    SU upgrade to 8.0.4811 (Maintenance 1)
    108 Posts 42 Posters 41.4k Views 42 Watching
    • Dan RathbunD
      Dan Rathbun
      @jason_maranto said:
      I had no such issues on either system I installed on... very odd.
      But did you make a backup?
      Seems if there is a subfolder under the Google folder, and it has "Google Sketchup 8" as part of the folder name (instead of an exact match,) the Installer gets confused.
      LESSON: when you make backups, change the foldername to something that does not have the substrings "Google" or "Sketchup" in it !!
      I'm not here much anymore.
      • jason_marantoJ
        jason_maranto
        I always move my backups to DVD, a server, or a thumb drive in case the drive goes -- but I was talking more about not having the additional software installed or settings changed.
        Best,
        Jason.
          jeabdc
          Thankyou and Happy New Year 2011 _ สวัสดีปีใหม่ทุกๆคนครับ
          Chaingmai, Thailand
          • AndrewSA
            AndrewS
            Dan,
            @dan rathbun said:
            I wanted to do a fresh clean install of the release...
            This wasn't any more necessary an activity at release time than it was beforehand, since beta 6 is actually what we released for M1. It would probably have been best to leave it alone and allow the installer to automatically handle the details.
            @dan rathbun said:
            I ran the 8.0M1 installer
            It created a new "%ProgramFiles%/Google/Google Sketchup 8" folder, as expected... BUT
            it copied everything from my Backup folder heirarchy, ...
            THEN ... overwrote ALL the Google supplied files (rb, rbs, skm, skp, etc...) in BOTH folder heirarchys !!!
            It destroyed my backup copies !!!
            I'm sorry to hear of the trouble you encountered. However, as one of two people who was responsible for creating the installer and someone who has spent countless hours testing it, I have to say that this is a pretty dubious claim. I'm not writing it off as impossible, but just as incredibly improbable. If I get a chance next week, I will try to take a look to see how much control we have over how the uninstallation is performed and whether there is an error to be found in how the list of files to remove is populated. It may also be a matter of either WiX or MSI conspiring to cause such havoc, in ways over which we have no control. I can tell you however that the uninstall logic has undergone very little change since its introduction in SketchUp 7 and this is the first I've ever heard of something even remotely like this being reported. It's far more likely that human error is to blame for the issue. One way to test this would be to repeat the exact same set of steps again. If your hypothesis about the name matching is correct, you'll get exactly the same behavior the next time around. Again, I'll see if I can find any evidence to support how this might happen, but given my experience with having written, tested, used and debugged the installer for the last several years, I just have to say that it's unlikely there will be anything to find.
            @dan rathbun said:
            It installed that BLEEPIN' Google IE Toolbar without asking if I wanted it.. causing me to uninstall it. (Hate this!) I am installing an application .. and your installer is messin' with another unrelated application!!
            I'm sorry to say that this is rather more plausible than your first complaint. We actually go to great lengths to ensure this sort of thing does not happen, because we recognize how frustrating it can be. Apparently we have a bit more work left to do there. Our intention is to program this so that when running the installer, you are asked whether you'd like to have the IE toolbar. Regardless of your answer, we attempt to write a registry value indicating that we've asked you this question. Any time after that when you run the installer, it should locate the registry key, recognize you've been asked before, and then not prompt you about it at all. Of course, it should never, ever install something against your wishes. The behavior you're describing is something we would never like to see happen.
            Unfortunately, ever since IE 8 came out, the way we detect whether you already have the IE toolbar or not, as well as the way we do some things like setting Google as the default search engine (if you've asked for that to be done), is much more complicated than it used to be. We've tweaked it many times and have spent quite a while trying to debug any remaining issues, but it appears that we have a bit more work to do there.
            As an aside, one thing I'd like to make very clear though is that for those of you who run registry cleaners or similar utilities, you're taking your life into your own hands to do so. Without being aware of how every registry key in the system is being used, you always run the risk of causing damage by removing things outside of the context of the installer program. I have no idea whether that's relevant in this case or not (I suspect not), but it may be important for others to think about for the future.
            @dan rathbun said:
            And the installer turned OFF my "Links" bar !! WTF! (I am a wee bit ticked off.)
