    1.3k Posts 299 Posters 2.5m Views 297 Watching
    • mitcorbM Offline
      mitcorb
      Well, good to know the updates appear to be backward compatible to earlier Sketchup versions. We would expect nothing less from the very capable Fredo6.
      ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ˜„
      And, I add my Thank You, Fredo
      • fredo6F Offline
        ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ˜„
        Yes. Normally the scripts should still work in SU6.
        The issue with SU* is that, due to a change of the Ruby interpreter, there were some small bugs generated and also some unuseful warnings.
        Also, for me, it is better is users can move to latest versions because it is easier to support.
        • N Offline
          notareal
          Thank you! โ˜€
            chloesdad
            Just wanted to add my thanks to you, Fredo for your generosity and talent.
            • F Offline
              Fletch
              Fredo, with you+SketchUp it eliminates need for almost any other modeling software. ๐Ÿ˜„
              (except for Sculptris... but I believe Whaat will have that covered in a few days/weeks/months.)
              Fletch
              Twilight Render Cross-platform Plugin for SketchUp on PC or Mac
                rattusNOR
                Great work. Thank you Fredo !
                  bowlr
                  Thanks for the plugins, howver, after I copied the files to plugins folder, I get this error msg from SU
                  "Error Loading File ZLoader__Curviloft.rb
                  no such file to load -- LibFredo6.rb"
                    bowlr, please go back and read the first post in the thread. Especially this:
                    IMPORTANT: Requires to download LibFredo6 3.6 or higher if not already installed.
                    • mitcorbM Offline
                      mitcorb
                      Quote:"Also, for me, it is better if users can move to latest versions because it is easier to support."
                      Fredo endquote
                      I agree in principle on this statement. However, I must consider more than just upgrading to SU8. My hardware is going beyond outdated, and the logistics of migrating what I have accumulated is not trivial for me. ๐Ÿ˜„
                        I think Fredo was referring to having users move to the latest versions of his tools.
                        • mitcorbM Offline
                          mitcorb
                          Ok, I missed the subtle distinction there.
                            Or I might have. that's just the way I read his comment, though.
                            • mitcorbM Offline
                              mitcorb
                              That's the problem with language, especially across cultures, and so forth. We should just switch to mental telepathy and cut out the stumbling blocks of spelling, grammar, semantics and time to type. ๐Ÿ˜†
                                I knew you were going to type that. ๐Ÿ˜„ ๐Ÿ˜†
                                  bowlr
                                  Thanks for pointing this out, much appreciated
                                  • fredo6F Offline
                                    Fredo endquote
                                    As Dave relevantly mentioned. I was talking about my Plugins. If you use the latest version of LibFredo6 and of the scripts, it is easier for me to reproduce possible bugs and issues.
                                    For SU, I try as much as possible to have them working with most SU versions (most work in SU 6 and even SU5).
                                      Pherim
                                      I just successfully used Loft along Path for the first time! (That means I used it for the first time and it worked immediately, not that I have tried it several times without success)
                                      It is simply awesome. This has to be one of the best plugins ever!
                                        make.GQ.china
                                        ๐Ÿ˜Ž ๐Ÿ˜Ž
                                        Great! A useful plug-in
                                        • jason_marantoJ Offline
                                          jason_maranto
                                          Hey Fredo, I have a file here with some geometry that gave me a hard time -- and I also have some examples of how I got it to work to a tolerable level but certainly not what I had envisioned.
                                          I'm sure user error was responsible to a degree but I though I'd share it with you if it helps debug at all.
                                          Best,
                                          Jason.
                                          loft issue.skp
                                          • fredo6F Offline
                                            Best,
                                            Jason.
                                            Jason,
                                            Thanks. This is a good example which shows some limitations of Curviloft (and it's not your errors at all!).
                                            You probably have to do it in 2 parts, as you did. First part should be with the option 'Line junction' and second part with Cubic Bezier, but you should simply skip the last profile before the rear face of the hull.
                                            Alternatively, you can take some inspiration of what it could give with the two other methods: Skinning and Loft along Path.
                                            In any case, I would suggest that you redraw the long profile to show more continuity at the junction(maybe with a single piece of spline).
                                            loft issue - Fredio.skp
                                            • 22
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 65
                                            • 66
                                            • 24 / 66
