    [Plugin] Lattice Maker
    149 Posts 69 Posters 374.8k Views 68 Watching
      Here's v1.1 http://forums.sketchucation.com/viewtopic.php?p=244981#p244981
      Extract from the zip as directed...
      Pane 'thickness' option added - useful if pane viewed from both sides and it is to be exported to a 3rd party renderer.
      New EN-US/FR/ES .lingvo files added in ../Plugins/TIGtools/ folder.
        Here's a slightly tweaked ES lingvo file, by Defisto.
        It will be included with any future update, but if you want it now please extract it into ../Plugins/TIGtools/ folder, to replace the original file.
        Aquí está un archivo lingvo-ES ligeramente modificado, por Defisto.
        Será incluido con cualquier actualización futura, pero si lo quieres ahora por favor extraerlo en la carpeta ../Plugins/TIGtools/, para reemplazar el archivo original.
        latticeMakerES.zip
          Here's v1.2 http://forums.sketchucation.com/viewtopic.php?p=244981#p244981
          The ES lingvo filehas been updated by Defisto.
          The Zip file now also contains deBabelizer.rb.
          • EdsonE
            Edson
            TIG,
            I ran into a little problem while installing this. it occurs that the zip file contains a folder named TIGtools, the same name of a folder that is part of your extrusion set of tools. thus when I try to put it in my plugins folder I am asked whether I want to replace the older folder or not which of course I do not.
            what is the solution for that?
            http://www.mahfuz.arq.br
              Reply 'Yes' and it should then merge the folders [does on PC... hope it does on MAC] - you need the new files in the folder - the existing ones should be retained...
              • gtalaricoG
                gtalarico
                Hi Tig.
                When I open double click to open one of my SU files I am getting a Loading error from latticeMaker...
                It does not happen if I just open Sketchup by itself - and I think it is only with this one specific file.
                Any ideas?
                LOADING ERROR:
                Error Loading File latticeMaker.rb
                C:/PROGRA~2/Google/GOOGLE~3/Plugins/latticeMaker.rb:2: syntax error, unexpected '(', expecting kEND
                Copyright 2010 (c), TIG
                C:/PROGRA~2/Google/GOOGLE~3/Plugins/latticeMaker.rb:4: syntax error, unexpected tCONSTANT, expecting kEND
                ...FTWARE IS PROVIDED "AS IS" AND WITHOUT ANY EXPRESS OR IMPLIE...
                C:/PROGRA~2/Google/GOOGLE~3/Plugins/latticeMaker.rb:5: syntax error, unexpected tCONSTANT, expecting kDO or '{' or '('
                WARRANTIES,INCLUDING,WITHOUT LIMITATION,THE IMPLIED WARRANTIES OF
                C:/PROGRA~2/Google/GOOGLE~3/Plugins/latticeMaker.rb:10: syntax error, unexpected ':', expecting kEND
                C:/PROGRA~2/Google/GOOGLE~3/Plugins/latticeMaker.rb:11: syntax error, unexpected tIDENTIFIER, expecting kDO or '{' or '('
                ...and makes a Lattice, offset by a frames given
                C:/PROGRA~2/Google/GOOGLE~3/Plugins/latticeMaker.rb:12: syntax error, unexpected ',', expecting kEND
                width and depth, and pane inset, you can also ...
                C:/PROGRA~2/Google/GOOGLE~3/Plugins/latticeMaker.rb:12: syntax error, unexpected tIDENTIFIER, expecting kDO or '{' or '('
                ...depth, and pane inset, you can also assign limited Materials...
                C:/PROGRA~2/Google/GOOGLE~3/Plugins/latticeMaker.rb:13: syntax error, unexpected kFOR, expecting kDO or '{' or '('
                to the frame/pane for ease of future selection/manipulation.
                C:/PROGRA~2/Google/GOOGLE~3/Plugins/latticeMaker.rb:14: syntax error, unexpected tIDENTIFIER, expecting kEND
                It is similar to EEbyRailsToLattice BUT works on selected Faces...
