    PolygonMesh behavior
    34 Posts 7 Posters 4.3k Views 7 Watching
      soldatino
      Error 404 (Not Found)!!1
      (code.google.com)
      but this is about points "particular index in the mesh."
      Or it is for each face? In this case I have to calculate each angle between vertexes of adjacent faces?
      Anyway the vector that I get is 0,0,0, but the faces have smooting in SU.
      http://sketchup.google.com/support/bin/answer.py?hl=it&answer=114941
      the procedure is explained in the yellow window..
      r3nDer tools
        I think "particular index in the mesh." refer to the index of polygons.
        Normals in SketchUp does not relate the smoothing. Normals are always perpendicular to the face/polygon.
        To find out of the mesh has smooth edges use PolygonMesh.polygon_at http://code.google.com/intl/it/apis/sketchup/docs/ourdoc/polygonmesh.html#polygon_at or PolygonMesh.polygons http://code.google.com/intl/it/apis/sketchup/docs/ourdoc/polygonmesh.html#polygons
          soldatino
          yes, thanks, pointing at the face I get the float values of the vector.
          Now if it is a offset valid for all the points of each face, I have to find the common points of adjacent faces, and interpolate their offsets to get the vector for the points. A lot of work... do yo think it is right?
          r3nDer tools
            Think so - SU doesn't provide vertex normals.
            When I wrote Vertex Tools I have to work them out manually from the connected faces.
              Look at a vertex.
              Get its faces.
              Get the normals of the faces [lets say there are 3 of them].
              Combine the faces' normals [vectors] using v = v1 + v2 + v3
              Now 'v' should be the combined-vector at that vertex [the vertex-normal?]...
              Test it using entities.add_line(vertex.position,v.to_a)
              which should draw a line at the vertex along the direction of the combined-vector 'v'...
                soldatino
                thomthom, TIG, thanks. I will attempt to write this in Ruby, even if I dont know much of this language, to do it with a post editor would be very easy, storing the array of all the normals of every face as comments within the ouput of the points ...
                note: Vertex.used_by? in a loop of all connected faces ? waiting for the eternity...
                r3nDer tools
                    soldatino
                    @thomthom said:
                    I am worried because I think that with large model the time required will be huge.
                    Addictionally I would not repeat the calculation for the same point when the loop scans the already involved faces, but if I do not want to repeat I have to save an array for all the entities, containing normals already calculated, and to scan it also, which could be worse...
                    r3nDer tools
                      What are you doing? An exporter?
                        <span class="syntaxdefault"><br />&nbsp;&nbsp;</span><span class="syntaxkeyword">for&nbsp;</span><span class="syntaxdefault">eachvrtx&nbsp;in&nbsp;0.</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">numvrtx&nbsp;</span><span class="syntaxkeyword">do<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">x&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">mesh</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">point_at</span><span class="syntaxkeyword">((</span><span class="syntaxdefault">vertices</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">eachvrtx</span><span class="syntaxkeyword">]).</span><span class="syntaxdefault">abs</span><span class="syntaxkeyword">).</span><span class="syntaxdefault">x</span><span class="syntaxkeyword">*</span><span class="syntaxdefault">RatioPov<br />&nbsp;&nbsp;&nbsp;&nbsp;y&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">mesh</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">point_at</span><span class="syntaxkeyword">((</span><span class="syntaxdefault">vertices</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">eachvrtx</span><span class="syntaxkeyword">]).</span><span class="syntaxdefault">abs</span><span class="syntaxkeyword">).</span><span class="syntaxdefault">y</span><span class="syntaxkeyword">*</span><span class="syntaxdefault">RatioPov<br />&nbsp;&nbsp;&nbsp;&nbsp;z&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">mesh</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">point_at</span><span class="syntaxkeyword">((</span><span class="syntaxdefault">vertices</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">eachvrtx</span><span class="syntaxkeyword">]).</span><span class="syntaxdefault">abs</span><span class="syntaxkeyword">).</span><span class="syntaxdefault">z</span><span class="syntaxkeyword">*</span><span class="syntaxdefault">RatioPov<br /></span>
                        Change into this
                        <span class="syntaxdefault"><br />&nbsp;&nbsp;</span><span class="syntaxkeyword">for&nbsp;</span><span class="syntaxdefault">eachvrtx&nbsp;in&nbsp;0.</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">numvrtx&nbsp;</span><span class="syntaxkeyword">do<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">pt&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">mesh</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">point_at</span><span class="syntaxkeyword">((</span><span class="syntaxdefault">vertices</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">eachvrtx</span><span class="syntaxkeyword">]).</span><span class="syntaxdefault">abs</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">x&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">pt</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">x</span><span class="syntaxkeyword">*</span><span class="syntaxdefault">RatioPov<br />&nbsp;&nbsp;&nbsp;&nbsp;y&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">pt</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">y</span><span class="syntaxkeyword">*</span><span class="syntaxdefault">RatioPov<br />&nbsp;&nbsp;&nbsp;&nbsp;z&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">pt</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">z</span><span class="syntaxkeyword">*</span><span class="syntaxdefault">RatioPov<br /></span>
                        Should be a little bit faster.
                          soldatino
                          This is a part of my exporter to POV-Ray. Yes, now I apply your suggestion !
                          r3nDer tools
                            soldatino
                            17/11/2010 10:03:00
                            //Ending at 17/11/2010 10:03:18
                            17/11/2010 10:09:00
                            //Ending at 17/11/2010 10:09:18
                            28935 faces
                            Later I will check on largest files...
                            r3nDer tools
                            • T
                              tomasz
                              You are wrong Thomas!
                              Check this :
                              polygonmesh.normal_at(vertex_index)
                              Soldatino, your exporter will work faster now 😄
                              I think that is what you have been looking for, unless you want to do vertex welding.
                                Check this :
                                From the docs I see nothing that indicate vertex index. http://code.google.com/apis/sketchup/docs/ourdoc/polygonmesh.html#normal_at
                                Saying that - it doesn't even say if it's polygon index.
                                Tomaz: you got a working example?
                                • T
                                  tomasz
                                  @thomthom said:
                                  Toma**s**z: you got a working example?
                                  Yep. SU2TH 😄
                                  You have to extract a triangle indexes using
                                  tri_indexes=polygonmesh.polygon_at(mesh_index)
                                  and then
                                  normal0=tri.normal_at(tri_indexes[0]) normal1=tri.normal_at(tri_indexes[1]) normal2=tri.normal_at(tri_indexes[2])
                                  The docs are .... terribly bad, you know that you can't rely on them 😄
                                  Now you know how to use it and speed-up your plugins.
                                  EDITED. I was terribly wrong 😄 It is correct now.
                                    I can't get it working...
                                    • T
                                      tomasz
                                      Do not count_points, count_polygons instead.
                                      1 .. mesh.count_polygons
                                      then
                                      tri_indexes=mesh.polygon_at(i)
                                      (0..2).each{|q| p mesh.normal_at(tri_indexes[q])}
                                      EDIT.
                                      use mesh 7 to ensure you get also normals. Doc doesn't say what is a default flag.
                                        But when you do 1 .. mesh.count_polygons you iterate over the polygons. And mesh.polygon_at(i) returns an array of point (vertex) indexes - which are the same indexes you get when you iterate mesh.count_points...
                                          EDIT.
                                          Ah! Yes - of course. Now I get normals.
                                          • T
                                            tomasz
                                            Correct. They are same indexes, but now they define a triangle. In exporter you usually export triangles not a cloud of points...
                                            Have you used mesh(7)? Maybe this is why it returns Vector3d(0,0,0) instead of Vector3d(0,-1,0)?
