    Human face-trials,tutorial..challenge?!
    Scheduled Pinned Locked Moved Organic Modelling
    68 Posts 14 Posters 47.7k Views 14 Watching
      More suited to Blender. Triangles are the enemy of organic modelling. But definitely deserves a go! The video is great 👍
      As an extra bit of info here's a neat little tut showing how to make a skull in Blender
      http://cg.tutsplus.com/tutorials/blender/sculpt-model-and-texture-a-low-poly-skull-in-blender/
      It has some interesting techniques that might get the juices flowing
      • soloS Offline
        Eli, you may want to wait for SDS2 and use the sculpting tools as well as face selected division options where you can divide only the areas you need to sculpt, keeping polys under control. SDS2 can also sculpt in symmetry so making things easier.
        • mitcorbM Offline
          mitcorb
          Here is an image of work in progress.
          About the only thing in common is the fact that I used a Sketchup UV sphere as a starting point.
          This is all in the interest of learning.
          Scale? Forget it. All done by eye-- which this model lacks.
          • dereiD Offline
            derei
            Any idea when it will be available ? 💚 🎉
            • mitcorbM Offline
              mitcorb
              I saw in another thread that it would be available sometime in first quarter of 2011?
              • ely862meE Offline
                ely862me
                Right now i m in the mood for modeling this(i have no doubt that sds2 will rock on).
                It will only be the face and i m not worried for the polycount.
                Nice one mitcorb, i hope i will be able to give mine a nice feminine face 😄.
                Cheers!
                Elisei (sketchupper)
                Come and See EliseiDesign
                • mitcorbM Offline
                  mitcorb
                  Well, it appears already to have the feminine proportions well established.
                  • soloS Offline
                    Proxy progress, 1/2 face first:
                    Join two halves, run SDS2 with 1 iriteration in order to smooth mesh, then select face only and run 1 more irriteration for dividing polys in order to get model ready for sculpting.
                    • soloS Offline
                      A quick idea of the sculpting progress.
                      (original .gif removed as it was slow and boring, used a timelapse instead, more happens and faster, however if you wanna see it it's here: http://dl.dropbox.com/u/1129899/sculpting.gif )
                      http://dl.dropbox.com/u/1129899/timelapse sculpt.gif
                      • soloS Offline
                        More selective subdivision in order to get more sculpting detail.
                        • ely862meE Offline
                          ely862me
                          Nice,it will be a very useful tool.
                          Eyelids ..
                            I withdraw my comment on triangles making the human head difficult. That is a masterclass in SketchUp! Well done Eli 👍
                            • jamalitoJ Offline
                              jamalito
                              http://dl.dropbox.com/u/1129899/sculpting progress.gif
                              your tool look like a z Brush
                              Albert Einstein:
                              ((I am enough of an artist to draw freely upon my imagination. Imagination is more important than knowledge. Knowledge is limited. Imagination encircles the world.))
                              • jamalitoJ Offline
                                jamalito
                                great Topic Ely all threads were talking about architecture, few of the subjects talking about Human
                                Albert Einstein:
                                • soloS Offline
                                  Eli, great eyelids so far, I will use glasses for now until I get around to playing more...oh the mouth also is missing. 😉
                                  I stole the hair from a previous model I did a few years ago, used FFD to shape to this head.
                                  Cartoon faces are so much quicker and easier.
                                  • mitcorbM Offline
                                    mitcorb
                                    Great work Solo. I was watching your progress in the previous posts. The results are starting to look like a self portrait, at least when compared to your avatar image. SDS seems to have all of the elements of Sculpt Tools by -BTM and then some. I notice a red line projecting normal out of the circle of influence, or is that my imagination? Because it appears to lengthen as if reflecting a dynamically changing parameter?
                                    • soloS Offline
                                      mitcorb, you are correct, the arrow is intensity and the circle is size of brush very easy to work with as you have TAB buttons to select mode, up and down keys for strength and direction and left and right for sizing the brush. So work-flow is pretty smooth once you get used to the keys. What's also great is that you can select mesh to be subdivided so no need in having whole model tight meshed but the areas you need to add detail and then you can select those areas again and reduce the complexity using the poly reduce tools, there are other tools that I'm still getting to play with and learn, like vertice selection and editing tools.
                                      • soloS Offline
                                        Update...
                                        Details to ears, more defined and muscular torso, mouth detail.
                                        I used sculpt, divide and reduce. The thing is one can either overdo or under do so easily, it's actually hard to stop as it never looks finished or right.
                                        • BoxB Offline
                                          Wonderful and very useful work, but I'm not quite understanding which tools you are using?
                                          I have achieved similar,nowhere near as good, using Tigs extrusion tools, but it required a multitude of beziers and a lot of planning.
                                          • soloS Offline
                                            Ben, I'm using SDS2 which is in Alpha testing at moment, Dale lets me show and tell, so do not worry about not knowing the tools I'm using yet, once it becomes available I should be versed well enough to help y'all out the gates. This is a new process for me also as I used to create proxy's and divide, now I start with a basic proxy, divide, sculpt, divide, reduce, and so on. This is my first sculpting attempt on this scale, I dabbled a week or so ago with the scooter.
                                            • 1 / 4
