    [Plugin] Material Replacer
    79 Posts 42 Posters 91.9k Views 42 Watching
      I'm not going to Basecamp... 😞
      • Bob JamesB Offline
        Bob James
        Bummer 😒
          Bob James
          @thomthom said:
          One can select all entities that has material with the same colour.
          That's what I don't know how to do: If I could select all the entities with the same color and then isolate only those entities I could see which ones had the "wrong" color so I could change it.
          Very belated update:
          Karen Walkerman has done just what I requested above.
          http://forums.sketchucation.com/viewtopic.php?t=31378
          Thanks again Karen πŸ‘
            dedmin
            Is it possible to change just the material of the picked face?
              Can't you just paint it ??
                dedmin
                The beauty of this tool - You don't have to open a component to change the material of the faces.
                But it changes all the material in the whole model - not just the face You click on.
                  BUT your question was to change the material of the picked face !
                  You mean to change the material of the picked face INSIDE THE GROUP/INSTANCE !
                  It couldbe done... but I must leave it to others......
                    dedmin
                    Yes, inside the group or component. And only of that picked fase.
                      lcbrewer
                      How do you install this plugin
                        Open the zip file and drop the .rb file and the folder with it into the Plugins folder where SketchUp is installed.
                        • bagateloB Offline
                          bagatelo
                          It would be possible to create a function swap some materials? Something like this:
                          Imagine a blue box and a red ball. We play the plugin, we click on the box and after the ball, and the colors are reversed. It would be interesting too, if it were possible to exchange materials not in the whole scene, but only on selected objects. Thanks for this fantastic tool.
                            cobb89
                            Is there any way we can use this plugin to replace a specific material [.skm]..that has been used in the model with vray materials [i.e. .vismats]...??
                              Use V-Ray's material editor. Right click a material and Import
                              • jarynzlesaJ Offline
                                jarynzlesa
                                thank you for this plugin, i found this very useful. πŸ‘
                                http://www.vizualizaceschodiste.mypage.cz/
                                  Bob James
                                  This sort of ties in with the current thread:
                                  http://forums.sketchucation.com/viewtopic.php?f=79&t=36987
                                  • dereiD Offline
                                    derei
                                    As I can see, this plugin replaces a material globally in entire model. It would be awesome to have option to replace material on a specific object only. πŸ‘
                                    Will you take into consideration my suggestion?
                                    Thank you.
                                    DESIGNER AND ARTIST DEREI.UK
                                      Thank you.
                                      You probably need http://forums.sketchucation.com/viewtopic.php?p=63629#p63629 [my olde Global_Material_Replacer.rb tool] - it is dialog driven to choose the material to go and material to use - including 'All' and 'Default-front/back'. It swaps materials in the entire model's active_entities collection, OR IF there's a selection on selected objects... It works inside 'containers'...
                                      • dereiD Offline
                                        derei
                                        As I could see, thomthom's plugin keeps UV mapping, when replacing materials, which is cool πŸ˜„. Does yours keeps UV ?
                                        When I use paint bucket tool to change the material on some object, the UV is reset.
                                          Use the Entity Info to replace materials - then the UV is preserved.
                                          • dereiD Offline
                                            derei
                                            Thanks! I never used it.
                                            • 2 / 4
