    Filetting and Bullnosing Edges
    25 Posts 8 Posters 5.3k Views 8 Watching
    • ely862meE
      ely862me
      My pleasure ...
      Elisei
      Elisei (sketchupper)
      Come and See EliseiDesign
      • ely862meE
        ely862me
        I ll try to compose a simple tutorial
        lets make the main body of an electric guitar :
        1:draw the main shape
        2:pull it up to achieve the body
        3:ad the extra lines (i selected the perimeter and copy paste it on blue axis nearby the up and down perimeter )
        4:remove the extra faces for a proper result
        5:run sds
        6:this is what sds made without those extra lines
        7:if u do need more sharpen corners add another round of extra lines(this time i just made an offset)
        8:this is the result for 7 after running the sds
        Pretty cool ha?!!(and i figured it all by myself) πŸ˜†
        cheers!!
        hope it helps
        Elisei
        electric quitar.skp
        • X
          xrok1
          hey! you can also do it this way and save about a third of the polys. plus you are sure that the front and back are flat. πŸ˜„cap.jpg
          • ely862meE
            ely862me
            yeah u can...just on flat areas
            • T
              Tekkybot
              @ely862me said:
              is quite simple..
              u first have to make the normal mesh but low poly
              then the lines u want to be sharpen add another round of lines near them
              man! i own this plugin! i thought subdivide and smooth was just a cool gimic that nobody actauly used how wrong i was. installing now β˜€
              • T
                TeamSDA
                Hi Elisei
                Your input has been quite liberating. We took your advice and built a low poly mesh from scratch then used the sds to smooth it out. We are not as quick as you appear to be, but your advice looks like it will open the door to a lot more creative freedom in sketch up. Below is the new Pod we built using your technique.
                TeamSDA
                p.s. Your technique of adding more lines to reduce the amount of smoothing on edges works great. πŸ‘
                p.p.s. We know that turning off hidden geometry in the view menu gets rid of all the mesh lines but there are still artifact lines showing up that we would like to get rid of, have you ever had this problem and if so do you have any ideas about how to fix it.
                JVC Pod.skp
                • ely862meE
                  ely862me
                  select the geometry right click and click on soften/smooth edges (check the soften coplanar too)
                  • bazB
                    baz
                    Hi eliesi,
                    I downloaded your guitar skp to try this out and it worked perfectly with your model but when I tried it with a different shape I got this...
                    Any idea what I'm doing wrong?
                    • ely862meE
                      ely862me
                      It looks like you have some internal faces which affects the final result.
                      Also keep in mind that u MUST make a low poly model(what u have there is more like the final model-the polycount will be enormous), then apply the subdivide.
                        Baz: are you trying to make a fillet on the edge? In which case you want to look into Fredo's RoundCorner plugin.
                        • bazB
                          baz
                          hi guys, thanks for replies, I must admit, after getting suv8, I havent reloaded this ruby. 'Round corners' does the trick when necessary.
                          Happy Christmas and a prosperous New Year, everyone.
                          Baz
                          • 2 / 2
