    PolygonMesh behavior
    34 Posts 7 Posters 3.9k Views 7 Watching
      This is odd...
      Are you saying that the face normal doesn't depend on the order which the vertices of the PolygonMesh is added?
      When you say it produces a smooth face - in SU? Or in the app that imports the OBJ you export?
      AFIK, the only way to smooth a PolygonMesh was to specify Soft+Smooth when you add the mesh to the model. I've not seen any methods of smoothing individual polygons in a mesh - though I'd very much like to have that control.
      • mitcorbM
        mitcorb
        Pardon my eavesdropping, but exactly how would I visualize a vertex normal? I can visualize a face normal, even an edge normal under some conditions. Or is it sort of like a tesseract?
          I did that for Vertex Tools, I take the average normal of the faces connected to the vertex.
          • AdamBA
            AdamB
            You're missing a step with your averaging there. You need to weight by the contribution each face connected to the vertex makes - ie weight by the interior angle otherwise a cube constructed of triangles will end up with vertex normals not all pointing out exactly at 45 degrees.
              soldatino
              I am sorry but I use this topic because it seems to be about my question.
              I make a solid using the help example for smooth surfaces (6 sides), then I push for the elevation, then I select all the object, then I apply Soften edges angle 79,0 degrees, and the edge appear soft.
              But if I get the normals at each point I read always (0, 0, 0), that is not a valid vector.
              Sorry, where I am wrong?
              for np in 1..numpol do
                vertices=mesh.polygon_at np
                numvrtx=vertices.length - 1
                for eachvrtx in 0..numvrtx do
                  x = mesh.point_at((vertices[eachvrtx]).abs).x*RatioPov
                  y = mesh.point_at((vertices[eachvrtx]).abs).y*RatioPov
                  z = mesh.point_at((vertices[eachvrtx]).abs).z*RatioPov
                  nx = mesh.normal_at (eachvrtx+1) #index is base 1
                  UI.messagebox(nx.to_s)
              r3nDer tools
                Which example?
                I think that .normal_at( index ) refer to the normal of a polygon - not point...
                  soldatino
                  Error 404 (Not Found)!!1
                  (code.google.com)
                  but this is about points "particular index in the mesh."
                  Or it is for each face? In this case I have to calculate each angle between vertexes of adjacent faces?
                  Anyway the vector that I get is 0,0,0, but the faces have smooting in SU.
                  http://sketchup.google.com/support/bin/answer.py?hl=it&answer=114941
                  the procedure is explained in the yellow window..
                  r3nDer tools
                    I think "particular index in the mesh." refer to the index of polygons.
                    Normals in SketchUp does not relate the smoothing. Normals are always perpendicular to the face/polygon.
                    To find out of the mesh has smooth edges use PolygonMesh.polygon_at http://code.google.com/intl/it/apis/sketchup/docs/ourdoc/polygonmesh.html#polygon_at or PolygonMesh.polygons http://code.google.com/intl/it/apis/sketchup/docs/ourdoc/polygonmesh.html#polygons
                      soldatino
                      yes, thanks, pointing at the face I get the float values of the vector.
                      Now if it is a offset valid for all the points of each face, I have to find the common points of adjacent faces, and interpolate their offsets to get the vector for the points. A lot of work... do yo think it is right?
                      r3nDer tools
                        Think so - SU doesn't provide vertex normals.
                        When I wrote Vertex Tools I have to work them out manually from the connected faces.
                          Look at a vertex.
                          Get its faces.
                          Get the normals of the faces [lets say there are 3 of them].
                          Combine the faces' normals [vectors] using v = v1 + v2 + v3
                          Now 'v' should be the combined-vector at that vertex [the vertex-normal?]...
                          Test it using entities.add_line(vertex.position,v.to_a)
                          which should draw a line at the vertex along the direction of the combined-vector 'v'...
                            soldatino
                            thomthom, TIG, thanks. I will attempt to write this in Ruby, even if I dont know much of this language, to do it with a post editor would be very easy, storing the array of all the normals of every face as comments within the ouput of the points ...
