    Help with this 3d wall Panel
    45 Posts 12 Posters 7.3k Views 12 Watching
    • kaluK
      kalu
      This is an update in Vray, PH. not quite there...
      http://i637.photobucket.com/albums/uu100/artechedesign/basic_displac.jpg
      I use displacement (2) and I invert the Image in PH and use levels to adapt the contrast to create the bump map.
      THE ONLY DIFFERENCE BETWEEN FICTION AND REALITY IS WHEN FICTION HAS TO BE CREDIBLE
      • kaluK
        kalu
        @ely862me said:
        Let see what is the problem ,where u get stuck.
        Thank you for your time and help , I apology for my comments you are great.
          Can we consider this unfortunate incident over? Kalu if you've a model already made but not what you need could you upload to see where your problem lies?
          It will help to see your exact failing and we can continue from there?
          Rich
          • MarianM
            Marian
            On a less serious note, here's my superfast super simple non accurate attempt which may be easier to understand for a beginner, but you need the Subdivide and Smooth plugin.
            http://fc08.deviantart.net/fs70/f/2010/358/c/8/tutorial_simple_wall_tile_by_marian87-d35kshm.jpg
            • kaluK
              kalu
              Thank you Marian for the quick Tutorial I will try that. I attach the Vray displacement model that I use now.
              Thanks for your quick and great tutorial.
              PS. What is the SDS plugin for softness?
              Vray 1.48.89 sketchup 8
              • N
                notareal
                File Not Found
                (www.smustard.com)
                • kaluK
                  kalu
                  @notareal said:
                  File Not Found
                  (www.smustard.com)
                  Thank you Notareal, I already have that, I just looking in SCF for that Plugin thinking that was some new. Really appreciate your comments.
                  kalu.
                  • MarianM
                    Marian
                    You're welcome.
                    SDS(Subdivide and Smooth)- It does what it says in the name, subdivides the polygons, multiplying them and then applies smoothing. You can clearly see the effect of SDS in the last part of my tutorial.
                    It does cost $20 dollars but it's worth it, maybe not completely for this project but I guarantee you'll need it on future projects where organic modeling is requiered.
                    • soloS
                      Play with vertices and edges to define shape then subdivide as needed, group before subdividing as then you can use crease tool for corners and that will enable you to stack panels without gaps.
                      3d wall.skp
                        Ands43
                        How did you do that ely.
                        Imported jpeg, traced over the lines. grouped it??, then sub divide in sks is that this http://www.smustard.com/script/SubdivideAndSmooth
                        Looks good.
                        • 3 / 3
