    [Plugin] ImageTrimmer
    364 Posts 58 Posters 337.7k Views 58 Watching
    • srxS
      srx
      That is great for png trees shadows. Thank you.
      www.saurus.rs
        This is great! It's been asked for for such a long time.
        How about an option to simply the edges - make the resulting silhouette simpler?
        You can use the Douglas-Peucker algorithm port I used in Edge Tools:
        http://forums.sketchucation.com/viewtopic.php?f=323&t=24593#p210736
          Thanks for the tip... At the moment it slavishly follows every pixel!
          This is only v1.0 so I'm sure there are lots of improvements possible.
          My use of using one function specific small Java .jar executables reading 'ini' files to pass arguments etc seems to work better than I expected... So far in alphabetical order, there's...
          Bumpmapper.jar and BumpmapperInverted.jar to make gray-scale bumpmap pngs from imagefiles.
          EdgeDetector.jar that finds a given png's edges and makes the 'edged' version and a .dat file = 01's used by SUp.
          Gifxtractor.jar that makes pngs of all frames in a given animated gif file.
          Thumbnailer.jar that makes a 64x64 thumbnail of an image.
          ThumbnailerRGB.jar that makes a 64x64 thumbnail of a color from its RGB values.
          UnZipDirectory.jar that uncompresses zip files OR skm files.
          ZipDirectory.jar that compresses zip files OR skm files in a given folder.
          Any ideas for other similar 'jar' tools always welcomed - I only taught myself Java in the last week or two, specifically to do image manipulation parallel to Ruby, but I'm sure there are other possible uses too... πŸ€“
            You've made a great deal of tools there. Too bad my apartment is such a mess still - don't get much time to look at all these new goodies.
            • shuraS
              shura
              With that .jar business I resign right away. just want to put another +1 here: simplifying edges? Oh yes please! (drooling)
                I had dallied with some outline simplification ideas... but brought v1.0 to market without that functionality as my brain hurt.
                I'll think about it again - e.g. even a simple square hole 32x32 pixels currently has 128 edges when 4 would do!!
                A square hole on the diagonal has 256 edges when 4 would do!!!
                I'm sure I can clone some ideas from others' code πŸ˜‰ πŸ˜„
                  With the simplification algorithm I linked to, then those 128 edges should become 4. You feed it a set of points that form a curve (for separate each curve into sets and you get a simplified set.
                  • CadFatherC
                    CadFather
                    speechlessly amazing!
                      Here's v1.1 http://forums.sketchucation.com/viewtopic.php?p=294815#p294815
                      It's got an 'outline simplifier' option added.
                      This is also available a separate tool to simplify the outlines of existing ImageTrimmed components.
                      See the notes for details...
                      [Thanks to ThomThom and Douglas-Peucker fro the simplification algorithm ideas...]
                        @cadfather said:
                        not sure what happened but when run, the script opened edge 'detector.jar' file and there it stayed..
                        it opened with winrar so will check this out
                        You need to have Java enabled on you computer - it usually is...
                        Did you extract most files into SKMtools subfolder as the instructions...
                        The script doesn't open 'EdgeDector.jar' - rather it should 'execute' it as it's a very small app that does just one thing ?
                        What OS system are you using ? XP ??
                        What version of IE do you have ?
                        What version of SUp ? I guess NOT 9.1 πŸ˜’
                        • CadFatherC
                          CadFather
                          EDIT: yes if winrar (i guess any other zipping app as well) is set to open jar files too - trimmer will run winrar -- uncheking the file association makes trimmer work fine
                          • CadFatherC
                            CadFather
                            well TIG, with the likes of you, it feels like SU 10.2! πŸ˜†
                            • T
                              tomasz
                              Thanks for the interesting plugin and the inspiration TIG!
                              Two weeks is not that much. I will give it a try!
                                CADfather
                                I have looked at your '.jar' issue... I can reproduce it! IF I let a 'zip/unzip' application like AlZip or WinRar 'poach' the '.jar' file-type as one that it will open. If so then when Ruby tries to 'open' a '.jar' file instead of it 'executing' in Java [like it should], it 'opens' in the decompression application...
                                The solution = look at your WinRar settings and ensure '.jar' is NOT one of its file-types for opening...
                                • CadFatherC
                                  CadFather
                                  thanks TIG, that's exactly what i did - (perhaps wasn't too clear in the edit)
                                  one specu-question: could you, adjust the sampling rate/area of the script? suppose you didn't want so much precision, it could perhaps speed up the trimming process - having said that, the simplifier is well integrated
                                  once the trim is achieved
                                    Sorry - didn't see the 'edit' ! πŸ˜’
                                    It first has to 'get' all of the edges of the solid/transparent areas - it's 'easier' to draw all of the edges as boundaries to these pixels - this is the most complex outline - a Factor 2 simplification will often improve the steppiness of these edges, BUT it can trim small solid areas or leave small transparent areas... Most of the time in the initial processing is finding which edge bits get faces or 'holes' and of course therefore which are part of which 'loops'... The 'simplifier' works on the face perimeter loops once they are made - it's much easier than trying to decide which edges could be the loops initially... You will have seen that the simplifier at Factor 2 reprocesses the faces' loops quite quickly... I can see how to easily recast the code to allow simplification before processing πŸ˜•
                                    • CadFatherC
                                      CadFather
                                      i see.. still a pretty amazing feat.. in fact so are the images produced in the folder.. Thanks again
                                        The Image's original 'image' file, 'edged' .png and a .dat file [01s] are put into the temporary folder [it is removed IF it's empty] made inside the SKP model's folder. If you answer 'No' when asked if you want to remove temporary files you can open/use them. I didn't automate this deletion because you might want the Image's 'image' file and/or the 'edged' .png. The .dat file does go but it's just a load of 0s and 1s !!! If you leave one of the dialogs open you can always read/copy it before it 'goes' πŸ˜‰
                                        • CadFatherC
                                          CadFather
                                          very useful indeed.. πŸ˜„
                                          • soloS
                                            What am I doing wrong? I have a .png. I made it a component, selected it and then clicked on Image trimmer and get a warning 'Image trimmer: You selected an Image first.', so I exploded and tried again with same warning, I tried simplyfier and it works, but trimming does not, what am I doing wrong?
                                            • 18
                                            • 19
                                            • 1 / 19
