    Bending a textured face
    43 Posts 8 Posters 5.5k Views 8 Watching
    • numbthumbN Offline
      numbthumb
      Well, then it shouldn´t be "bending a textured face", but the other way around 😄
      Comfortably numb...
        It actually did cut a bunch off of the top. I did it this morning around 4 am before my coffee had kicked in so I didn't notice it. I measured out the line with the bend in it so it is the same length as the flat mat. I suppose the material is the projected length.
        As Csaba says, there's probably nothing that can be done about it with the way SU currently handles materials. Perhaps if things like this are really important, it would make sense to look at some other application either for applying the materials or possibly for doing the whole drawing. Although all sorts of folks are using SketchUp for things for which it wasn't originally designed, including myself, and making it work quite well, I am sure there are some jobs that are still better left to other programs.
          If this object is bending only one direction, you should not use projected material on it but simply wrap it around the curve.
          • hellnbakH Offline
            hellnbak
            Any chance of a plugin for this?
            • hellnbakH Offline
              hellnbak
              Something to glue the texture to the face or object so that it is affected the same way. Or maybe turn the texture into a face. As you can see, I know not of what I speak 😆
              You could call it "Texture Superglue" 😍
                Thomthom is working on some kind of UV plugin. Maybe that will be able to do it. Also, I have seen sneak previews of Whaat's new Subdivide and smooth plugin.
                • Chris FullmerC Offline
                  If you made the texture unique on each face of the mat, it might work then?
                  • hellnbakH Offline
                    hellnbak
                    The mat only has one face. If you're talking about dividing it into parts before bending it and making each of them unique, I thought of that, but wouldn't that increase the number of textures? I don't know enuf about this stuff to even be saying anything, but I am trying to keep my textures to a minimum to keep my file size down.
                    Probably not what you meant anyhow.
                    I'll shut up now and go away 😒
                      That is exactly what I meant. It might be the only way to do it? I don't know. Where's Thom?
                      • Wo3DanW Offline
                        Wo3Dan
                        Hi Chris, that shouldn't be necessary in the way that you get multiple textures.
                        Only one should do.
                        If you do this manually it's an easy proces towards the result. See attached file.
                        (Although I don't suppose hellnbak is looking for laborious modelling).
                        I don't know enough about your plugin but when done manually the texture I used is fixed to the original flat mat geometry. Once you split up the mat and rotate mat "segments" successively, the texture stays as it should. This could be done the same way in a script can't it?
                        textured floor mat without distortion in texture
                        • hellnbakH Offline
                          hellnbak
                          Is anybody?
                            @hellnbak said:
                            Is anybody?
                            Even if I am not deliberately looking for it, I do not mind doing it when I know I cannot achieve it otherwise and the result is worth the laborious way. Wrapping a texture around a curved face should not take longer (even if you go facet by facet) than writing a forum post.
                            This window below is on a curved wall (a basilica apse), arched and all the edges are rounded. So there was no other way than manually doing it.
                            (By the way, in this model, all the edges are rounded everywhere as you can see from the buttress, too, so when I made the textures, I even counted the pixels how they would wrap around to make a seamless tiling when they reach around pillars and such - tell me about labour! 😄 )
                            http://lh5.ggpht.com/_zcvsIuYiVbo/Suw3FoVmC8I/AAAAAAAACu4/pZfgc8630Gg/Bazilika-Texture20.jpg
                              Roger
                              Texture on a curved shape
                              The leather textures were applied to the curved shape with hidden geometry showing and clicking the paint texture tool at each change of plane. Rendered in Twilight Render using Metropolis Light Transport with Bidirectional Path Tracing. This is one small part of my project without end.
                              http://www.azcreative.com
                              • hellnbakH Offline
                                hellnbak
                                Could you please elaborate? I've tried so many things with this I'm not sure if this is one of them.
                                  Where's that model?
                                  • hellnbakH Offline
                                    hellnbak
                                    If you mean the jpg for the mat, here it is
                                      Well, not really the jpg but the model (as I do not know where and how you wanted to bend it) however here it is
                                      Mat.skp
                                      • hellnbakH Offline
                                        hellnbak
                                        Great! Now, could you please explain the process of what you did?
                                          Some pictures. After sampling / painting in picture 5, repeat the steps for the rest of the facets. It takes less than a minute. The point is that now you are not projecting but wrapping the material around that curve by positioning it.
                                          (Sorry, previously I attached a wrong screenshot)
                                            Excellent Csaba. 👍
                                            • 2 / 3
