    Problems doing a curve
    26 Posts 5 Posters 3.4k Views 5 Watching
    • G
      Gumleguf
      To illustrate my point.
      Two groups are facing each other. I "just" need to connect them, but can't work out how to.
      JamoR909_clone_5_two_facing_groups.skp
      • GaieusG
        The whole thing is just 30 mm thick. Should the max top thickness be 520 mm?
          I quickly made this from the one face.
          Switched of Hidden Geometry.
          Removed the 'holes-surfaces'.
          Selected all Surface/Edges
          Use EEbyVector to extrude it backwards by ~50mm.
          The 'sides' are made, but the 'back' is missing at this point.
          Copied [Move+Ctrl] the front Surface and placed it on the back.
          Selected that Surface and Reversed it so all faces are then 'out'.
          • G
            Gumleguf
            Gaieus > Not sure I understand?
            Bottom width is 420mm, top width is 520mm. Space between the two (depth) is 50mm.
            • G
              Gumleguf
              TIG > That's 99% procent done. Sweet! I'll try to follow your instructions, and see how far I get.
              You guys rock!
              • G
                Gumleguf
                Tig > Tried following your instructions and ended up with this. It looks correct except that when I use EEbyVector to extrude it backwards by 50mm my model gets "sliced up". I finished and also pasted the back to it and reversed it, but when smoothing the model the "slices" remains:
                JamoR909_clone_6_EEbyVector_1.skp
                • GaieusG
                  Ah, OK, I thought you meant the thickness of that plate...
                    [attachment=1:1bxp6nwa]<!-- ia1 -->gbl324234.JPG<!-- ia1 -->[/attachment:1bxp6nwa]
                    [attachment=0:1bxp6nwa]<!-- ia0 -->JamoR909_clone_6_EEbyVector_1.skp<!-- ia0 -->[/attachment:1bxp6nwa]
                    NOT quite the expected result... but not irredeemable...
                    Select a face with the correct orientation and right-click 'Orient' to get them all facing the same way... then select all and Smooth till it looks like you want...
                    • G
                      Gumleguf
                      TIG > Am I not following your instructions?
                      I tried selecting a face, right-clicked and selected "Orient Faces", but it seems to me that it only made some other faces reverse?
                        I think I have it!
                        You are making internal faces so can never successfully get orient faces to work as there are always some wrong!
                        I think this is because you are extruding ALL Edges as you have View > Hidden Geometry ON and are working on the Smoothed ones as well.
                        Switch View > Hidden Geometry OFF, then Select the Surface and its Edges [then Shift+Ctrl to deselect the Surface]...
                        EEbyVector on the Edges back 50mm.
                        At that point you shouls have all of the 'sides' made without a 'back'.
                        Copy the front as the back as explained before and reverse it...
                        πŸ€“
                        • G
                          Gumleguf
                          I think you're right.
                          Does this look correct (I think it does, but what do I know... πŸ˜‰ )?
                          JamoR909_clone_6_EEbyVector_3.skp
                            Good!
                            Now all you need to do is select the front Surface, right-click and Orient - all faces will be correct.
                            To 'smooth' the edges you don't want around the top edge, Select all [treble-click surface] and right-click Smooth...
                            Done πŸ˜„
                            • G
                              Gumleguf
                              This is too cool.
                              Thanks all. You are the best.
                              • 2 / 2