                C:/PROGRA~2/Google/GOOGLE~3/Plugins/latticeMaker.rb:16: syntax error, unexpected ':', expecting kEND
                C:/PROGRA~2/Google/GOOGLE~3/Plugins/latticeMaker.rb:17: syntax error, unexpected tCONSTANT, expecting kEND
                Make a 3D Mesh - perhaps using EEbyRail...
                C:/PROGRA~2/Google/GOOGLE~3/Plugins/latticeMaker.rb:17: syntax error, unexpected tIDENTIFIER, expecting kDO or '{' or '('
                ...Make a 3D Mesh - perhaps using EEbyRails or other tools - re...
                ...or other tools - remember that
                C:/PROGRA~2/Google/GOOGLE~3/Plugins/latticeMaker.rb:18: syntax error, unexpected kNOT, expecting kEND
                Faces need not be triangulated if all Edges ...
                C:/PROGRA~2/Google/GOOGLE~3/Plugins/latticeMaker.rb:19: syntax error, unexpected tIDENTIFIER, expecting kDO or '{' or '('
                using similar profiles/rails will allow 'quad faces'. You can also
                C:/PROGRA~2/Google/GOOGLE~3/Plugins/latticeMaker.rb:20: syntax error, unexpected tIDENTIFIER, expecting kDO or '{' or '('
                manually draw over faces to sub-divide them as required.
                C:/PROGRA~2/Google/GOOGLE~3/Plugins/latticeMaker.rb:22: syntax error, unexpected tCONSTANT, expecting kDO or '{' or '('
                any Edges etc in the Selection are igno...
                C:/PROGRA~2/Google/GOOGLE~3/Plugins/latticeMaker.rb:27: syntax error, unexpected tIDENTIFIER, expecting kEND
                ...e direction away from a Face's
                C:/PROGRA~2/Google/GOOGLE~3/Plugins/latticeMaker.rb:28: syntax error, unexpected ',', expecting kEND
                'front', so if you want the frames and...
                C:/PROGRA~2/Google/GOOGLE~3/Plugins/latticeMaker.rb:28: syntax error, unexpected kIN, expecting kEND
                ...rames and pane to be formed in the other
                C:/PROGRA~2/Google/GOOGLE~3/Plugins/latticeMaker.rb:29: syntax error, unexpected tIDENTIFIER, expecting kEND
                direction 'Reverse' the Selected Faces beforehand.
                C:/PROGRA~2/Google/GOOGLE~3/Plugins/latticeMaker.rb:31: syntax error, unexpected tIDENTIFIER, expecting kDO or '{' or '('
                Run 'Lattice Maker', from the Plugins Menu.
                C:/PROGRA~2/Google/GOOGLE~3/Plugins/latticeMaker.rb:32: syntax error, unexpected kTHEN, expecting kEND
                You are then prompted to chose the 'Lattice Properties':
                C:/PROGRA~2/Google/GOOGLE~3/Plugins/latticeMaker.rb:32: syntax error, unexpected ':', expecting kEND
                C:/PROGRA~2/Google/GOOGLE~3/Plugins/latticeMaker.rb:33: syntax error, unexpected tIDENTIFIER, expecting kDO or '{' or '('
                'Width' - default is 50mm/2" - this is the width centered on the
                C:/PROGRA~2/Google/GOOGLE~3/Plugins/latticeMaker.rb:33: syntax error, unexpected tSTRING_BEG, expecting kEND
                C:/PROGRA~2/Google/GOOGLE~3/Plugins/latticeMaker.rb:34: syntax error, unexpected tIDENTIFIER, expecting kEND
                ...ely a 100mm/4" 'frame' overall where faces abut.
