menu. Any ideas?
                                      The Lib is support for other tools by Fredo!
                                      Many of these are Extensions and need activating from menu Window > Preferences > Extensions......
                                      • H Offline
                                        hero719
                                        i'm beginer. thk you! πŸ‘ πŸ‘ β˜€
                                          k2wengen
                                          thank you!!! ^^
                                          have a nice day 🀣
                                          • H Offline
                                            Hexmeister
                                            Fantastic
                                            • 11
                                            • 12
                                            • 13
                                            • 111
                                            • 112
                                            • 11 / 112
