    [Plugin] BoolTools just released!
    84 Posts 38 Posters 74.7k Views 38 Watching
    • JClementsJ Offline
      JClements
      Wonderful script. Thank you.
      @rickw said:
      I use the same shortcut! Good thinking! ๐Ÿ˜„
      Me three. I adopted this key-combo from Xara which implemented a paste-in-place quite a while ago (their paste, ctrl-v, pastes in the center of the screen).
      • david_hD Offline
        david_h
        I am trying to do the Drill bit thing and when I try to do the difference tool it just hangs. I have set the no. of Facets for each at 24. What is the problem? I can't view the Tuts cuz I don't have 7 yet. I am using the drawhelix.rb and the follow me tool to create my helix. Is this a good way?
        D
        EDIT: I got it to work, but I had to simplify the model considerably. 12 facets for the helix and the cylinder. Looks Okay I guess. Could I have done it a different way? That is . . .If I ever need to draw a drill bit in a real design situation. ๐Ÿ’š20081229092101_1m44s.jpg
        • Gus RG Offline
          Gus R
          David,
          Here's the tutorial in Version 6.
          drill bit tutorial v6.skp
          I recommend using drawhelix13.rb for the helix and lines2tubes.rb for the tube. Follow me will distort the tube too much in this case -- even though it will still work.
          Your 12 segment drill bit looks pretty good. As far as SU hanging consider that it might take some time depending on your CPU capacity. It might take 5 minutes. In my case, certain complicated functions will lead to the appearance of SU locking up when in fact it hasn't. This will happen even when I'm rendering. Sometimes I have to let SU work and not touch a thing or move the mouse away from the SU screen otherwise it will cause SU to crash. Try it again with 24 segments only this time give it a good solid 5 minutes or more without doing any other computer tasks.
          Gus
          www.instagram.com/gusrobatto/
          www.facebook.com/gusrobatto
          • david_hD Offline
            david_h
            Thanks for the TUT. it was the DH13 rb that I did use. I think I have the L2Tube rb as well, although I didn't use that one.
            Thx,
            D
            • david_hD Offline
              david_h
              As per your Tut. Thanks much.
              David
                Click Draw
                I'm not sure why, but I still get some missing faces when I try to do a drill bit. I match the segments in the helix and the cylinder. I build it large so I can scale down....same result. Very frustrating. Could there be any issues with other rubies effecting the ones I use for this process? The gray hair just keeps coming as I keep trying to figure it out. HELPPPPPP!
                Frustrated, Jeff
                Have I mentioned how much of a laugh I get out of some of the Signatures on here!
                • Gus RG Offline
                  Gus R
                  Jeff,
                  I've had the same situation occur as well. So far it seems as though you have to try these at random at a larger scale. Anytime you get an intersetion that is around 1/16 inch or 1 mm it will corrupt the subtraction. At the same time, if you scale it too much it will corrupt the subtraction. I tried it once at 1,000,000X and the corruption was even worse.
                  So far my computer has survived the trip out the window and down 6 floors. It's been almost 7 years now. I have been tempted. ๐Ÿ˜ฎ
                  Gus
                  • W Offline
                    Whaat
                    @gus r said:
                    Jeff,
                    Gus
                    BoolTools uses the intersection method from the SketchUp API which is the exact same function as the 'intersect' context click function that can be accessed from the UI. Sometimes, the intersect method fails (likely due to precision errors). For complex operations (such as a helical subtraction, the chances of these precision errors are greater. If the intersection method fails to execute properly, you will get strange results with BoolTools.
                    ClickDraw: If you could post your SKP file, I can take a look just to make sure that your problems are not being caused by some other issue.
                    Dale
                    • plot-parisP Offline
                      plot-paris
                      using a modifier key to keep the difference-object is a great idea. so we will see that in the next version? (along with nested grouping support ๐Ÿ˜‰ )
                      ps: I use 'Ctrl + Shift + V' for 'Paste in place' as too. soon Google will integrate it as a default shortcut... ๐Ÿ˜„
                        sjtunba
                        why i can't see it
                        • X Offline
                          xrok1
                          just bought it ๐Ÿ˜„ awesome ,but +1 on this option.
                          โ€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.โ€
                          • N Offline
                            NewOne
                            @whaat said:
                            1. A request. When performing a Cut - it is sometimes desirable to KEEP the geometry that is acting as the edge for the cut. eg Trimming Steel Beams 1 and 2 with Wall 1.
                              Sometimes I'd like to keep Wall 1 after the operation.
                              Could this be built in - eg with an option dialog ??? Would be very handy.
                            I anticipated this request and tried hard to get this to work for this version but it was too buggy. My idea was that you could hold down the CNTL modifier key while selecting if you want to keep the cutting geometry. Hopefully, I can get it to work for the next version. There is a fairly easy workaround though:
                            1. Select the 'cutting' group and press CNTL+C to copy. You can actually select the group by hovering your mouse over the cutting group while you have the 'Difference' tool active.
                            2. Perform the cut with BoolTools
                            3. Choose 'paste-in-place' to get the cutting group back. (a shortcut-key would come in handy here...)
                            Hope this helps!
                            Can you make that just the intersection to be deleted when cutting? Just the part of steel beam/or wall that is common to be deleted ?In AutoCAD the substracted object is deleted. It lets behind a gap in the other one. This tool can be better ๐Ÿ˜„
                              Coronel
                              Great tutorial, thanks
                                blah238
                                Does this work in SketchUp 8?
                                  Yes, although for SU 8 Pro, with the introduction of Solid tools, it has become sort of obsolete.
                                  Yet for those with SU Free, it is still cheaper than buying Pro of course.
                                    tfdesign
                                    If you can get it to work that is. I couldn't get mine to work. ๐Ÿ˜ž
                                      This plugin or SU8?
                                        Or the solid tools?
                                        • W Offline
                                          Whaat
                                          BoolTools relies on the model.raytest method which is buggy in SU8. Therefore, I would not recommend using it with SU8 until that bug is fixed.
                                            tfdesign
                                            @thomthom said:
                                            This plugin or SU8?
                                            The former.
                                            • 3 / 5
