    [Plugin] triangulateFaces.rb v1.2 20101120
    97 Posts 21 Posters 117.7k Views 21 Watching
      blair
      Thanks PILOU!
      I just tried that one on the flat plane I had previously shown and it did nothing. What I would like to do is create a multitude of triangles like Jeff had shown on the far right in the example he posted.
        Try this plugin: http://forums.sketchucation.com/viewtopic.php?f=323&t=21472
        Use the UV probe and hit F2 to see SU's internal triangulation. What do you get then? Would that triangulation be ok?
        • bac9-flclB Offline
          bac9-flcl
          Upd: I've figured out what conditions are needed to reproduce the bug (all dimensions are multiple of 1m in this example; if it matters):
          http://img.gameru.net/th/7a004.jpg
          Thanks, will try it and post about result πŸ˜„
            bac9-flcl
            Greetings.
            I've encountered a problem with this plugin. Here's the deal: I am making a complex building, looking like that:
            http://img.gameru.net/th/65082.jpg
            Of course, it consists of a hundreds of separate components, because I don't need any unnecessary polycount. For example, here are the outer walls:
            http://img.gameru.net/th/a4015.jpg
            http://img.gameru.net/th/3697a.jpg
            As you can see, they are divided with edges. Some were made to allow different texturing (e.g. leaks under the windows), and some - to ensure that triangulation made during the import process via Autodesk Connection Extension (which seems, by the way, to be the only way to export your model from SU without breaking it) won't look like a messy web full of thin invalid faces.
            However, CE repeatedly fails to triangulate T-type face connections properly:
            http://img.gameru.net/th/75605.jpg
            Here is how it should look like:
            http://img.gameru.net/th/d3095.jpg
            And there are the examples how CE (or standart 3DS Max triangulation, maybe CE is just utilizing it) works with such faces:
            http://img.gameru.net/th/42a40.jpg
            http://img.gameru.net/th/3697d.jpg
            Of course it's not your problem, but Max/CE, so let's move onto the subject. To ensure this weirdness won't appear in my model after Max import, I must draw all triangulation on risky areas by myself, in SU, before using Connection Extension.
            It's quite easy to guess that I hate to spend time for this. It would take hours to complete hand-made triangulation with Line tool for every T-shaped area. So I searched for some SU plugin which can make a triangulation of selected faces, - your seems to be the most used πŸ˜„
            I tried the plugin:
            http://img.gameru.net/th/380a1.jpg
            http://img.gameru.net/th/767b6.jpg
            Seemed to work fine, but when I tried it on a bit harder areas, it didn't went so smooth:
            http://img.gameru.net/th/e1cda.jpg
            http://img.gameru.net/th/39e2b.jpg
            These edges are missing:
            http://img.gameru.net/th/318e3.jpg
            Another area:
            http://img.gameru.net/th/1fc3c.jpg
            http://img.gameru.net/th/ce385.jpg
            http://img.gameru.net/th/8b639.jpg
            I decided to test it on the simple T-shaped face without pre-drawn edges. Unfortunately, I got this:
            Is there some kind of a rule I don't know? Something like "non-convex faces are forbidden"? πŸ˜„
            It's just strange to encounter the same issue again in a completely different software, with an area I can't call hard to triangulate at all. There are no geometrical paradoxes, every man can connect these points with proper lines, - then why a triangulation is improper?
            To be exact, the problem seems to be related not only to T-shaped faces, but to non-convex faces (in some curcumstances) and to faces with divided straight edges:
            [url=http://img.gameru.net/?v=5feed.jpg:3a0jr4pg][img:3a0jr4pg]http://img.gameru.net/th/5feed.jpg[/img:3a0jr4pg][/url:3a0jr4pg]
            Here I got a more complex example:
            [url=http://img.gameru.net/?v=6afdd.jpg:3a0jr4pg][img:3a0jr4pg]http://img.gameru.net/th/6afdd.jpg[/img:3a0jr4pg][/url:3a0jr4pg]
            Surprisingly, it was triangulated properly:
            [url=http://img.gameru.net/?v=05e4c.jpg:3a0jr4pg][img:3a0jr4pg]http://img.gameru.net/th/05e4c.jpg[/img:3a0jr4pg][/url:3a0jr4pg]
            Then I've added the line:
            [url=http://img.gameru.net/?v=73f56.jpg:3a0jr4pg][img:3a0jr4pg]http://img.gameru.net/th/73f56.jpg[/img:3a0jr4pg][/url:3a0jr4pg]
            Just as planned:
            [url=http://img.gameru.net/?v=36011.jpg:3a0jr4pg][img:3a0jr4pg]http://img.gameru.net/th/36011.jpg[/img:3a0jr4pg][/url:3a0jr4pg]
            Or let's use some dividing under windows:
            [url=http://img.gameru.net/?v=c24bb.jpg:3a0jr4pg][img:3a0jr4pg]http://img.gameru.net/th/c24bb.jpg[/img:3a0jr4pg][/url:3a0jr4pg]
            Then we have 4-sided faces again:
            [url=http://img.gameru.net/?v=62060.jpg:3a0jr4pg][img:3a0jr4pg]http://img.gameru.net/th/62060.jpg[/img:3a0jr4pg][/url:3a0jr4pg]
            Sorry for being so talkative πŸ˜„
            ^ So here's the ultimate question: is there a way to fix the triangulation of such areas?
              bac9-flcl
              http://img.gameru.net/th/f6c83.jpg
              Oh, nice, it's internal triangulation 😞
              Should we ask SU team to fix it then?
