[Plugin Library] LibFredo6 - v14.5b - 24 May 24
There has been various talks about repositories. But no concrete results yet. Still high up there on our wish list.
And we have been talking about the visibility of the download links in the threads. Some authors have begun to add a Download button graphic by the link. I still have that on my to-do list.
@tonywilton said:
Thanks for the link, I downloaded and installed it OK to get RoundCorner working, what a brilliant plugin that is!
Yes, indeed it's a gem (no wonder it's called "ruby")
Admire the calm response to my rant bye the way, thanks again
I am the most patient admin/mod in the world.
Now come on, Thom! You know that I rarely lose my temper (at least in public)
I'll give you that. You're better than I am.
its great hearing about all the happy souls using Fredo. Wish I could join you. Instead like many I am unable to get the plug in to work ---at all.
I am seeing the fredo download in my left most sketchup /preferences/extensions menu but it still spits out large error messages about being unable to read certain LIb and other files.
Here's the exact error message:
Error Loading File bezierspline.rb
no such file to load -- libtraductor.rbError Loading File Z__loader.rb
undefined method `effective_load' for nil:NilClassError Loading File /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/FREDOSCALE_Dir_20/__loader.rb
uninitialized constant Traductor::Plugin::MYPLUGINError Loading File ZLoader__FredoScale.rb
uninitialized constant Traductor::Plugin::MYPLUGINOther plug ins are working fine, (including bezier spline) ...
Have followed the instructions given by TIG to a "T" .
Is there anything I am missing seriously ??? The Fredo guy mentions having to install the Fredo round corner plug in to get it to work. Ok , but where is that ? Substantive help needed thanks -
Thanks a lot for this one
i cant extract my downloaded libfredo to my sketchup8 plugin folder i got error while doing it it said cant find a libfredo file
i need more help
i need more help
i got it already
and all of plug-ins i download is working except the curviloft, example is when i make a 2 circle with different size on both end and i do the procedure and on transition part theres no output all i can see is the to circle
and if i use the button with the face icon my su8 turn to not responding state
i think i follow the right steps but all i can got is error -
Merci!
Thanks a lot! Very helpful and capable plugin!
Thanks for sharing.
NEW RELEASE: LibFredo6 3.6b - 13 Jan 11
This new release is mainly driven by Curviloft 1.1 (and to anticipate on some future scripts). It also includes fixes for SU8 and other evolutions for all my scripts (including support a two-phase loading for Curviloft, FredoScale, RoundCorner and Tools on Surface).
So it is advised to download it.
See main post for download.
Hi friedo06
first of thank u for developing such useful plugin
Nice work dude keep it up!I'm now exicted to learn more & more abouth Ruby script
take care -
Thank you!I have downloaded the plugins.
I've copied paste libfredo6 in my plugins folder...Can the following folders be safely deleted....??
LIBFREDO6_Dir_34
LIBFREDO6_Dir_35
LIBFREDO6_Dir_34
LIBFREDO6_Dir_35
YES.
Same for the plugin folders where you can remove the older folders.Fredo
I must be doing something wrong here. I downloaded version 3.6 and unzipped as instructed, and sure enough, I've got the folder LIBFREDO6_Dir_36 and the file LibFredo6.rb in my \Plugins directory. But when I run Sketchup, nothing new shows up in the Window menu. Any ideas?
The Lib is support for other tools by Fredo!
Many of these are Extensions and need activating from menu Window > Preferences > Extensions...... -
i'm beginer. thk you!