                C:/PROGRA~2/Google/GOOGLE~3/Plugins/latticeMaker.rb:35: syntax error, unexpected '['
                [if <=0 it defaults]
                C:/PROGRA~2/Google/GOOGLE~3/Plugins/latticeMaker.rb:36: syntax error, unexpected tIDENTIFIER, expecting kDO or '{' or '('
                'Depth' - default is 50mm/2", this is measured 'in' from the face
                C:/PROGRA~2/Google/GOOGLE~3/Plugins/latticeMaker.rb:36: syntax error, unexpected tSTRING_BEG, expecting kEND
                C:/PROGRA~2/Google/GOOGLE~3/Plugins/latticeMaker.rb:39: syntax error, unexpected tEQ
                default is 25.mm/1" [if ==0 there is no 'inset', if <0 it defaults;
                C:/PROGRA~2/Google/GOOGLE~3/Plugins/latticeMaker.rb:39: syntax error, unexpected '<'
                C:/PROGRA~2/Google/GOOGLE~3/Plugins/latticeMaker.rb:40: syntax error, unexpected kAND
                it can never be more than the depth, and reverts to that if it is].
                C:/PROGRA~2/Google/GOOGLE~3/Plugins/latticeMaker.rb:40: syntax error, unexpected ']', expecting kEND
                C:/PROGRA~2/Google/GOOGLE~3/Plugins/latticeMaker.rb:41: syntax error, unexpected tIDENTIFIER, expecting kDO or '{' or '('
                'Pane Thickness' - the thickness of the pane measured inset from the
                C:/PROGRA~2/Google/GOOGLE~3/Plugins/latticeMaker.rb:42: syntax error, unexpected tIDENTIFIER, expecting kEND
                ...0.25" [if ==0 the pane is 'one sided'
                C:/PROGRA~2/Google/GOOGLE~3/Plugins/latticeMaker.rb:43: syntax error, unexpected tIDENTIFIER, expecting kEND
                (facing 'out'), if <0 it is 'outset', this...
                ...ng 'out'), if <0 it is 'outset', this -ve 'outset' cannot be...
                ... is 'outset', this -ve 'outset' cannot be > the
                C:/PROGRA~2/Google/GOOGLE~3/Plugins/latticeMaker.rb:47: syntax error, unexpected tCONSTANT, expecting kEND
                'Lattice Material' - default is <Defau...
                ... - additional choices are 'Red',
                C:/PROGRA~2/Google/GOOGLE~3/Plugins/latticeMaker.rb:48: syntax error, unexpected tCONSTANT, expecting kEND
                'Orange', 'Yellow', 'Green', 'Blue', ...
                'Orange', 'Yellow', 'Green', 'Blue', 'Violet', ...
                'Orange', 'Yellow', 'Green', 'Blue', 'Violet', 'Black', ...
                ...nge', 'Yellow', 'Green', 'Blue', 'Violet', 'Black', 'White' ...
                ...low', 'Green', 'Blue', 'Violet', 'Black', 'White' or 'Gray'.
                ...een', 'Blue', 'Violet', 'Black', 'White' or 'Gray'.
                ...ue', 'Violet', 'Black', 'White' or 'Gray'.
                ...et', 'Black', 'White' or 'Gray'.
                C:/PROGRA~2/Google/GOOGLE~3/Plugins/latticeMaker.rb:49: syntax error, unexpected tCONSTANT, expecting kEND
                'Pane Material' - default is <None>...
                C:/PROGRA~2/Google/GOOGLE~3/Plugins/latticeMaker.rb:50: syntax error, unexpected tCONSTANT, expecting kEND
                "Glass", 'Red', 'Orange', 'Yellow', 'Green', 'Blue', 'Violet',
                "Glass"
                "Glass"
                "Glass"
                C:/PROGRA~2/Google/GOOGLE~3/Plugins/latticeMaker.rb:51: syntax error, unexpected tCONSTANT, expecting kEND
                'Black', 'White', 'Gray'.
                C:/PROGRA~2/Google/GOOGLE~3/Plugins/latticeMaker.rb:53: syntax error, unexpected tIDENTIFIER, expecting kEND
                become 'holes' in the final lattice.