            I'm not sure what you mean by the Links bar (and in what context). If you can clarify a bit, perhaps I can address your concern.
            Andrew
            Andrew S.
            SketchUp Release Engineer
            • Dan RathbunD
              Dan Rathbun
              @andrews said:
              Dan,
              The Links bar / Menu Bar reset was just an annoyance. My last "bitch" looks this was major, but I didn't intend to mean it this way. It's the file overwriting that ticked me off, as it's creates reconstructive work for me to do.
              Specifically on the IE toolbars resetting:
              What I think happened... is that IE may have done this when your installer added the Google toolbar.
              I run IE with the MenuBar OFF (to save screenspace,) and use the ALT key to "pop" it up, whenever I need access to the menu. It's a really neat feature that the Sketchup interface could use as an option, but you'd need to implement MenuBar classes instead of the old Menu class attached to the app window.
              Anyway... after the Google Toolbar was installed and then removed (it basically had a popup balloon that said something like: "We've installed the Google Toolbar, do you want to keep it, or Uninstall it?" and I clicked uninstall. Also.. had to go thru the web poll questionaire "Why are uninstalling the Google toolbar?... etc")
              ... the check for Tools > Menu Bar was checked instead of unchecked.
              Not a big deal.. I unchecked it again.. and the IE Menubar went back into hidden-popup mode.
              Same is true for the "Links" bar. On IE within the Favorites folder, is a special subfolder named "Links", and a companion menu toggle item, at Tools > Toolbars > Links which I had checked.
              When checked, IE displays a toolbar titled "Links" and populates it with any Internet shortcuts in the %UserProfile%\Favorites\Links folder. I don't have any in there (and delete or move the ones Microsoft puts in there,) but instead put custom subfolders in the "Links" folder. IE then creates dropdown menus on the Links Toolbar for subfolders of the Links folder, and submenus for subfolders of subfolders ... etc. etc.
              Basically, in this way, the Links Toolbar becomes a My custom menubar of links that I need quick access to. (See attached image of a Links submenu named "HTML" opened.)
              Again.. After the Google toolbar was removed... I had to go thru the Tools menu, to recheck, the Links menu item, so the Links toolbar would be displayed.
              It is an annoyance... mostly. I don't know who or what is to blame (it may occur when ANY toolbar is added to IE7.)
              BTW.. I will update to IE8 (.. just have been putting it off,) the 5 other machines in the household have been updated to IE8 already.
              Because I did an UNINSTALL first, the HKCU\Software\Google\Sketchup8 registry key was removed, possibly along with the attribute you mention that keeps track of previous installer check boxes. (But I dont see it in there.. I know I have seen it somewhere before.. somewhere in the registry. DING! It rings a bell.)
              Anyway.. I recall in previous installers that there was a checkbox for the Google Toolbar. I recall previous forum discussions that people wanted it unchecked by default... according to popular opinion.
              I recall it was usually checked by default. This is not new generally.. OpenOffice Installer has an IE toolbar option that I think is checked by default (making me always uncheck it.) Anyway.. the only toolbar I run is the one for with my Anti-Virus program.
              BUT... THIS timeI do not recall seeing any toolbar checkbox, during installation. I recall the EULA confirm dialog.. and the Install Location dialog.. and thats was it.
              Am I going crazy? Did anyone else see a Google toolbar checkbox on any of the 8.0M1 Installer dialogs?
              • Dan RathbunD
                Dan Rathbun
                P.S. - I understand Google wanting to promote it's products (the Google toolbar,) BUT I don't need it.
                If you look at the image above, you will see that I have the IE built-in search bar already set to use Google search as the default.
                In addition I have a link to my Gmail page, where it belongs, in my "Dan" Links subfolder, which appears as my Dan submenu on the Links toolbar.
                It is a pet-peeve, that everyone's installer (not just Google's) is trying to install some toolbar. Bing or Yahoo or whatever.
                My experience is that these toolbars compete with one another, to scan webpages, anti-phishing, anti-popup, etc. It's not needed as it's built-into IE since IE7 at least.
                I NEVER run anymore than 1 add-on toolbar, usually the one that comes with the AV program that is installed on the machine.
                  d12dozr
                  I've never seen a question about the Google Toolbar when installing SU, and it never got installed this time around,(Win 7) but the toolbar did get installed on my old Vista system with SU7(very annoying!) without asking if I wanted it.
