    A Welcome Message to New SketchUcation Members
    1.4k Posts 667 Posters 652.0k Views 667 Watching
      Hi Andrew,
      Welcome! One word of advice....run!
        Bencito2
        Hello My Name is Benjamin Ferreira.
        Thank You for the generous resources on this site.
          Welcome Ben, glad to have you here ๐Ÿ‘
            joycebmartz
            hello...
            This is my first day in SketchUcation. I've been using the basic tools of sketchup but would like to learn it more in depth ...especially the plugins.
            Thnks
              Hi Joyce and welcome! Look around in the plugins forum!
              ๐Ÿ˜„
                Monty
                Just joined, looking forward to learning more about SketchUp!
                I guess I'll just thank everyone in advance! ๐Ÿ˜„
                -Monty
                  Hi Jeff and welcome! โ˜€
                    blondeambition
                    Hi All,
                    ...and enormous thanks for all of your help and information! I discovered SU a year ago, while looking for an alternative to my old student version of AutoCAD (for interior design). I've been giddy with delight ever since! I was successfully using the Pro 7 version until a few days ago, when I upgraded to the new Pro 8, and am now having issues with Push/Pull not functioning correctly. (It seems to work for a few operations, and then starts to just move the faces)
                    I've read that it could be related to my mouse (Logitech LX 3 optical) and wonder if anyone here has encountered the same issue, and hopefully can offer some advice? I unfortunately uninstalled the older program, and am desperate to get "up and running" again. I'm having SU withdrawal symtoms!!! ๐Ÿ˜ข Any suggestions would be most appreciated!
                    I'm excited to be part of this forum, and looking forward to learning more.
                    -BarbE
                      Hi BarbE (and welcome),
                      Maybe it's your graphics card/driver. Ty to disable hardware acceleration under Window > Preferences > OpenGL settings. If it "seems" to help, first thing should be to update your video driver.
                      What video card do you have by the way?
                        blondeambition
                        Thanks for the welcome and the suggestion. I did try that earlier as a solution, but it didn't work. My Graphics card (is that the same as the Video card?...please forgive me if that's a dumb question!) is the NVIDIA GEFORCE 9800M GS 512MB.
                        Fortunately, I did a System Restore, and have my Pro 7 Version back. I plan to reinstall the 8 version at a later time.
                        Thanks again for your welcome and prompt response. Also Happy New Year!
                        -BarbE
                          Well, openGL and graphic (or video) card issue was just my first guess. Yet you could still try a driver update. If it used to work with SU 7 and now with SU 8 it has issues, I am still suspicious (the card itself seems to be okay).
                          I also have a Logitech mouse but I did not install its driver just using it as a plug and play mouse and it works flawlessly.
                          Anyway, you can install and keep both SU versions at the same time. I have all since version 6 and can even run them together.
                            rlharv2
                            Thanks for the welcome. My name is Rick and I am new to SU and will be learning to use it for woodworking as a hobbyist. Thanks
                              JicJac
                              Happy and prosperous New Year to all you sketchy characters.
                              I'm a technical illustrator / patent draftsman. New to SketchUp.
                              I kicked around in Second Life for several years. I learned a lot about building in 3D and textures there.
                              Here is one of my first stabs at SketchUp.
                              http://i1185.photobucket.com/albums/z341/JicJac/Dungeonrailandgear.jpg
                              It's a scene from an informal story myself and two of my brothers are writing - just for the fun of it.
                              My goal is to become proficient with SketchUp this year and incorporate it into my day-to-day production stream.
                              Thanks in advance for the warm welcome,
                              JicJac
                                Welcome to SCF. That's a big cog you got!
                                  JicJac
                                  When I was into SecondLife, I created many SteamPunk Victorian environments. Scale was almost always out of proportion - intentionally. Dealing with fantasy worlds provides license to mix and match contemporary with rustic (Jules Verne-esque). It's fun and nonrestrictive. Not sure where SketchUp will take me. There seems to be plenty of competent architectural drafters out there. I suppose my creations will run from contemporary mechanical to fanciful SteamPunk Victorian and a few artistic pieces.
                                  Thanks for the comment,
                                  JJ
                                    Stylus_PT
                                    Olรก amigos!
                                    My name is Manu, I'm an architect and I'm from Portugal.
                                    I use Sketchup since it was a @last software, I've started to use it as a volume sketch/study tool at arch school, than I've begun to understand the hidden capabilities of sketchup and ended up using it for the hole architecting process except licensing, witch use "good" old autocad from exported sections.
                                    As a work tool I need it to be fast, and sketchup is the fastest model maker I've tried until we start bending the geometry in more than one axle, as soon as we do it workflow just drops to the ground.
                                    With this in mind I think I'm limiting my design creativity just to get things done at scheduled.
                                    I have been following this forum unregistered for quite a while, but know I realy need your help to search and understand some plugins witch I think will keep me stick with sketchup.
                                    My thanks since now.
                                      Hi Manu,
                                      Welcome to SCF!
                                      You'll definitely get good advice here. And you'll get help with finding solutions quickly. Get posting ๐Ÿ‘
                                      We also have a Portuguese forum that you can access via your User Control Panel. There's a tab there named User Groups which allows you to access the other languages etc.
                                      • doppelD Offline
                                        doppel
                                        hi guys!
                                        congrats for this friendly place!
                                          @doppel said:
                                          hi guys!
                                          Ha! If only you could see Rich when he is paying for the rounds in the pub!
                                          ๐Ÿ˜ฎ
                                          (And if you saw how many people I've banned for the last couple of days!) ๐Ÿ‘ฟ
                                          This is just since Christmas - so we are not necessarily that friendly... ๐Ÿ˜’
                                            aegyr
                                            Hello,
                                            I am working on an ergonomic ultralight aircraft cabin and I am testing ideas with Sketchup.
                                            I am new to 3D software and have limited drawing capacity (inference helps a lot !).
                                            I am in the process of getting a Phlatprinter III to make actual physical mockup.
                                            Cheers,
                                            Laurent
                                            • 40
                                            • 41
                                            • 42
                                            • 43
                                            • 44
                                            • 72
                                            • 73
                                            • 42 / 73