                C:/PROGRA~2/Google/GOOGLE~3/Plugins/latticeMaker.rb:54: syntax error, unexpected tCONSTANT, expecting kEND
                ***The 'Glass' material will be made if it ...
                C:/PROGRA~2/Google/GOOGLE~3/Plugins/latticeMaker.rb:54: syntax error, unexpected tIDENTIFIER, expecting kEND
                ...ial will be made if it doesn't exist - it is colored
                C:/PROGRA~2/Google/GOOGLE~3/Plugins/latticeMaker.rb:54: syntax error, unexpected tIDENTIFIER, expecting kDO or '{' or '('
                ...de if it doesn't exist - it is colored
                C:/PROGRA~2/Google/GOOGLE~3/Plugins/latticeMaker.rb:55: syntax error, unexpected tIDENTIFIER, expecting kEND
                'bluish-light-gray' with 3030200154pacity.
                C:/PROGRA~2/Google/GOOGLE~3/Plugins/latticeMaker.rb:57: syntax error, unexpected tCONSTANT, expecting kEND
                The Faces edges are now offset to suit,...
                C:/PROGRA~2/Google/GOOGLE~3/Plugins/latticeMaker.rb:57: syntax error, unexpected kTHEN
                ...s are now offset to suit, then pushpulled to suit and the
                C:/PROGRA~2/Google/GOOGLE~3/Plugins/latticeMaker.rb:59: syntax error, unexpected tIDENTIFIER, expecting kEND
                ...too small to have a 'pane' are made 'solid'.
                C:/PROGRA~2/Google/GOOGLE~3/Plugins/latticeMaker.rb:60: syntax error, unexpected tIDENTIFIER, expecting kDO or '{' or '('
                The operation is one-step undo-able.
                C:/PROGRA~2/Google/GOOGLE~3/Plugins/latticeMaker.rb:62: syntax error, unexpected ':', expecting kEND
                C:/PROGRA~2/Google/GOOGLE~3/Plugins/latticeMaker.rb:63: syntax error, unexpected tIDENTIFIER, expecting kDO or '{' or '('
                Are welcome [by PayPal], please use 'TIGdonations.htm' in the
                C:/PROGRA~2/Google/GOOGLE~3/Plugins/latticeMaker.rb:63: syntax error, unexpected kIN, expecting kEND
                C:/PROGRA~2/Google/GOOGLE~3/Plugins/latticeMaker.rb:64: unknown regexp options - TIGtl
                C:/PROGRA~2/Google/GOOGLE~3/Plugins/latticeMaker.rb:66: syntax error, unexpected tCONSTANT, expecting kEND
                To Do:
                C:/PROGRA~2/Google/GOOGLE~3/Plugins/latticeMaker.rb:70: syntax error, unexpected tINTEGER, expecting kEND
                1.0 20100511 First release.
                C:/PROGRA~2/Google/GOOGLE~3/Plugins/latticeMaker.rb:71: syntax error, unexpected tFLOAT
                1.1 20101023 Pane 'thickness' option added.
                C:/PROGRA~2/Google/GOOGLE~3/Plugins/latticeMaker.rb:71: syntax error, unexpected tIDENTIFIER, expecting kEND
                C:/PROGRA~2/Google/GOOGLE~3/Plugins/latticeMaker.rb:72: syntax error, unexpected tCONSTANT, expecting kDO or '{' or '('
                ... EN-US/FR/ES Lingvo files added in ../Plugins/TIG...
                C:/PROGRA~2/Google/GOOGLE~3/Plugins/latticeMaker.rb:72: syntax error, unexpected kIN, expecting kEND
                ...US/FR/ES Lingvo files added in ../Plugins/TIGtools/ folder.
                C:/PROGRA~2/Google/GOOGLE~3/Plugins/latticeMaker.rb:72: unknown regexp options - TIGtl
                C:/PROGRA~2/Google/GOOGLE~3/Plugins/latticeMaker.rb:73: syntax error, unexpected tFLOAT
                1.2 20101027 ES lingvo updated by...
