    Phantom intersection lines
    12 Posts 5 Posters 1.1k Views 5 Watching
    • mitcorbM Offline
      mitcorb
      In this case, in your model, it appears that edge is needed.
      I often draw new faces over "indentations" in a model rather than moving the vertices. And I have seen the phantom effect. I often select the phantom and delete if I don't need it, especially if it forms internal faces in a model.
        That may also be the case however without the model again... 😒
        • mitcorbM Offline
          mitcorb
          I just had a momentary power outage and lost login.
          Gaieus, are you asking in a roundabout way that hellnbak upload his model?
          My brain is a little fuzzy-- waiting for my morning coffee to kick in.
          Edit: and you may be contemplating an afternoon nap 💚
            Well, yes. he's had a bunch of topics already where a model would have made things much more clear.
            ATM I am already over nap time and preparing to go pubtown. 😉
              Is pubtown the English word for Pecs?
                Pardon me, I do not know what you are talking about. I generally drink mint tea (if available - if not, any other kind of alcoholic beverages)
                  Well, don't forget your sandals we you decide to go for a cup of tea!
                  @hellnbak
                  We'll leave this discussion alone now and I hope your mystery lines reveal their secret soon 😉
                  • hellnbakH Offline
                    hellnbak
                    In my noobie efforts to fix the problem I screwed up the model so badly it's hardly recognizable anymore 😳 Looks more like modern art now. I'm trying to recreate the problem. Will upload if I am successful. Thanks
                      To illustrate what I was describing above, have a look at these images (2d export of a model of mine). I knew I was going to have these issues so I made my roof 5 cms (~2") thick which is probably too much theoretically (should be about half) but who cares, it is not visible anyway. You will see that when zoomed out, the beams of the roof structure bleed through the 5 cm thick roof.
                      Read the description of each shot under the images.
                      From a distance, 1 pixel on screen is thicker than that 5 cms which is the thickness of the roof
                      In this shot, the farther part of the roof is shortened so the beams still bleed through but not on the closer part.
                      Here I am close enough so that those 5 cms are thicker than 1 pixel on screen.
                        Jim57
                        hellnbak—
                        WIthout seeing the geometry I can't say, but I just had success with a similar issue when someone posted the technique for making edges invisible without erasing them:
                        —Find the inner edge that's bleeding through
                        —Open the group or component that contains it
                        —Select the Eraser tool
                        —While holding down the shift key, click on the line that bleeds through
                        You still see any color or texture, but without the hard line that ends it, and the inner color does not bleed through.
                        Best,
                        Jim
