    A Welcome Message to New SketchUcation Members
    1.4k Posts 667 Posters 867.8k Views 667 Watching
      Hello Binu and welcome. There's lot to see here indeed.
      Please, do not write in all CAPS however.
      • F Offline
        forrrest
        Hi All,
        Been using sketchup for about 6 months now, only just discovered the power of plugins after I was trying to join 2 curves by hand and though 'there must be an easier way.........' now seen the the light ๐Ÿ˜„
          RafaDesign
          Rafa here from Cape Town. Mainly interested in stadium and sports venue design!
          Look forward to finding out about plugin-ins similar to the soap, skin and bubble plugin.
            Welcome to SCF! ๐Ÿ‘
              Drafter X
              Drafter X here.
              My new online identity is incognito as I get a new business going while still finishing with my current employer.
              Hoping to use sketchup extensively in the new venture.
                Sounds mysterious, welcome to the madhouse
                  keen_builder
                  Hi All
                  Im only very new at this type of program , I build scale models of cars and trucks and found this program to be a great help in design to 3d in stead of just on paper , Ive learnt alot from trial and error , But have yet to learn how to make a curved pipe like exhaust or roll cage , I know Plug Ins are a big thing so Im looking into how that works , I look forward to seeing some of your work and chatting with you all over time
                  Many Thanks
                  John
                    Hi John and welcome!
                    Let's have a quick look at the Follow me tool here. I am not sure an exhaust pipe would exactly look like this but you can get the idea. Download the skp file and do as instructed in the image.
                    Pipe.skp
                      keen_builder
                      Thank You Gaieus , after reading several posts on this forum and useing the search button I was able to find some very helpful hints on how to do this , Im not very good at reading long pages unfortunately so I have had to learn from trial and error , now I have started to learn curves and pipes , I can further my education with this program .
                      The wealth of information that this forum holds is incredible and look forward to learning so much more .
                      Thanks again for your help ๐Ÿ˜„
                        If you are planning to make many of these pipes, some plugins will be invaluable. First of all, to make the whole curve (created of several arcs and lines above) into one polyline, there is the Weld plugin. If you weld curves together, you can select them at one and also the resulting pipe will be smooth all the way long.
                        Then there is a tool, Tuba along path, to make these welded paths into a pipe just by one click.
                        Finally, to create pipes with quite irregular diameters along their path, there are several lofting tools like Curviloft for instance.
                          keen_builder
                          Wow !! Thanks so much for the Help , Im really starting to enjoy this program now that I can make pipes and such , Im currently working on a manifold and a off road buggy frame .
                          Thank You again for this Help it is very much appreciated ๐Ÿ˜„
                          • H Offline
                            harnstein
                            @gaieus said:
                            ..Tuba along path..
                            Sry Gaieus, couldn't hold it.. ๐Ÿ˜‰ Hope you don't mind..
                            tuba..
                            still sketchin'
                            • shuraS Offline
                              shura
                              ๐Ÿคฃ
                              that's a good one harnstein. by the way, your username is ๐Ÿ˜† too, are you german?
                              • H Offline
                                harnstein
                                yep, alex
                                almost next door, berlin tiergarten, nice to meet you ๐Ÿ˜‰
                                still sketchin'
                                  Yep, that was a good one indeed! ๐Ÿ˜„
                                  Ha! I still remember that Tiergarten from the time when there were two Berlins!
                                  ๐Ÿ˜ž
                                  • H Offline
                                    harnstein
                                    thanks-
                                    berlin, it still appears to me like they are still two ๐Ÿ˜‰
                                    greetings to hungary and congrats for your 20.000 post!
                                    now lets welcome the new users here again ๐Ÿ˜‰
                                    still sketchin'
                                      Holy smokes! ๐Ÿ˜ฎ
                                        mingjae
                                        hello, this is my third question and it looks like no needed to make anew thread,
                                        so I post the simple question here, hope you guys can help me to solve the problem ๐Ÿ˜›
                                        This is it:
                                        http://img694.imageshack.us/img694/6261/bingung.jpg
                                        above is the Top view, I rotate it to match it with the coordinate in Google Earth (i dont know exactly the degree I just rotate it),
                                        if I go to Right view, then the Picture Plan is on A, how to make it to see in B?
                                        Should I do it manually? create a line in origin X direction (i've change the position of the Axes)and measure the degree and then rotate it?
                                        2nd: where is the north?
                                        thx
                                          Hi Joe,
                                          The so called "standard views" are always aligned to the original world axes (or global axes) of the model no matter what the alignment of your building or what a new set of (temporary) axes you have. This is a much debated "feature" and many people think it should be changed but for the time being, we have to live with this.
                                          There are two solutions:
                                          1. You can align your view to that plane B by navigating to (somewhat) that view then right click on the face that is parallel with that plane and "Align view".
                                            Note that this only works with faces (not groups/components). Once you are in such a view, you can create a scene and get back there next time without this workaround.
                                          2. Make a component of your whole building adjusting the component axes conveniently (parallel to the building's walls). Now you can always export this component by right clicking and "Saving as...". After you open the component (a new file), it will inherit its axes from the component axes in the model.
                                            You can always "reload" the modified component in your master file: just right click on the original model and "Reload".
                                          • W Offline
                                            who74
                                            Hay all just discovered Sketchup nice modeling tool.
                                            • 40
                                            • 41
                                            • 42
                                            • 43
                                            • 44
                                            • 72
                                            • 73
                                            • 42 / 73
