    Help with this 3d wall Panel
    45 Posts 12 Posters 6.9k Views 12 Watching
    • kaluK
      kalu
      Eli and his foloowers,
      I have PM messages from Eli says that nothing is for free, so you can figure out, just translate that for me. I do not respond all the messages in the original post so some of his responses are there all my are almost in PM messages.I will not apologize to him or any others that thinking in this way. I ask many times in PM messages to explain better and he refuse to do more explanation. So I move in this matter, forgot eli and what ever guy that follow and I will continue looking for a method to create that wall block. I am kind of tired to see who say he say, just put your method or questions or comments that are value. I thank you the people to take their time and effort to create a simple method for this post.
      I work on Vray and PS maybe I can get the effect in the render with displacement instead the 3D model.
      Kalu.
      PS: For all that see the "Free cookie" thing, If I want that, I am a member of "Formfonts" for years and I can ask them to create the model for me, but I rather learn.
      THE ONLY DIFFERENCE BETWEEN FICTION AND REALITY IS WHEN FICTION HAS TO BE CREDIBLE
      • Mike LuceyM
        Mike Lucey
        Kalu,
        You are again casting slurs in your first sentence, 'Eli and his foloowers'! I presume you meant to write 'followers'!
        I and the others that have commented on your attitude ARE NOT followers of Eli. As for myself, it is my job to maintain reasonable standards here on SketchUcation. I intend to do this at all times.
        As for your last sentence, 'but I rather learn'! It looks to me that you are not interested in learning good manners and when to admit you have made a mistake and offer an apology. Unless you do so shortly I regretfully will ban you from SCF.
        Mike
        • kaluK
          kalu
          This is an update in Vray, PH. not quite there...
          http://i637.photobucket.com/albums/uu100/artechedesign/basic_displac.jpg
          I use displacement (2) and I invert the Image in PH and use levels to adapt the contrast to create the bump map.
          • kaluK
            kalu
            @ely862me said:
            Let see what is the problem ,where u get stuck.
            Thank you for your time and help , I apology for my comments you are great.
              Can we consider this unfortunate incident over? Kalu if you've a model already made but not what you need could you upload to see where your problem lies?
              It will help to see your exact failing and we can continue from there?
              Rich
              • MarianM
                Marian
                On a less serious note, here's my superfast super simple non accurate attempt which may be easier to understand for a beginner, but you need the Subdivide and Smooth plugin.
                http://fc08.deviantart.net/fs70/f/2010/358/c/8/tutorial_simple_wall_tile_by_marian87-d35kshm.jpg
                • kaluK
                  kalu
                  Thank you Marian for the quick Tutorial I will try that. I attach the Vray displacement model that I use now.
                  Thanks for your quick and great tutorial.
                  PS. What is the SDS plugin for softness?
                  Vray 1.48.89 sketchup 8
                  • N
                    notareal
                    File Not Found
                    (www.smustard.com)
                    • kaluK
                      kalu
                      @notareal said:
                      File Not Found
                      (www.smustard.com)
                      Thank you Notareal, I already have that, I just looking in SCF for that Plugin thinking that was some new. Really appreciate your comments.
                      kalu.
                      • MarianM
                        Marian
                        You're welcome.
                        SDS(Subdivide and Smooth)- It does what it says in the name, subdivides the polygons, multiplying them and then applies smoothing. You can clearly see the effect of SDS in the last part of my tutorial.
                        It does cost $20 dollars but it's worth it, maybe not completely for this project but I guarantee you'll need it on future projects where organic modeling is requiered.
                        • soloS
                          Play with vertices and edges to define shape then subdivide as needed, group before subdividing as then you can use crease tool for corners and that will enable you to stack panels without gaps.
                          3d wall.skp
                            Ands43
                            How did you do that ely.
                            Imported jpeg, traced over the lines. grouped it??, then sub divide in sks is that this http://www.smustard.com/script/SubdivideAndSmooth
                            Looks good.
                            • 3 / 3
