    Welding Bead - Not to Be Confused with the Weld Plugin
    15 Posts 7 Posters 7.8k Views 7 Watching
      30KView
      Thanks, i think you solution is a good one and models reality much better than my attemp.
      I may wait to see if any one else chimes in but thank you again.
      • Jean-FrancoJ
        Jean-Franco
        Hi, I remember someone showing us the way he used to simulate welding bead on a bicycle frame. Who is it ?
        Edit:
        I think it's this one: http://forums.sketchucation.com/viewtopic.php?f=18&t=963
        Jean-Franco
        • GaieusG
          Ah yes, I remember that topic, too.
          Maybe a bit unnecessarily "overdone" in the details (unless you examine it from very close) but of course, definitely an excellent way to achieve perfectness!
          (Not as if I didn't regularly tend to overdo details that won't be normally seen anyway - no wonder I do not work efficiently and never make a deadline 😄 )
            30KView
            OK, thanks to the help of others(Gaieus and Jean-Franco and plug in authors) I was able to improve my welded joints so that they were tremendously better than my initial attempts - see attached file. Basically the soap skin bubble plugin with -ve bubble. Also my first attempt at layout. Thanks for the help and as always, appreciate any feedback.
            Regarding the overdone factor, which is definitely high for this simple project. Besides having a compulsiveness problem with having representative model forms, it is also a technique learning exprience for me. Thanks again.
            mast retrofit.layout
            • GaieusG
              And for those (free SU users) who cannot open layout files, here is an image export:
              Nice job!
              (If you have some "really proper" image of such a weld, you could also project it on those pieces)
                Slimdog
                Not to sure what your experience is in the steel industry but there are lots of symbols that are used for showing welds on shop drawings.
                I have tried modeling welds in sketchup with rsw's technique and it works well but takes up tonnes of memory and slows my puter down. I think just adding a texture is the easiest way.
                http://www.tpub.com/content/draftsman/14276/img/14276_214_1.jpg
                • W
                  watkins
                  There is also this:
                  Regards,
                  Bob
                  • W
                    watkins
                    and this:
                    Regards,
                    Bob
                      Dear Bob,
                      Thanks for the links to those videos. Interesting approach in the first one although I think he was working harder than he needed to for some of it but he got the job done. The second one is excellent: use a material to insinuate the texture of the weld bead to keep the file size down.
                      • charly2008C
                        charly2008
                        Another possibility would be CurviLoft and EEbyRails.
                        Charly
                        Untitled.skp
                        • W
                          watkins
                          This might also be useful
                          Regards,
                          Bob
