    [Plugin] Coords Text Tag from Datum
    149 Posts 27 Posters 109.7k Views 27 Watching
    • GeorgeG Offline
      George
      @tig said:
      EDIT:
      Having thought about it...
      You must set the X/Y values as your long/lat values in the main dialog OR you can initially use NOT use long/lat but say meters and place one Tag at the origin... THEN change to Long/Lat and it should work... as the one at the origin changes to your Model's long/lat...
      I'll have another think about this 'logic'...
      Yes, I found that works for enabling the LL function of the Add Coords-Tag tool.
      If I start with XY-Units set to any unit besides Latitude_Longitude, all the tools work fine.
      As you suggest …
      I can start by creating one ‘Length-Units’ Tag in the model, say, at the Origin, and then switch the Settings dialog to XY-Units = Latitude_Longitude.
      Thereupon the existing length-units tag updates to LL and from there on the Add Coords-Tag tool places a correct LL tag wherever one clicks. All is good.
      The dysfunction occurs when one then goes to the plugin menu and selects; Add Coords-Tag by Dialog.
      My little Test Model 1 is geo-located at 46°N 90°W
      I enter those coordinates in the dialog as shown below
      The LL tag that results is located ~ 46° (some 2700 nautical miles) to the south and 3° east at:
      0.018412N 87.000000W
      When I close SU, open and repeat the process, the same errant LL value occurs.
      http://lh5.ggpht.com/_pI3lDYnW_xk/TTtFITa0YNI/AAAAAAAAD8M/e0RjFM5_f24/ScreenShot110.jpg
      The Add Coords-Tag by Dialog and Import Coords-Tag from CSV (in LL units) are the elusive gems.
      -Geo
      "Everyone is entitled to his own opinions, but not to his own facts." ~Patrick Moynihan
        I think I got it, guys. Please, confirm that in the input dialog, the Lat and Log lines are changed. What you enter as longitude, should be latitude and vice versa. Try to enter into the Longitude line what you'd enter into the Latitude line and vice versa. See also attached screenshot. My SU window is floating above my GE window so bot co-ordinates can be seen.
        By the way, Geo, if you really want to geolocate your model in SU 8, never use the map but the manual location field. Only then "add imagery". It's a couple of metres off otherwise (I know it would not be needed in the particular case you are after just mentioning).
          So.... is it 'broken' ?
          And if it is what do I [we] need to do to fix it ?? 😕
          • GeorgeG Offline
            George
            Hello TIG & Gaieus,
            I just got back to see Gaieus’ post.
            Let me try Gaieus’ solution and post how it works for me.
            -Geo
              No, it works perfectly. Just swap the Longitude and Latitude texts in the dialog. This way it is misleading because we need to enter the values swapped.
              This (line 799-803):
              <span class="syntaxdefault">    if xyunits</span><span class="syntaxkeyword">==</span><span class="syntaxstring">"Latitude_Longitude"<br /></span><span class="syntaxdefault">      p0</span><span class="syntaxkeyword">=</span><span class="syntaxstring">"Longitude; "<br /></span><span class="syntaxdefault">      p1</span><span class="syntaxkeyword">=</span><span class="syntaxstring">"Latitiude; "<br /></span><span class="syntaxdefault">      xyus</span><span class="syntaxkeyword">=</span><span class="syntaxstring">"LL"<br /></span><span class="syntaxdefault">    else<br /> </span>
              should be
              <span class="syntaxdefault">    if xyunits</span><span class="syntaxkeyword">==</span><span class="syntaxstring">"Latitude_Longitude"<br /></span><span class="syntaxdefault">      p0</span><span class="syntaxkeyword">=</span><span class="syntaxstring">"Latitude; "<br /></span><span class="syntaxdefault">      p1</span><span class="syntaxkeyword">=</span><span class="syntaxstring">"Longitude; "<br /></span><span class="syntaxdefault">      xyus</span><span class="syntaxkeyword">=</span><span class="syntaxstring">"LL"<br /></span><span class="syntaxdefault">    else<br /> </span>
              "Latit iude" is misspelt there anyway (good it was not in the code - although then it would have turned out at least - and I could hardly find it as I did not notice the misspell first and was also searching for "Latitude" in NP++) so it could bear an update.
              • GeorgeG Offline
                George
                That solved that problem, Gaieus. 😍
                Now to try this on the ‘Import Coords-Tags from CSV’ tool.
                Note the coordinates entered in the dialog are the reverse of those in Model Info-Location
                Yet, the LL-Tag it creates is correct.
                http://lh3.ggpht.com/_pI3lDYnW_xk/TTt43VeSnEI/AAAAAAAAD8g/r2plRMUotD4/ScreenShot111.jpg
                -Geo
                  Oh, I am really glad. When I was torturing TIG along this whole topic until we got where the plugin is, I mainly concentrated on the other aspects of it (custom, ortho-co-ordinates) as Didier by then had come out with his LatLong tool and in this plugin here it was just an "extra" for me (but of course, important one) so did not notice this little glitch.
                  Anyway, I hope you enjoy it as much as I do (and of course, many thanks to TIG again)
                  I think in that Help Forum topic I overcomplicated the thing with the PhotoMatch thing as the guy does not seem to need it as accurately.
                    OK, so I went along and did the changes in the code I wrote above and success; it works perfectly!
                      Here's an update http://forums.sketchucation.com/viewtopic.php?p=284829#p284829
                      It should now work ! as Gaieus explained the prompts were wrong 😒 .
                      At least I've got him to delve into the bowels of a script AND fix it himself!!
                      We'll make a scripter of you yet Csaba!!!
                      I fixed the typo in the 'Add' dialog prompts' text.
