    1.3k Posts 300 Posters 3.3m Views 298 Watching
    • N
      notareal
      Thank you! ☀
      • C
        chloesdad
        Just wanted to add my thanks to you, Fredo for your generosity and talent.
        • FletchF
          Fletch
          Fredo, with you+SketchUp it eliminates need for almost any other modeling software. 😄
          (except for Sculptris... but I believe Whaat will have that covered in a few days/weeks/months.)
          Fletch
            rattusNOR
            Great work. Thank you Fredo !
            • B
              bowlr
              Thanks for the plugins, howver, after I copied the files to plugins folder, I get this error msg from SU
              "Error Loading File ZLoader__Curviloft.rb
              no such file to load -- LibFredo6.rb"
                bowlr, please go back and read the first post in the thread. Especially this:
                IMPORTANT: Requires to download LibFredo6 3.6 or higher if not already installed.
                • mitcorbM
                  mitcorb
                  Quote:"Also, for me, it is better if users can move to latest versions because it is easier to support."
                  Fredo endquote
                  I agree in principle on this statement. However, I must consider more than just upgrading to SU8. My hardware is going beyond outdated, and the logistics of migrating what I have accumulated is not trivial for me. 😄
                    I think Fredo was referring to having users move to the latest versions of his tools.
                    • mitcorbM
                      mitcorb
                      Ok, I missed the subtle distinction there.
                        Or I might have. that's just the way I read his comment, though.
                        • mitcorbM
                          mitcorb
                          That's the problem with language, especially across cultures, and so forth. We should just switch to mental telepathy and cut out the stumbling blocks of spelling, grammar, semantics and time to type. 😆
                            I knew you were going to type that. 😄 😆
                            • B
                              bowlr
                              Thanks for pointing this out, much appreciated
                              • fredo6F
                                Fredo endquote
                                As Dave relevantly mentioned. I was talking about my Plugins. If you use the latest version of LibFredo6 and of the scripts, it is easier for me to reproduce possible bugs and issues.
                                For SU, I try as much as possible to have them working with most SU versions (most work in SU 6 and even SU5).
                                • P
                                  Pherim
                                  I just successfully used Loft along Path for the first time! (That means I used it for the first time and it worked immediately, not that I have tried it several times without success)
                                  It is simply awesome. This has to be one of the best plugins ever!
                                    make.GQ.china
                                    Great! A useful plug-in
                                    • jason_marantoJ
                                      jason_maranto
                                      Hey Fredo, I have a file here with some geometry that gave me a hard time -- and I also have some examples of how I got it to work to a tolerable level but certainly not what I had envisioned.
                                      I'm sure user error was responsible to a degree but I though I'd share it with you if it helps debug at all.
                                      Best,
                                      Jason.
                                      loft issue.skp
                                      • fredo6F
                                        Best,
                                        Jason.
                                        Jason,
                                        Thanks. This is a good example which shows some limitations of Curviloft (and it's not your errors at all!).
                                        You probably have to do it in 2 parts, as you did. First part should be with the option 'Line junction' and second part with Cubic Bezier, but you should simply skip the last profile before the rear face of the hull.
                                        Alternatively, you can take some inspiration of what it could give with the two other methods: Skinning and Loft along Path.
                                        In any case, I would suggest that you redraw the long profile to show more continuity at the junction(maybe with a single piece of spline).
                                        loft issue - Fredio.skp
                                        • jason_marantoJ
                                          jason_maranto
                                          Thank-you again... that was very helpful and led me in a different direction that worked much better.
                                          I have another file for you -- I suspect this is asking for too much 😉
                                          Best,
                                          Jason.
                                          Interesting_loft.skp
                                          • fredo6F
                                            Jason,
                                            This is definitely too much for Curviloft. The only way to achieve it on this kind of model is to draw intermediate profiles and use Skinning.
                                            Indeed, you have to figure out how these intermediate profiles should be. But anyway, there are so many solutions to skin your shape that any program would need some guidance.
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 65
                                            • 66
                                            • 21 / 66
