    Projecting Textures question
    18 Posts 5 Posters 1.8k Views 5 Watching
      You know, it would be a big help if you posted images of what you are trying to accomplish and what you are getting.
      @N08/5220913800/" target="_blank" rel="noopener noreferrer nofollow ugc">
      http://farm5.static.flickr.com/4104/5220913800_f39ed0db04.jpg
      A minute or two to do this. I used the first shift pattern I came across.
      since the shift pattern wouldn't be repeated on the bottom of the knob, make that component unique and apply the other material.
      • GaieusG
        @hellnbak said:
        I have tried exploding the top sphere half, but it still will only project onto individual "slices" at a time...
        Then you are either not projecting or your geometry is not smooth or anything.
        Like Dave says;
        • hellnbakH
          hellnbak
          Not quite what I had in mind. But I'm just a noob, so I probably don't know what the hell I'm doing.
          • hellnbakH
            hellnbak
            It did, for whatever reason, seem to stop projecting it onto individual slices
            • GaieusG
              Post the file, please. It is so hard to say anything from an image like that. If you are projecting that image (how are you doing it by the way?) it should NOT look like that.
              • hellnbakH
                hellnbak
                Here it is.
                Ball 4.skp
                  You have a mixture of 'Hidden Lines' and 'Softened Lines' as a result of your previous efficint modelling. Even you cannot see these lines SU does and is attempting to 'Project' between each segment.
                  Start again and drawe a Sphere and project on to that Sphere. Then compare new Sphere with old Sphere with 'Hidden Geometry' on.
                  • GaieusG
                    Rich beat me but like I said above:
                    Triple click on your sphere and right click > Soften edges and in the popup dialog, pull the slider a bit. Just enough to "tough" it.
                    Then do the projection.
                    • hellnbakH
                      hellnbak
                      Ok, it seems to work now, although I'm not sure of the whys and wherefores of it, which bothers me. Now, how do I get rid of the "extras" as indicated in attached photo? Thanks for bearing with me.
                        To prevent the image from repeating, you need to make the area the material is to fill small enough so that it can't. If you look at my example, you can see where the gray changes. I intersected a horizontal face with the hemisphere to create that limit. After applying the image of the shift pattern to the upper region and a gray color that was close to the lower region, I hid the edges of the circle that resulted from the intersection. I also deleted the internal face that was created during the intersection since it isn't needed.
                        FWIW, I could have made the image slightly smaller and made it fit better but it was just an example, anyway.
                          Or to build on Dave's excellent advice....
                          Your texture is tiling due to the fact the Ball's surface area is larger than your textures surface area. Edit your texture to something like this...
                          This can be done in GIMP or PhotoShop or Paint.NET or whatever you use to manipulate images. Basically the canvas of your image needs more space between the gear stick textures otherwise those repeating patterns will show on the ball.
                          As i said to you before. Keep asking questions and you'll learn some great tricks here. Like Daves approach or my longer approach πŸ˜’
                          Sorry Dave i started typing and couldn't resist posting.
                          • hellnbakH
                            hellnbak
                            Actually I just showed the hidden geometry and painted the faces to get rid of the stuff I didn't want. Had to draw a couple lines where the good and the bad stuff shared a face, but it worked fine. My head hurts too much to try what you suggested πŸ˜†
                            Thanks again for sticking with me on this. Much appreciated.
                            • hellnbakH
                              hellnbak
                              I know this probably wouldn't work in most situations, but it did in this simple one. Your method of enlarging the area around the image will probably be what I use in the future.
