    [Plugin] Selection Toys
    594 Posts 121 Posters 397.8k Views 121 Watching
    • TIGT Online
      All of this suggests that it is not a valid Ruby file ?
      Oddly encoded?
      Opened in a word-processor??
      Incorrectly unzipped???
      Who knows...
        Looks like corrupted download, or corrupted unzipping. What's the content ofvthe .rb file when you open it in a text editor - a plain text editor like Notepad?
        I've never ever seen such error.
        • irwanwrI Offline
          irwanwr
          i've downloaded both again twice. TTLib and Selection Toys.
          either 7zip or winrar seems to work just fine.
          i'll try to unzip them with 7zip then.
          [Edit]
          Problem solved. Old corrupted files sometimes need to be erased first
          and not just overwrite it. Both works fine now. Checked with Notepad++.
          Thank you all. πŸ‘
            Does exist a selection of segments of an explosed curve 1/x ? (Maybe I have missed that in the list)
            So
            for 1/2 ( 1,3,5,7...
            for 1/3 (1,4,7,10...
            for 1/4 (1,5,9,13...
            etc...
              what..? 😲 πŸ˜• ❓
                Like this for select all segments of a curve by 1 / x
                Here x = 2 or x = 3
                  I was thinking of something like that for V3 - and QuadFace Tools.
                    Cool! 😎
                    • I Offline
                      ivreich
                      Select edges by length(?)
                      Hi thomthom,
                      Any chance we could have a feature to select edges by length? For examples, select edges <X, =X, >X, where X is the length of a pre-selected edge?
                      I'm doing some work involving mapping of components to edges, and this could be a pretty handy tool to have.
                      Cheers
                      Joel
                        Right now I'm very busy with Vertex Tools - getting it ready to ship.
                        • cottyC Offline
                          cotty
                          Hi thomthom,
                          Cheers
                          Joel
                          Maybe this can help you: http://forums.sketchucation.com/viewtopic.php?t=16915#p134106 ?
                          my SketchUp gallery
                          • E Offline
                            Ecuadorian
                            Just wanted to thank Thomthom again. I'm currently working on a project that has a lot of junk in a certain layer, and found no other way to do the job but to use his plugin.
                            Thanks! πŸ‘
                            -Miguel Lescano
                              Dollmaker
                              Select loop does not work for me on sketchup 8.. it only select edges but there is no loop selected on faces..
                                Screenshots? Sample model?
                                • F Offline
                                  fullyfledgeded
                                  Hi, great tool. Works on my google su 8 but not my trimble version. Any thoughts? the plugins are installed, but when you context click nothing happens
                                    I have the latest Trimble version, used every one f them. Always worked.
                                    Can you be more specific to "when you context click nothing happens"?
                                    What are you clicking on?
                                    Surely there is a menu appearing? Missing menu items?
                                    Any errors? (If you keep the Ruby Console open?)
                                    • F Offline
                                      fullyfledgeded
                                      In trimble SU 8 I double click Susan (SU's default component) to enter it for editing. Click her grey shirt so only that is selected. right click it, then click select & then hit "coplanar faces". nothing changes.
                                      the exact same process in google SU 8 works how it should.
                                      ruby console displays nothing in both cases
                                      there are no missing menu items, it appears the same in both su versions.
                                      thanks
                                        Works fine on my computer. Might be some other plugin interfering. Try with just Selection Toys installed.
                                        • TIGT Online
                                          If you click on just her 'gray' shirt then only one face will be selected, there are no edges in the selection to be considered for coplanar-ness...
                                          BUT if you double-click the shirt-face so that its edges also select... then some of those edges can be considered 'coplanar', because they border two same-plane-faces which also have the same 'gray' material...
                                            MadPax
                                            Do the conditions of dependency mean that one cannot have both Quad Tools and the Selection Toys installed simultaneously? (Because of the different TT-Lib versions involved?)
                                            Cheers,
                                            Peter
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 29
                                            • 30
                                            • 22 / 30