                C:/PROGRA~2/Google/GOOGLE~3/Plugins/latticeMaker.rb:74: syntax error, unexpected '=', expecting kEND
                C:/PROGRA~2/Google/GOOGLE~3/Plugins/latticeMaker.rb:137: syntax error, unexpected kDO_BLOCK, expecting kEND
                0.upto(verts.length-1) do |i|
                -Gui
                http://www.gtalarico.com
                • G
                  gavvy
                  WOW ,I DON'T KNOW HOW TO SAY IT 😮
                    gtalarico
                    The error is telling me that on line 2 it finds an unexpected '('.
                    Thereafter all of the code is knacked as it's corrupted...
                    Because the first several lines are inside a =begin..=end comment-block Ruby shouldn't even be reading line that at all - let alone give an error!
                    Open the file in Notepad.exe [or equivalent plain-text editor] and see if it starts with
                    =begin
                    Have you edited/read the file in word-processor and saved it?
                    If so then that might have corrupted it.
                    Try re-downloading the files and replacing it with a virgin copy.
                    This is a weird error! 😒
                      dhonzie
                      TIG, i really appreciate all your plugins.... THANK U!!!!! 😍 😍 😍
                      can you or somebody upload a tutorial for this so that i could apply this to my school project???
                      Thank u n advance...... 😄
                        There are several examples in the thread[s]...
                        There are some movie tutorials for various plugins in the pipeline, but I can't say when they might be going public...
                          dhonzie
                          hehe... THANK U i am looking forward to watch that video soon..
                          Thank u again TIG for giving us those plugins.....
                          hopefully someday all the fuction in 3dsmax would be available in sketchup...
                          thank u again TIG......... 😄 😄
                          • utilerU
                            utiler
                            I really look forward to these video tuts too, TIG. Always good to see it in action from a pro!!!! 👍
                            Just Curious...
                              arjunmax09
                              Is it possible to delete in one go the original linear path used for lattice making??
                              when you fail at something....you haven't really failed...you've found one way the thing will not work out
                                Lattice Maker does NOT leave a linear path - it uses the selected mesh faces to make the 'panes' so the 'path' is consumed ?
                                EEbyRailsToLattice does leave the Profile and Rail Curves... BUT on completion asks if you want to delete them -on a Yes they go too ??
                                Please explain yourself differently... 😕
                                  arjunmax09
                                  TIG...I've uploaded images to clear my question
                                    Ah! You mean 'coplanar' edges - not easy removed because of the inner face. Because the LatticeMaker is for 3D meshes to Lattices each 'pane' is made separately.
                                    I suggest you get my 'Latticeizer' - that is intended for 2D forms and it does remove the original center-lines if specified. You draw the form and group it, then 'Latticeize' it - you should then get the results you want without center-lines...
                                    • bagateloB
                                      bagatelo
                                      TIG: Please note if is possible to solve my problem: http://forums.sketchucation.com/viewtopic.php?f=323&t=16599&p=316794#p316794
                                        Bagatelo
                                        I have replied in the other thread you linked to - I think perhaps you mean Latticeizer NOT LatticeMaker ?
                                        • bagateloB
                                          bagatelo
                                          I am sorry having traded the place where it I should respond.
                                          Please note the presentation that I have made in the attached file. That's exactly what I need. In some cases, I do not use handles in aluminum bar. I use ordinary handles. So I do not pull over 3cm from top face to bottom. In some cases, I use different spaces for 0.5cm, as requested by the woodworker or architect that I work. Thank you for your attention.
                                          WHAT I NEED SKT 7.skp
                                          • N
                                            Niffler
                                            Thank you, TIG for all you do.
                                            Although you are in the UK, I still would like to wish you a wonderful Thanksgiving holiday and to all you "Sketchers" out there. I lift my pint of (alcohol-free) nog to you, mates.
                                            Peace
                                            • 3 / 8