              SU is heavily oriented for Push/Pull boolean operations which easily produce surfaces with holes, non-convex surfaces and other kinds of complex geometry, so it's very important issue. I don't use Push/Pull for anything complex, but thousands of users do - and it means thousands of SU models have such surfaces. Same as they have zero-area or 4-sided faces bug.
              Maybe it doesn't affect SU and Google Earth performance, but these faces are considered invalid and unacceptable in other 3d software or game engines. For example, I can't use any model with "invalid" faces in X-Ray Engine (S.T.A.L.K.E.R.).
                Here's v1.2 http://forums.sketchucation.com/viewtopic.php?p=175613#p175613
                This should now trap any '4-sided' "triangles" made by the 'mesh' process as it forces an intersection of all new entities and adds edges should a "triangle's" vertices > 3...
                • CadFatherC Offline
                  CadFather
                  Tig,
                  is there anyway to split the resulting triangles as well? suppose you wanted to subdivide the mesh even further (perhaps there is a script already..)
                    @cadfather said:
                    Tig,
                    I think there's a subdivide tool somewhere...
                      CadFather
                      ok (search shows Whaat's SDS)
                        I'm probably thinking of RickW's simpler free tool - referred to here... http://forums.sketchucation.com/viewtopic.php?p=278060#p278060 and available here http://www.smustard.com/script/Subdivide
                          CadFather
                          thanks TIG but that will 'smooth' the shape - i'm only thinking of dividing
                          i think there is the difficulty of internal (read infernal..) faces being generated
                            My Addvertex+ tool http://rhin.crai.archi.fr/rubylibrarydepot/plugin_details.php?id=8
                            lets you add a vertex on a face and divides it into triangles with new edges...
                              CadFather
                              ok TIG, i'll have a look, thanks as always
                                bac9-flcl
                                Thanks a lot! I've finally got my models into X-Ray SDK 😍
                                http://img.gameru.net/th/035c3.jpg
                                http://img.gameru.net/th/583ba.jpg
                                http://img.gameru.net/th/7099f.jpg
                                http://img.gameru.net/th/12959.jpg
                                  jman0war
                                  Hiya,
                                  I downloaded this plugin with the goal of importing my Sketchup models into Unreal Developers Kit (UDK).
                                  But even though the faces are triangled ok, when I import my model in UDK most the triangles are really messed up.
                                  Like this:
                                  http://photos2.pix.ie/E2/45/E2458AAC3155407588F70888B4B391C8-0000316933-0002622418-00800L-6AC7C78B1057411F8E2C7FDD5C50FCC1.jpg
                                  I suppose this doesn't indicate any problem with triangulatefaces.rb, but rather UDK.
                                  Has anybody else tried to this? Would love some advice. πŸŽ‰
                                    Are the normals in the SketchUp model oriented properly?
                                      jman0war
                                      Well, all the white faces are pointed out, if that's what you mean.
                                      I don't think SU offers many options regarding normals.
                                      Do you mean smoothing?
                                      I tried again using a more simple model but results are the same.
                                      Tried toying around with the 2 options in the Soften Edges window, but got the same results.
                                      http://photos3.pix.ie/6F/66/6F66B36E6F514077AF8492334650BE09-0000316933-0002622789-01024L-BA9A361F41C24665A7F2488CC916D358.jpg
                                      http://photos3.pix.ie/81/B4/81B4B45B36564B10A0B88215CE4D824E-0000316933-0002622790-01024L-A57B864FEDBF40F0A23B1A8759AAC34F.jpg
                                      I'm confident people are able to put SU content into UDK, there's another ruby script exporter someone made called "HardPCM", but it produces the same results for me.
                                      So i'm not using that script atm.
                                        This app seems to be smoothing the coplanar edges - they are not smooth in the SKP.
                                        Have you tried switching off its 'preserve smooth groups' options etc?
                                          jman0war
                                          nice observation!
                                          I turned the quality slider down to 0 and found an option in the drop-down box that gives a better result.
                                          Not flawless though.
                                          It's one for the UDK forums at any rate.
                                          Thanks for the help.
                                          http://photos2.pix.ie/E3/86/E386BE5F37954E63A329630A03C1073A-0000316933-0002624300-01200L-CCE185660BE54D6D91F85CDBFB76ECD1.jpg
                                            mustafashredder
                                            @TIG
                                            Could you please post a download link to the .rbz file for your script. I cant load .rb file and it wont show up in sketchup when I copy the .rb file to the directory.
                                            • 5 / 5