                  BTW Dan, I use IE Beta 9...its very fast, you might try that.
                  http://goo.gl/f7ooYh
                  • Dan RathbunD
                    Dan Rathbun
                    Thanks... I've kept IE7 installed so I can test WebDialogs running under IE7... (if that matters.) There are things I don't like about IE8. And on some computers I prefer to use FireFox. (Example.. the Apple Dev website does not display correctly in IE7.)
                    • N
                      numerobis
                      WOW! largeadressaware, shadow bug and toolbars fixed!
                      very nice update! 😎
                      i think now it's time to upgrade from v7... 😄
                      • erikBE
                        erikB
                        Shadow bug fixed. Very nice update!
                        Well done to the google developpers.
                        erikB
                        • C
                          cadmunkey
                          On both installs I did over the weekend (1 desktop, 1 laptop) Windows popped up a message saying that sketchup did not install properly and had applied compatibility settings to it. Anyone else get this? I'm not sure how to check what settings have been applied just in case this has an impact SUs performance. I dont want to run any program under any kind of emulation mode.
                          Both machines have 64bit Win7 installed. Any ideas?
                          • jbacusJ
                            jbacus
                            Could you post a screenshot of the message? Probably just means that you're running SketchUp in 32bit mode on your 64bit system. There's no harm in that (no impact on performance). Though I'm sure someone will jump in here to ask when we're going to release that 64bit version of SketchUp so you don't see this message on install 😉
                            "...exaggerate the essential and leave the obvious unclear." --Vincent Van Gogh
                            John Bacus
                            jbacus@sketchup.com
                              I run 64bit Win7 - didn't get such message...
                              • spenceS
                                spence
                                Same here, running Win. 7 64bit and installed just fine. Also this is an awesome update, I'am very stoked about the shadow bug fix, then I run across the fix that allows you to choose a different codec WhoooooHooo . From the very beginning this has bugged me to death because I could get it to use DivX on occasion if I were to restart SU but even then would hardly ever work. So, I just installed DivX and gave it a whirl, awesome, it worked so slick and the export was very fast. It looked super good.
                                If anyone would like to try, check out the difference between codecs like the default (I thinks it's Sorenson) and DivX. DivX is so much smoother, no where near as much jitter. http://www.divx.com/DivX
                                Nice Job Google SketchUp!!!!
                                Spence
                                • Al HartA
                                  Al Hart
                                  @thomthom said:
                                  Yes - Under 64bit Windows, SU can now address up to 4GB RAM. (I have tried it with a huge render.) 😄
                                  Do we have to do anything to XP (e.g. the /3GB tweak) and/or 32-bit Windows 7 and/or 64 bit Windows to use LargeAddressAware?
                                  Do we have to do anything to SketchUp?
                                  Al Hart
                                  IRender nXt from Render Plus
                                    You don't do anything, but if you have a 64bit OS, SketchUp can address more than 2GB of memory, up til 4GB. Just make sure you have a 64bit OS and at least 4GB RAM.
                                    • C
                                      cadmunkey
                                      Strange you guys didnt get the same message. This happened on 2 completely different machines. 1 a custom built desktop and the other on a Sony Vaio laptop. I will try reinstall later and see if I get the same message and I'll post a screenshot.
                                      Thanks for your replies.
                                      • C
                                        cadmunkey
                                        Just reinstalled but the message didnt appear. Obviously the info is still in the registry so doesnt need to do it again. I'll check out compatibility settings in the Microsoft forums to see what I need to do to take them off.
                                        • Al HartA
                                          Al Hart
                                          It used to be in XP that you had to change the OS to give you 3GB rather than 1.8GB of 32-bit space. I presume that fix would still help with SketchUp.
                                          The other half of my question was whether you still had to do something to enable LargeAddressAware in 32 bit Windows 7?
                                          A;
                                          Al Hart
                                            No - LAA is not possible on 32bit Windows. You do have the 3G which, which gives applications 3GB RAM and the system 1GB (As oppose to the default 2GB/2GB). That also required you to have 4GB to make use of it. I found the 3G switch to make the system a bit flimsy and unstable.
                                            • 4 / 6
