    A gust of wind
    20 Posts 12 Posters 1.8k Views 12 Watching
    • massimoM Offline
      massimo Moderator
      Latest fun...Modeled in SU and rendered with Twilight.
      The lighting is made with three slightly yellowish IES emitter planes and a coloured point light in the flame. Progressive preset, 115 passes and no post pro of any kind. πŸ˜„
        I check this out earlier at Twilight. Really exquisite technique and application. Members would benefit by seeing the raw SU setup. Check it out in the Gallery forum.
        Thanks for bringing here too massimo πŸ‘
        • soloS Offline
          Very cool, there is a new plugin that can animate it now.
          • massimoM Offline
            massimo Moderator
            Thanks guys. πŸ˜„
            Rich here you have some raw SU's screenshot. Very simple setup.
            Saw that plugin Solo, maybe I'll try it.
            • olisheaO Offline
              olishea
              photo!
              oli
              • massimoM Offline
                massimo Moderator
                Cheers Oli. πŸ˜„
                  Roger
                  Excellent lighting. What can you tell us about the makeup of the wax. What numbers did you use for subsurface scatter, index of refraction etc.?
                  http://www.azcreative.com
                  • massimoM Offline
                    massimo Moderator
                    A new version. Added something and changed a bit the lighting. The fabric was taken somewhere from a bedroom scene and "worked" a bit with S&S plugin. Again Twilight, only 60 passes this time. no post work. πŸ˜„
                    • massimoM Offline
                      massimo Moderator
                      Thanks Roger. If I remember well you use Kerkythea. The material I've used for the wax is the "milk" from the translucent material pack, with no changes. It's a simple mix between a dielectric glass and a tranlucent mat, with scatter and falloff. It comes with Twilight installation as well.
                      IOR=1.35
                      Fog settings
                      Emittance=1
                      Scatter=1
                      Falloff=135
                      • F Offline
                        fymoro
                        πŸ‘ Massimo, Perfecto... πŸ‘
                        http://www.thearender.com/cms/index.php/news/featured-artists/137-frederic-yves-moro.html
                          Roger
                          IOR=1.35
                          Fog settings
                          Emittance=1
                          Scatter=1
                          Falloff=135
                          Wow, good memory Massimo. Yes I think KT is great but now I am also using Twilight as I like the interface a little better.
                          • massimoM Offline
                            massimo Moderator
                            Glad you like it Fred. πŸ˜„
                              Larsen
                              A lot of congratulations... But no sharing.
                              Showing is GOOD,Sharing is better.
                              [Every form of thinking perish by excess of its basic principles.
                              • numbthumbN Offline
                                numbthumb
                                Simple, yet effective. Bravissimo! πŸ‘
                                Comfortably numb...
                                  reitveld
                                  Really nice! Thanks for sharing.
                                  • Bryan KB Offline
                                    Amazing. Absolutely amazing.
                                    • massimoM Offline
                                      massimo Moderator
                                      Thanks again guys. πŸ˜„
                                      • RichardR Offline
                                        Richard
                                        Mate you are an artist!! No doubt! It's in the detail - the direction of the flame, the lost wax resulting - who else would care for such detail unless it is part of their personal charter!
                                        [BUILTBRAND.COM.AU](http://builtbrand.com.au/)
                                          SurfingAlien
                                          this is great, Massimo! just g-r-e-a-t
                                          still waiting for the OSX port of Twilight to have a go myself, BTW
                                          • massimoM Offline
                                            massimo Moderator
                                            Thanks for the kind words. Cheers Richard and Alessandro. πŸ˜„
