    Naval Cutter "Alert" 1777
    78 Posts 32 Posters 45.1k Views 32 Watching
    • Bryan KB Offline
      Has someone seen my jaw? I left it on the floor somewhere.... ๐Ÿ˜ฎ
        Yeah. They were in the basement. Here you are:
        http://wichita.kumc.edu/support/lab/images/lower_jaw.jpg
        • axeonaliasA Offline
          axeonalias
          Well its time for her to officially get wet, the sails have been fitted in game and shes good to go,still need to add the sail texture and the footropes etc to the spars,but the worst of its over,the bowsprit being offset slightly to her port makes setting the Jib tricky but not impossible,the Staysail is centred as its Line comes off the stem head ( BONUS! )
          Ive set the sails in game in a way so that you can choose your own sail setup,The main squaresail and the T`gallant share a File while all the rest are induvidual.
          http://farm6.static.flickr.com/5205/5329964913_357c6f0b9f_b.jpg
          http://farm6.static.flickr.com/5124/5329998825_a4027fbd12_b.jpg
          https://sketchfab.com/Axeonalias
            Some slight wrinkling of the sails would really sell the whole set-up (wow, the first critique, I guess)
            Exquisite job, thanks for sharing! ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘
            ๐Ÿ˜‰
              SketchUpNoobie
              Congratulations! ๐Ÿ˜
              Truly amazing. ๐Ÿ˜ฎ One question though, is this a shot of the ship in-game or a rendering? ๐Ÿ˜ณ Sorry, I'm not very good at distinguishing these kind of things.
              SketchUpNoobie: the complete noob in all things SketchUp.
              • Bryan KB Offline
                ๐Ÿคฃ
                  Pherim
                  Wow this is amazing. The only thing is the sails need a real texture, then it would be perfect!
                    rollin45
                    Work which can only be aspired to by regular folks like me, you are an inspiration!!
                    ok,, back to work for me.. ๐Ÿ˜„
                    Wishing you continued success in your efforts.
                    rollin'
                      Crazy Eyes
                      Hi Marius,
                      Its been a long time since Ive been on here, and whos model do I see but yours.
                      I see that your modelling is getting even better. I love the way you set the scenes as you go along.
                      I always told you you were good! ๐Ÿ˜‰
                      We'll have to catch up some time.
                      Some people are lovers, some are fighters, if you love to fight, fight for love!
                      • Bryan KB Offline
                        (well that made no senses. remind me not to post after I've been to the pub)
                        This is what I meant to say:
                        Love the formation composition. Wow.
                          Excellent drawings. You've done a marvelous job on these boats. Looks like a lot of detail.
                          I did notice two things, though. Neither boat has frames or ribs which must be installed prior to planking since they are what give the hull her shape. And the jib stay can't go through the tops'l.
                          The t'gallant seems quite large to me. I don't know that I've ever noticed a rig where the t'gallant is larger than the tops'l. Usually the higher up the sail, the smaller they are.
                          You mentioned in the game that the sails can be set as desired. Can that long bow sprit be reefed as well?
                          Keep up the good work.
                          Edited to add: While looking at something else, I came across this image of a model of Alert. The foot of her tops'l is cut to clear the forward standing rigging and it does look like her t'gallant is larger than the tops'l. You can see her frames through the hole in the side of the hull.
                          http://www.craftsmanshipmuseum.com/images/ColeAlert21.jpg
                          There's an interesting article about the model's construction by Mr. Cole, the builder.
                            cadmunkey
                            Superb model and I've really enjoyed following your thread. It must be sweet to play with your model in a game too!
                              sawhack
                              hi axionalias,
                              how'd you make those hull plating? I'm doing lusitania ship hull and i want its hull appears to it is in the actual Lusitania, but i don't have any plan of its hull plating, how did you done that one i'm really impressed of your work, what plugin you use to do that hull plating?
                              saw
                              • spenceS Offline
                                spence
                                Wow ๐Ÿ˜ฒ that is some quality work, nice job. I loved viewing the build process.
                                Spence
                                  axeonalias
                                  Hi Saw,
                                  I did not use any plugins for the hull,Its just texturing etc. nothing fancy,A hip like the Lusitania`s hull would be tricky and require a Texture made for it.
                                  Dave as im sure you are aware that this is a game model and in reality the Ribs are not visable,I have modeled The full ribs on ships like these before but it is alot of work for something that will later be removed.
                                  About the sails I am also aware of it,the pictures shown are incorrect,its abit tricky to make cloth fold around a line in a game as you will also notice when she is on a close haul her main square intersects the shrouds and on a run the Gaff intersects the Backstays as well,I have found a way to control this in game but still needs tweaking. Thanks
                                    axeonalias
                                    Its been a wile since ive done anything on her,but its time to finnish her up.
                                    Sail Textures have been made and added on, this is a tiresome task that involves modeling the ropes and all the details on each sail,then Baking the texture,then fitting the texture to the sail mesh.
                                    Im happy with the way it turned out,all Dirty and old looking is my style.
                                    http://farm6.static.flickr.com/5059/5477038149_0a94deded5_b.jpg
                                    http://farm6.static.flickr.com/5257/5477038215_9b33e14913_b.jpg
                                    http://farm6.static.flickr.com/5213/5477636852_9a6f7a036f_b.jpg
                                    • KrisidiousK Offline
                                      Krisidious
                                      bravo... what an incredible journey this model has been. thanks for taking the time to cut the development shots and render them... the process of watching it come to life was an experience aside from the wonderful model itself.
                                      where do we get this game?
                                      By: Kristoff Rand
                                        axeonalias
                                        Thanks Krisidious, She still has some work before she is finnished, Baking will be the last and most rewarding step.
                                        The Game can be found here, She will be available for both Virtual sailor 7 and Vehicle simulator ( More for Vehicle sim as it is has the latest engine and looks way better )
                                        Quality Simulations - great simulations for flight, sailing, robots, rockets and vehicles.
                                        Quality Simulations produces high quality simulation programs, including: Vehicle Simulator, Micro Flight, Virtual Sailor, Rocket Simulator, Robot Simulator, Fire Flight.
                                        (www.hangsim.com)
                                          Pherim
                                          Awesome! Don't know what else to say. ๐Ÿ‘
                                            Krisidious
                                            that is a really kool simulator... the water effects are amazing. can you put land and buildings in that simulator? after seeing this I'm afraid you're going to have to make a movie and show us the Alert in action.
                                            By: Kristoff Rand
                                            • 3 / 4
