    [Plugin] Bitmap To Mesh
    264 Posts 75 Posters 530.7k Views 75 Watching
    • G
      Ghalko
      💭 What if you could make an image file that could encode for overhangs?
      Basically it would be a flat image with a curvy perimeter within the rectangle that when smooshed would make a rectangular-based object that would include overhangs, and potentially tunnels (A perimeter within a perimeter, matched with another across the map.) Also a different color perimeter or lack thereof would create sphere or bumpy boulder, or even a planet if your memory can handle it.
      So right now is is black and white for basic z-height. How much information could be encoded using rgb? Red values might indicate what pixels it lines up with, blue indicates order and green indicates height or distance.
      Using the perimeter as an encoding medium for the flattened surface for distance it must go for the final product.
      This was just a random idea I had a few minutes ago while thinking about this plugin, it is possible but the way might not be very straight-forward. The image format might have to be something more than a .bmp. Also a good thing that might come out of this is large scale compression potential. Also organic shapes...
      Bryan
      Arrrggghhh! Why won't it make a face!!! Stupid, no good piece of... Oh look! The line went to the wrong point. Whew... moving on. (My fights with sketchup.)
      • K
        keyston
        hey, excellent tool, similar to the terrain editor in vue but with your script you can work to a scale.
        2 questions;
        how do you map a texture to a non flat surface in su?
        I usually un soften/smooth edges and muck around with the eyedropper in the material toolbar which is a long process at the best of times, but with the hundreds/thousands of faces generated using this plugin thats not an option.
        I was also wondering if it would be possible to use a bitmap from an object in your scene to generate the mesh, say like you have texture mapped a cube for example, with 1 texture on all faces, you select the object, then generate mesh on all the mapped faces.Possible? too difficult? Just an idea from someone with no idea. 💭 👍 👎 ❓
        Thanks again for the plugin.
        • K
          keyston
          just found the answer to my first question, projected texture. much easier 😒
            It'd be challenging to make the mesh work between faces, but the biggest problem is that it would most likely create a mesh that is all too dense for SketchUp to handle.
            • jamalitoJ
              jamalito
              wow every good I like this plugin
              becouse I am used it in ornamentation
              thnx
              Albert Einstein:
              ((I am enough of an artist to draw freely upon my imagination. Imagination is more important than knowledge. Knowledge is limited. Imagination encircles the world.))
              • B
                Ben Ritter
                Thomas, I love it. I have the mesh made, but struggling to find the right image size to make the mesh workable. I've broken the image down into 6 parts and I have a mesh, but can't get a texture applied. SU crashes.
                I've been able to apply the texture when it's grouped, but the image gets applied rotated 180 deg.
                So, for anyone, is there a way to simplify the mesh first? Would that actually help in applying the projected texture?
                SU8.0.3117, File is 98mb
                  Matias Germán
                  It´s a great plugin. Thanks Thomas. 👍
                    If you need a simpker mesh, resample the bitmap you generated it from down. Less pixels - simpler mesh.
                    • B
                      Ben Ritter
                      I will try the resampling. Any idea why the image gets turned around?
                        Got a screenshot? I'm not sure if I understand what you describe.
                        • majidM
                          majid
                          Dear tomtom, I'ven;t tested your plugin yet, seems to be great and so many thanx, but as a suggestion to reduce faces and improvement, maybe you could add an option for merging co-planar faces
                          • B
                            Ben Ritter
                            Thomas, thanks for your help, I can't seem to recreate that scenario now, but here's what happens when I try to project the texture above it. I get bits and pieces onto the mesh.
                              You could run CleanUp afterwards.
                              • FletchF
                                Fletch
                                Ben, look at my example of roof tile above very closely - you will see that you should use a TINY .bmp... I mean TINY.
                                Then scale the mesh that is generated UP in SketchUp, then PROJECT your texture DOWN onto the face. Be sure the texture position is set to PROJECTED.
                                Remember that BLACK is the lowest point, and WHITE is the HIGHEST point on the final mesh... so make sure to create your displacement map appropriately... a sketch like that is not likely to give you the exact results you want... depending on what you want I guess.
                                Thom Thom, I used your plugin to helpme create this image... thanks again! 👍
                                It is KEY to use a very good displacement map and very small resolution.
                                Fletch
                                  Fletch - how did you do that?
                                  A plugin that inserts components at vertices?
                                    Fletch, that is way cool! It looks like an On/Off button but makes me think it's label could be changed by controlling which pins are up and which are down.
                                    • B
                                      Ben Ritter
                                      Fletch, thanks for the reminders. The bmp was a scanned in sketch that I tried. Perhaps not the best to use. Thank you anyway.
                                      • GaieusG
                                        Here is a bit of the workflow.
                                        http://twilightrender.com/phpBB3/viewtopic.php?f=26&t=2208
                                          The board requires you to be registered and logged in to view this forum.
                                          • GaieusG
                                            Ah yeah, that is a restricted area for license holders.
                                            Anyway, it's drop.rb. 😉
                                            • 13
                                            • 14
                                            • 6 / 14
