    1.5k Posts 471 Posters 3.3m Views 470 Watching
    • JujuSKPJ Offline
      JujuSKP Extension Creator
      Hi Jeff,
      Thanks for your reply, I'll check that and come back to you.
      Julien
      • fredo6F Offline
        Hi Jeff,
        Julien
        Julien,
        What I can do is to prepare a file with traces that you can run. The issue seems to be in the Palette drawing, but I don't see why it can take so long.
        • JujuSKPJ Offline
          Jeff,
          I have try to shrink the palette, but does respond for me (still same problem).
          However, I change the plugins folder as mention, and try out the roundcorner plugin. I still have the problem, but it responds a little more better.
          First improvement, we are on the good way -)
          Thanks julien
          • Z Offline
            Zacchia
            This is really a helpful plugin, with it it is easy to create sofas! Thanks a lot to give this for free!!
              sasa
              hi fredo
              i can see that other people had succeeded installing and using the roundcorner plugin
              i've extracted the folders into the plugin file and put it by the order u mentioned
              when i tried to open the sketchup i'v got errors :
              Error Loading File ZLoader__RoundCorner.rb
              uninitialized constant LibFredo6::Traductor
              i'm a mac user and i would be more than happy to have a solution !!
              • fredo6F Offline
                Sasa,
                I think you forgot to install LibFredo6, which is a shared library used by my plugins.
                see http://forums.sketchucation.com/viewtopic.php?f=323&t=17947&hilit=plugin
                • 3 Offline
                  3D Sloth
                  Ok, so I have to wait for the next release?
                  I am sorry but I am not using Windows anymore -)
                  I was used to work with sketchup 7 and the round corner plugin without any problems.
                  I have download and install curviloft, it works really fine and quick.
                  I have retry roundcorner, still having the same problem.
                  thanks fredo
                  Then, it would be helpful if other Mac users could tell if they have similar performance issues.
                  Sure thing, I'm having exactly the same problem as JujuSkp. Just got pointed towards this thread for this!
                  • N Offline
                    N3MES1S
                    @cst said:
                    Fredo:
                    I use Mac OS 10.6 and SketchUp 8.
                    I have dropped RoundCorner%202 & LibFredo6%203 into the
                    plugins folder which is nested in the
                    Sketchup folder which is nested in the
                    Google SketchUp 8 folder which nested in the
                    Application Support folder which is nested in the
                    Library folder which is nested in the
                    Hard Drive icon
                    When I start up SketchUp 8 I see no new tools in the Tools drop-down menu.
                    Please tell me what I've done wrong.
                    Thank you
                    Cliff
                    cliff, those are the folders you're left with upon unzipping.. you have to open those folders to get to these files:
                    %(#FF0000)[ROUNDCORNER_Dir_21
                    ZLoader__RoundCorner.rb]
                    and
                    %(#FF0000)[LIBFREDO6_Dir_34
                    LibFredo6.rb]
                    those four items go in the plugins folder at the same path you stated in your post.
                    Hi, awesome plugin, a shame i cant get it to work. I placed the folders and the files under the plugins folder, as u say, there are 2 folders, the roundcorner plugin folder and the libfredo library folder. And 2 files, the roundcorner plugin file and the libfredo library file. But i cant see anything about the plugin in sketchup, neither in preferences neither in the context menu. Is this plugin working for sketchup 8.0 ???
                      LiveView
                      [b]RoundCorner performs the rounding of the edges and corners of 3D shapes along a 2D profile, in 3 modes: Round corners, Sharp corners and Bevel.
                      Hi Fredo6 ! πŸ˜„
                      This ruby made a strong impression on me ! It's very very very useful !
                      I have a small idea, could you resolve it ?
                      Image link broken, browser stalls thus link removed (poster never came back anyway).
                      Many thanks ! πŸ˜„
                        akigrimm
                        Hi Fredo
                        I desperately try to install your plugin, but I must have done something wrong: In the Sketchup 7.1 pro i put in the plugin folder:
                        LIBFREDO6_Dir_35
                        ROUNDCORNER_Dir_21
                        LibFredo6.rb
                        When starting SU it prompts:
                        uninitialized constant Traductor::Plugin
                        Why could that be?
                        Thanks for the help
                        • fredo6F Offline
                          HI,
                          For some reasons (may be the unzip operation), you do not have th right footprint and LibFredo6 has not been loaded.
                          I suggest you check again.
                          • I Offline
                            Ike
                            I am having similar problems installing this plugin.
                            Has anybody been successful installing it and using on a Mac.
                            If there is, can someone please send a screenshot of the hireacy
                            of the plugins folder so, we can have a visual reference
                            Your help is very much appreciated
                            Ike
                            • V Offline
                              Vicspa
                              The plugin I use the most.
                              Thanks so much
                              • jeff hammondJ Offline
                                @ike said:
                                Ike
                                Ike,
                                here's a mac installer for round corner which will work with su7 & 8
                                http://web.me.com/jeffhammond/su/RoundCorner.zip
                                • I Offline
                                  Ike
                                  @ike said:
                                  Ike
                                  Ike,
                                  That was easy πŸ˜„
                                  Thanks Jeff, I am so grateful
                                  Ike
                                  • StinkieS Offline
                                    Stinkie
                                    Does anyone know how the max amount of, er, bevel segments (? sorry - not a native speaker) can be upped? Currently the maximum amount is 30. I've been going through the code, but truth be told, I'm not much of a coder. πŸ˜„
                                    Help me out, and I'll send you gold, and curvy blondes. Really.
                                    • utilerU Offline
                                      utiler
                                      Hey stinkie, i don't know code either but you got me interested......!
                                      Just Curious...
                                        Look inside **RoundCorner_Commom.rb** find the line #150
                                        MYDEFPARAM.declare_:DEFAULT_Flag_Numseg, 6, 'I:>0<****30****'
                                        and change the 30 to something else like 72 [that's what I have mine set to]...
                                        Then in **RoundCorner_Tool.rb** find line #346
                                        @dlgall.field_numeric "num_seg", T6[:DLG_All_Numseg], 6, 1, ****30****
                                        and change the 30 to match - like 72...
                                        and line #1032 find
                                        if numseglock || numseg <= 0 || numseg > ****30****
                                        PM me about the delivery address πŸ˜‰
                                        • StinkieS Offline
                                          Stinkie
                                          Thanks, TIG! Much obliged. 😍
                                          Andrew - sorry, the blondes and the gold are being shipped to TIG's as we speak. I'm sure you understand the supply's limited. I do still have a bag of musty lint.
                                          • utilerU Offline
                                            utiler
                                            Thats' OK mate. Blonde's are hard work anyway.... I'll let someone else put up with there shit.... πŸ˜‰
                                            Just Curious...
                                            • 11
                                            • 12
                                            • 13
                                            • 73
                                            • 74
                                            • 11 / 74