                      I've also add +/- clues in them to avoid users West of Greenwich getting confused by Longitude!
                      Also now the 'Add' dialog's values of the Lat/Long start off with the model's origin Lat/Long and thereafter use the last used values...
                        @george said:
                        OK. I’ll change the code and report back.
                        Perhaps that is also what is causing the problem with ‘Import Coords-Tags from CSV’. ❓
                        The script will export LL-tags to CSV file perfectly.
                        Nothing happens when I try to import a CSV file in LL units.
                        I’ve tried importing CSVs I created and I’ve tried importing one of the CSVs the script exported.
                        Neither CSV will work. I also tried reversing Latitude and Longitude in the CSV file. Niente. 😞
                        ‘Import Coords-Tags from CSV’ does work if I specify length units and not LL
                        -Geo
                        Geo - no need to change the code - get v1.7, it's fixed!!!
                        'Import Coords-Tags from CSV'
                        This imports all of the 'Coords-Tags' into the Model from a CSV file in
                        to format X,Y,Z or LAT,LONG,Z - the values must be comma separated and
                        consist of numerals only with '.' as the decimal separator, one point
                        per line.
                        A dialog then requests the 'units' used in the CSV file for XY and Z,
                        and if you want to add Cpoints [defaults are 'm' and 'Yes'].
                        If the CSV file has a 'header' line etc it is ignored.
                        Is this what you are doing ?
                        • GeorgeG Offline
                          George
                          -Geo
                          UPDATE
                          I'll load the new version and report back. 😉
                            Well, I am really glad we could iron this out. I am still thinking on some possible, extra features but enough for today (and this week-end).
                            TIG: if the error had been in the codeitself, I would've never been able to find it so let's just forget that scripter apprenticeship! This was just a lucky trial and error (and I got suspicious because one regularly needs to add the Lat datum first and the Lon datum second although this is merely a convention of course)
                            • GeorgeG Offline
                              George
                              Got it. 👍
                              Success!!!
                              The 'Add Coords-Tag by Dialog' tool now places LL-Tags perfectly.
                              per line.
                              Yes.
                              Still, no success with v1.7 when I try importing a CSV in LL/Z units.
                              And …
                              Only partial success importing a CSV in XYZ length units.
                              I’m testing 'Import Coords-Tags from CSV' in XYZ length units with a simple CSV file.
                              I shared the CSV file at Google Docs:
                              https://spreadsheets.google.com/ccc?key=0AqR273kvdPGOdGhhWnJ6cTAyUDNZRExWYnc1YXk2emc&hl=en&authkey=CMLQqZYD
                              In the image below: Only 7 tags were created from the CSV file containing 49 points.
                              The 8th cords-tag you see in the image (at the origin) was placed prior to CSV import.
                              http://lh5.ggpht.com/_pI3lDYnW_xk/TTxYx-GVdPI/AAAAAAAAD80/65FlXWz5zBk/ScreenShot112.jpg
                              I’m fairly certain there is no problem is with the CSV file as I can import the file with the version of ‘Import Points Cloud’ script I’m running and all 49 points appear as in the image below.
                              The points in the CSV file describe the vertices of a cylinder with 24 segments (48 points)
                              The 49th point in the CSV file is at the origin [0,0,0]
                              http://lh3.ggpht.com/_pI3lDYnW_xk/TTxYyKHaoWI/AAAAAAAAD84/pZjMRqUHWkQ/ScreenShot113.jpg
                              I’ve been methodically trying different combinations of settings in the script settings dialog, to no avail.
                              Perhaps if we (or is it just me who's fouled up) manage 'Import Coords-Tags from CSV' in simple XYZ length units to work, then we’ll (I'll) be able to figure out the process using XY=LL/Z=Feet. 😕
                              Many thanks for your efforts, TIG.
                              -Geo
                                Geo
                                Can you zip and post your 'problem' CSV file so I can try it - telling me the 'units' [feet?]....
                                • GeorgeG Offline
                                  George
                                  Hi TIG,
                                  Here is: Points Test.zip
                                  Error 404 (Not Found)!!1
                                  (docs.google.com)
                                  The units were inches @ 6 dp
                                  -Geo
                                    @george said:
                                    Hi TIG,
                                    (docs.google.com)
                                    -Geo
                                    Thanks, I'll have a look at it - by the way you attach modestly sized zips etc like this direct to your posts... 😕
                                      Here's an updated version http://forums.sketchucation.com/viewtopic.php?p=284829#p284829
                                      v1.8 - Typos in Import-CSV fixed to allow -ve values, z=0 & no z.
                                      I had some stupid code errors that meant that xyz values with any negative numbers were skipped and also they were getting skipped if z didn't exist or was 0 😒
                                      Now all fixed... 😄
                                      George - your CSV now works perfectly! two 24 point circles one above the other, and one cpoint at the origin - 49 in all...
                                      • GeorgeG Offline
                                        George
                                        @tig said:
                                        .... by the way you attach modestly sized zips etc like this direct to your posts... 😕
                                        Forgive me, TIG.
                                        We do not have such modern conveniences over at Google SketchUp Help Forum. 😳
                                        -Geo
                                        • GeorgeG Offline
                                          George
                                          @tig said:
                                          Here's an updated version v1.8 ... Now all fixed... 😄
                                          😍 Yes !!!
                                          The CSV import in LL/Z units works perfectly as well !!!
                                          I'll alert the OP in the GSHF thread ... where all this commotion started. 😒
                                          Thank you, TIG. You are the master 🤓
                                          Thanks to Gaieus also. 😄
                                          -Geo
                                            Many thanks for this update, TIG!
                                            (and Geo, for being so persistent!)
                                            • 3 / 8
