πŸ€‘ SketchPlus 1.3 | 44 Tools for $15 until June 20th Buy Now
[REQUEST] bitmap to mesh with materials
14 Posts 3 Posters 1.2k Views 3 Watching
    baldaman
    Please look at the image below, my english is too poor to explain clearly what I mean thanks to words.
    I was thinking that if thomthom's plugin "bitmap to mesh" can handle bitmaps the way it does, maybe what I am asking for could be possible.
    Thanks in advance.
      You might be in luck... I have been developing a set of Image manipulation 'jar' files. It would be quite possible take a Selected Image and extract each pixel from in turn with its RGB value and then make a dat file of it that SUP can process into squares equivalent to the image and new materials for each color...
      I see the dat file being like this... assuming a 6x6 image with RRGGRR colors on each line
      255,0,0 255,0,0 0,255,0 0,255,0 255,0,0 255,0,0
      Using lines=IO.readlines(datfile) it then works out how wide and high the pixel-image is and makes a grouped set of flat faces so its overall size matches the original Image. It then takes a line from the lines at a time and checks the color of that 'square' using cols=line.split(' '), col=cols[0] etc and col=col.split(',') etc etc.
      Assembling a [new] Material name using something like...
      r=col[0]; g=col[1]; b=col[2]
      name="Mat-"+r+'-'+g+'-'+b
      mats=model.materials
      if not mat=mats[name]
       mat=mats.add(name')
       mat.color.red=r.to_i
       mat.color.green=g.to_i
       mat.color.blue=b.to_i
      face.material=mat
      face.back_material=mat
      Here the first pixel material.name is "Mat-255-0-0", as that exists later any squares with that color use the existing one not making anew one...
      I'll think it through over the weekend... πŸ€“
        I can easily make Bitmap to Mesh do that. Just a minor change from what it does now.
          Over to you ThomThom... πŸ˜‰
            baldaman
            Dear ruby masters, thank you for your response.
            So it seems possible right?
            I allready imagine what a funny contest we could organise with this tool!!!
            πŸ˜„ β˜€ β˜€ πŸ˜„
            Ok let's prepare some cookies...
              baldaman
              Here is an exemple of what I did for a custom sunscreens system somwhere near equator. The goal is to stop every sun rays while in the same time according visual porosity toward sky. The visual porosity changes according the position of the observer.
              I used 3ds max and polyboost plugin's "bitmap select" feature. After that, back to Sketchup and "components onto face collections".
              The components layout what painted in photoshop with brushes in order to obtain gradations.
              I am also thinking of using this method for faΓ§ade panels variations.
              My goal is to be able to do the whole process inside Sketchup.
              PS: My english lessons are so far away: sorry for my frenglish
              God bless proxies
                baldaman
                View from below
                  This is the season to be busy. I didn't manage to finish that update this weekend. I'll come. πŸ˜‰
                    baldaman
                    Ok thanks Thom, please take all the time you need.
                    No hurry πŸ˜„
                      http://forums.sketchucation.com/download/file.php?id=60572&mode=view
                      http://forums.sketchucation.com/viewtopic.php?f=323&t=31339#p275772
                        baldaman
                        😍 😍 😍 β˜€ β˜€ β˜€
                        You are the don Thom, thank you so much!!!
                        I am at the office now, not time to check this out
                        πŸŽ‰ πŸŽ‰ πŸŽ‰
                          Post back some samples of what you use it for. I'm very curious.
                            baldaman
                            Works perfectly. β˜€
                            We need to be carefull with the number of colours of the bitmap!
                            After a few tests,
                            best settings are:
                            . indexed colors in photoshop or another image editor (in Photoshop you can choose the number, in the exemple below we have 12 colors)
                            . save as bmp (8bit, no compression).
                            First exemple is specialy dedicated to Thomthom πŸ˜„
                              baldaman
                              More serious use exemples to come asap. πŸ˜‰
