    [Plugin] UV Toolkit
    377 Posts 86 Posters 311.4k Views 86 Watching
      Just let me know when you need a beta forum!
      πŸ˜‰
      • erikBE Offline
        erikB
        TT this ruby is amazing !! πŸ‘
        Will be very usefull.
        erikB
          Ben Ritter
          Thank you so much Thomas.
          • N Offline
            nektares
            Thanks for this one ThomThom it makes alot easier several uvmapping situations! this is great! Thanks again!
            uvtest
            • shuraS Offline
              shura
              Yes very useful indeed, thank you Thomas!
              The Remember/Restore function is very innovative too. I tried to make a pillow but it didn't work (back). Maybe because I also edited by using Move tool on single vertices?
              However, with only Smoove it works well (front).
                It didn't restore properly after using Move, but Smoove worked fine?
                How how odd... I really don't know why that would be. I'll try and see if I can reproduce it.
                • shuraS Offline
                  shura
                  I've reproduced the same process with a less complex geometry and it seems to work well (!).
                  When it did not work before, I have fiddled a lot with the vertices - or maybe the memory got lost when saving the file?
                    If you erase/recreate geometry you will loose mapping data.
                    • shuraS Offline
                      shura
                      Ah, that sounds plausible. Not sure what I did wrong, but I guess must have been something like that.
                      thank you Thomas
                      • Alan FraserA Offline
                        Alan Fraser
                        Looks like a very useful script, Thom...but I'm having problems loading the V2. The ruby is asking for core.rb in TT_Lib2. Is this different from the one in TT_UV_Toolkit; and if so, where is the Lib2 folder hanging out? Did that install as part of an earlier offering?
                        3D Figures
                          Requirements
                          * SketchUp 7 or newer - ( Other versions untested )
                          * [**TT_Lib2**](http://forums.sketchucation.com/viewtopic.php?f) (v2.4.0)
                          Yeah, it requires Thomthom's Menu
                            Alan Fraser
                            Thanks Rich...thought it would be something like that. Don't know how I missed that line.
                            3D Figures
                              Requirements
                              No - ThomThom's menu is not required. TT_Lib2 is. Two separate things. ThomThom's menu is just an optional plugin you install if you want to group all my plugins' menus under one main menu.
                                Sorry typo I meant to say Thomthom's Library.
                                Oh the shame!
                                  That'll be ten Hail Marys.
                                    Hi Thom,
                                    Again, arches...
                                    (I could not resist - what a brilliant plugin!)
                                    πŸ‘ πŸ‘ πŸ‘
                                    Here is an arch I made in this way:
                                      That's pretty cool
                                        Nice one.
                                        I have an update coming soon, 2.2. It allows you to map a set of quad-faces, copy the mapping to the UV clipboard and when you then select a set of other quadfaces and paste they are randomly applied UV mapping from the clipboard set.
                                        Makes it easy to apply a set of variations. Tried it on a geometree from FormFonts:
                                        Set of five UV mapping copied randomly to the quad-face leaves.
                                        One can make quite efficient mapping if you use sprite techniques - one material, with a texture containing all the variations.
                                          That will be interesting. Can hardly wait!
                                          πŸ˜„
                                            Can you explain more about 'sprite technique'? Never heard of it but I'm thinking it's a texture FontSync a range of similar hues?
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 18
                                            • 19
                                            • 12 / 19
