    A Welcome Message to New SketchUcation Members
    1.4k Posts 667 Posters 571.0k Views 667 Watching
      @riveteer said:
      Ok, first post so here it goes.
      I have been using Sketchup for a while now, (since Sketchup 5)and I have made a lot of models and posted them on 3d-warehouse. I'm joining this forum now because I would like to move to the next level of of modeling and also take advantage of some of the plugins exclusive to this site.
      First question... I downloaded this plugin called Make Faces v1.2 I have an idea of what it does but I'm having trouble implementing it on other then 2d lines. Is it possible to use this plugin on 3D lines ? If not is there a plugin that does what Make Faces does only in 3D.
      'Make Faces' only works if the selected edge had connected edges that are coplanar and could therefore make a face.
      If you have '3D' lines you need additional edges between vertices to make triangular shapes which could take a face - in fact the act of drawing them in will usually result in Sketchup adding the face for you if it can.
      To add faces in a 'mesh' linking 3D lines you could find and try Fredo's 'CurviLoft' script that's in beta, or my set of scripts zipped as the 'Extrusion Tools' - there are several tools but 'ExtrudeEdgesByRails.rb' would probably do what you want - just make 2, 3 or 4 curves from the edges [use 'weld.rb' for this] and use them as profiles/rails and they will get a mesh applied...SimpleEEbyRailsMeshV8.PNG
        Riveteer
        I get what make faces does now thanks Tig. I have also been manually drawing those triangles to make curved faces for a while now. I recently watched a speed modeling video on youtube and I swear, I saw the guy select some lines (that connected) and just push a button, and it made a meshed face.
          jimi james
          I've decided to finally stop lurking and join in. I've met a few members around the web at different places, like SFM & Deviant Art, so hello to them and everyone else as well.
          I've been using Sketchup for almost a year now....wow, has it really been that long. I guess it has. Man, time flies when you're modeling.
          Anyway, I wanted to learn 3d (cheaply) for a an original universe sci-fi project I'm working on and I've been really impressed by some of the results I've seen with Sketchup so I decided to jump in with both feet. I was really surprised by how easy it was to pick up, however with that being said, I realize I still have much to learn. I really enjoy it though so it's all good.
          I'll be posting some work in the gallery shortly. See you around the forum.
          The New Haven Chronicles
          "And we will fight." -- Secretary General Alvaro Masai
            GoldenFrog
            Lookin' forward to seeing some of your stuff Jimi!
            Remember, great minds think alike, and fools never differ.
              tonyone_06
              Iβ€˜m a newbie and I 'm not a native english speaker.Just love designd and sketchup,i'm here.Thank you.
                Hi Tony and welcome. I am not a native English speaker myself and - well, I also (and still) rememberbeing a newbie.
                πŸ˜‰
                • soloS Offline
                  He may not be a native English speaker, but Csaba can snore in many languages very fluently.
                    Indeed. And you have not even heard me after I eat beans!
                    πŸ˜’
                    • soloS Offline
                      Stereo? with aroma?
                        Doncol
                        Hi to you all, intereior designer by trade. Im relatively new to sketchup. I am used to using Solidworks. In that, you can create a plane to sketch on using a plane tool. Is there anything in sketchup that would do that ie a plugin. I find it awkward sketching to draw. This would help immensely. Thanks for listening and big thumbs up if you reply with a viable solution.
                        Col
                          Hi Colin and welcome!
                          In SU, you do not (necessarily) need a plane to sketch on. If you are drawing looking down (top view), SU will automatically draw your 2d sketches on the red/green plane.
                          However you can always draw a big enough rectangle and sketch on that if it feels more comfortable that way.
                          • I Offline
                            inkster
                            just checking -
                            ive been using su for a total of about 45 minutes now πŸ˜† (but i managed to get some images out for a presentation) πŸ‘
                            actually i learned 3d on alias wavefront back when dinosaurs roamed the earth but it was so cumbersome and pricey that i bailed before i ever became proficient at it. my background is in custom metal work and ive run into a plethora of issues right off the bat but its very promising overall, just need to take the time to learn (or unlearn) and get a rhythm going to the work flow.
                            i currently have 2d dxf to G code to a cnc cutter then on the brake presses and such to bend it all up -
                            what im missing is the ability to sketch up concepts, narrow them down, and then plug them into my current process. i noticed a "folding" plug in - not sure if it applies, material thickness is a big factor in steel.
                            anyways, thanks in advance πŸ’š
                              Hi inkster and welcome. If you work with metal, maybe you will find some of these plugins useful:
                              http://www.drawmetal.com/
                              • I Offline
                                inkster
                                thanks for the link β˜€
                                  Gaius Baltar
                                  Hello to everyone ! πŸ˜„
                                  My 'name' is Gaius .. I'm from Serbia ... from 'shity little mountain town'(like in South Park πŸ˜„ ) called Sokobanja. I'm a huge fan of SU ...
                                  I used to draw my town and I manage to finish about of 50% of it. It was a job for about a year and a half. Now I have some issues I got to work on, but when I finish all, I will present to you, so you can tell me is it any good, and I need come critics about it so I can make it better.
                                  I hope we will manage to help each other! That's it for now ...
                                  Stay safe!
                                  Greetz from Serbia πŸ˜„
                                    Hi Gaius, Gaieus here.
                                    πŸ˜„
                                      asvm27
                                      Hi my name is Andrew.
                                      I am a trim carpenter out of Indiana, I am somewhat new to sketchup.
                                      I usually will draw a sketch of a project by hand for clients, but I would like to use sketchup more so I can play with more ideas without having to erase and re draw. Anyway, I am kind of stuck on one of my sketchup drawings for a wine cellar that I have to build. I don't really know how to use this forum completely but if any one would like to help, I don't know how to put a picture of what I am doing in sketchup to show what I need help with. Any help would be really great.
                                      Thank you and I look forward to using this forum more often.
                                      • Andrew VanderMolen
                                        Hi Andrew and welcome!
                                        Below the text area where you type your forum post, there is an "Upload attachment" tab (if you scroll down a bit maybe). There you can attach images but sometimes the real skp file is the best.
                                          malcolmp
                                          Hello, my name is Malcolm Paul and this is a little project i have done for class
                                            Hi Malcolm and welcome!
                                            What class are you taking with SketchUp?
                                            (Nice model, by the way)
                                            • 58
                                            • 59
                                            • 60
                                            • 61
                                            • 62
                                            • 72
                                            • 73
                                            • 60 / 73
