    A Welcome Message to New SketchUcation Members
    1.4k Posts 667 Posters 1.2m Views 667 Watching
    • Rich O BrienR Online
      Sounds mysterious, welcome to the madhouse
        keen_builder
        Hi All
        Im only very new at this type of program , I build scale models of cars and trucks and found this program to be a great help in design to 3d in stead of just on paper , Ive learnt alot from trial and error , But have yet to learn how to make a curved pipe like exhaust or roll cage , I know Plug Ins are a big thing so Im looking into how that works , I look forward to seeing some of your work and chatting with you all over time
        Many Thanks
        John
          Hi John and welcome!
          Let's have a quick look at the Follow me tool here. I am not sure an exhaust pipe would exactly look like this but you can get the idea. Download the skp file and do as instructed in the image.
          Pipe.skp
            keen_builder
            Thank You Gaieus , after reading several posts on this forum and useing the search button I was able to find some very helpful hints on how to do this , Im not very good at reading long pages unfortunately so I have had to learn from trial and error , now I have started to learn curves and pipes , I can further my education with this program .
            The wealth of information that this forum holds is incredible and look forward to learning so much more .
            Thanks again for your help ๐Ÿ˜„
              If you are planning to make many of these pipes, some plugins will be invaluable. First of all, to make the whole curve (created of several arcs and lines above) into one polyline, there is the Weld plugin. If you weld curves together, you can select them at one and also the resulting pipe will be smooth all the way long.
              Then there is a tool, Tuba along path, to make these welded paths into a pipe just by one click.
              Finally, to create pipes with quite irregular diameters along their path, there are several lofting tools like Curviloft for instance.
                keen_builder
                Wow !! Thanks so much for the Help , Im really starting to enjoy this program now that I can make pipes and such , Im currently working on a manifold and a off road buggy frame .
                Thank You again for this Help it is very much appreciated ๐Ÿ˜„
                • H Offline
                  harnstein
                  @gaieus said:
                  ..Tuba along path..
                  Sry Gaieus, couldn't hold it.. ๐Ÿ˜‰ Hope you don't mind..
                  tuba..
                  still sketchin'
                  • shuraS Offline
                    shura
                    ๐Ÿคฃ
                    that's a good one harnstein. by the way, your username is ๐Ÿ˜† too, are you german?
                    • H Offline
                      harnstein
                      yep, alex
                      almost next door, berlin tiergarten, nice to meet you ๐Ÿ˜‰
                      still sketchin'
                        Yep, that was a good one indeed! ๐Ÿ˜„
                        Ha! I still remember that Tiergarten from the time when there were two Berlins!
                        ๐Ÿ˜ž
                        • H Offline
                          harnstein
                          thanks-
                          berlin, it still appears to me like they are still two ๐Ÿ˜‰
                          greetings to hungary and congrats for your 20.000 post!
                          now lets welcome the new users here again ๐Ÿ˜‰
                          still sketchin'
                            Holy smokes! ๐Ÿ˜ฎ
                              mingjae
                              hello, this is my third question and it looks like no needed to make anew thread,
                              so I post the simple question here, hope you guys can help me to solve the problem ๐Ÿ˜›
                              This is it:
                              http://img694.imageshack.us/img694/6261/bingung.jpg
                              above is the Top view, I rotate it to match it with the coordinate in Google Earth (i dont know exactly the degree I just rotate it),
                              if I go to Right view, then the Picture Plan is on A, how to make it to see in B?
                              Should I do it manually? create a line in origin X direction (i've change the position of the Axes)and measure the degree and then rotate it?
                              2nd: where is the north?
                              thx
                                Hi Joe,
                                The so called "standard views" are always aligned to the original world axes (or global axes) of the model no matter what the alignment of your building or what a new set of (temporary) axes you have. This is a much debated "feature" and many people think it should be changed but for the time being, we have to live with this.
                                There are two solutions:
                                1. You can align your view to that plane B by navigating to (somewhat) that view then right click on the face that is parallel with that plane and "Align view".
                                  Note that this only works with faces (not groups/components). Once you are in such a view, you can create a scene and get back there next time without this workaround.
                                2. Make a component of your whole building adjusting the component axes conveniently (parallel to the building's walls). Now you can always export this component by right clicking and "Saving as...". After you open the component (a new file), it will inherit its axes from the component axes in the model.
                                  You can always "reload" the modified component in your master file: just right click on the original model and "Reload".
                                • W Offline
                                  who74
                                  Hay all just discovered Sketchup nice modeling tool.
                                    sketchygal
                                    Just wanted to say hello as I'm new to SketchUp. Not to terribly advanced in any kind of computer modeling but I look forward to getting better and learning more!
                                    • mitcorbM Offline
                                      mitcorb
                                      To who74 and sketchygal: Welcome on behalf of all in the forum. Gaieus might be napping. Feel free to look around in all of the subforums and ask any question- no matter how trivial you think it is- in order to better understand the program. There are many people willing to assist you.
                                        mingjae
                                        to Gaieus:
                                        oh woow, umm..I don't know how to thanks, again, Gaieus save my life
                                        thanks to SketchUcation!
                                          Hi all,
                                          Yeah, when Mitcorb wrote, it was 4:30 am. (although was not sleeping but only because I had an overnight job - this is what I made from scratch from evening to dawn)
                                          NOW I am a bit sleepy (and could not save anyone's life even if (s)he was drowning next to me)
                                          ๐Ÿ˜†
                                            katy3kk
                                            Hi everyone!
                                            I'm very new to SketchUp and need some advice please.
                                            I'm a third year student and Iโ€™m in the process of doing my final year project, I was going to be using 3DS MAX with QUEST, but there was a complication with me having access to the software ( not on the correct course to have a copy.)
                                            One of my lecturers suggested using Unity3D as it's a free game engine after a bit of research I noticed a lot of other people where modelling in SketchUp, as it send both the object and textures across together once it has been exported, but the free version of sketch up Iโ€™m using does not allow me to export in .FBX
                                            which is why.....I need to buy the latest pro version but on a student licence in the UK, I am currently using the free version of SketchUp 8, but I need to be able to export my 3D models so I can use them in Unity3D, So if anyone can suggest a website I could buy from, that you know is safe I would be very thankful ๐Ÿ˜„ (I have ordered an NUS card which should arrive within 7days, to prove I am a student within the UK)
                                            Any help would be very much appreciated,
                                            Thanks for your time, Kate
                                            • 40
                                            • 41
                                            • 42
                                            • 43
                                            • 44
                                            • 72
                                            • 73
                                            • 42 / 73