                            note: Vertex.used_by? in a loop of all connected faces ? waiting for the eternity...
                            r3nDer tools
                                soldatino
                                @thomthom said:
                                I am worried because I think that with large model the time required will be huge.
                                Addictionally I would not repeat the calculation for the same point when the loop scans the already involved faces, but if I do not want to repeat I have to save an array for all the entities, containing normals already calculated, and to scan it also, which could be worse...
                                r3nDer tools
                                  What are you doing? An exporter?
                                    <span class="syntaxdefault"><br />&nbsp;&nbsp;</span><span class="syntaxkeyword">for&nbsp;</span><span class="syntaxdefault">eachvrtx&nbsp;in&nbsp;0.</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">numvrtx&nbsp;</span><span class="syntaxkeyword">do<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">x&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">mesh</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">point_at</span><span class="syntaxkeyword">((</span><span class="syntaxdefault">vertices</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">eachvrtx</span><span class="syntaxkeyword">]).</span><span class="syntaxdefault">abs</span><span class="syntaxkeyword">).</span><span class="syntaxdefault">x</span><span class="syntaxkeyword">*</span><span class="syntaxdefault">RatioPov<br />&nbsp;&nbsp;&nbsp;&nbsp;y&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">mesh</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">point_at</span><span class="syntaxkeyword">((</span><span class="syntaxdefault">vertices</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">eachvrtx</span><span class="syntaxkeyword">]).</span><span class="syntaxdefault">abs</span><span class="syntaxkeyword">).</span><span class="syntaxdefault">y</span><span class="syntaxkeyword">*</span><span class="syntaxdefault">RatioPov<br />&nbsp;&nbsp;&nbsp;&nbsp;z&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">mesh</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">point_at</span><span class="syntaxkeyword">((</span><span class="syntaxdefault">vertices</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">eachvrtx</span><span class="syntaxkeyword">]).</span><span class="syntaxdefault">abs</span><span class="syntaxkeyword">).</span><span class="syntaxdefault">z</span><span class="syntaxkeyword">*</span><span class="syntaxdefault">RatioPov<br /></span>
                                    Change into this
                                    <span class="syntaxdefault"><br />&nbsp;&nbsp;</span><span class="syntaxkeyword">for&nbsp;</span><span class="syntaxdefault">eachvrtx&nbsp;in&nbsp;0.</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">numvrtx&nbsp;</span><span class="syntaxkeyword">do<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">pt&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">mesh</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">point_at</span><span class="syntaxkeyword">((</span><span class="syntaxdefault">vertices</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">eachvrtx</span><span class="syntaxkeyword">]).</span><span class="syntaxdefault">abs</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">x&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">pt</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">x</span><span class="syntaxkeyword">*</span><span class="syntaxdefault">RatioPov<br />&nbsp;&nbsp;&nbsp;&nbsp;y&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">pt</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">y</span><span class="syntaxkeyword">*</span><span class="syntaxdefault">RatioPov<br />&nbsp;&nbsp;&nbsp;&nbsp;z&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">pt</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">z</span><span class="syntaxkeyword">*</span><span class="syntaxdefault">RatioPov<br /></span>
                                    Should be a little bit faster.
                                      soldatino
                                      This is a part of my exporter to POV-Ray. Yes, now I apply your suggestion !
                                      r3nDer tools
                                        soldatino
                                        17/11/2010 10:03:00
                                        //Ending at 17/11/2010 10:03:18
                                        17/11/2010 10:09:00
                                        //Ending at 17/11/2010 10:09:18
                                        28935 faces
                                        Later I will check on largest files...
                                        r3nDer tools
                                        • T
                                          tomasz
                                          You are wrong Thomas!
                                          Check this :
                                          polygonmesh.normal_at(vertex_index)
                                          Soldatino, your exporter will work faster now 😄
                                          I think that is what you have been looking for, unless you want to do vertex welding.
                                            Check this :
                                            From the docs I see nothing that indicate vertex index. http://code.google.com/apis/sketchup/docs/ourdoc/polygonmesh.html#normal_at
                                            Saying that - it doesn't even say if it's polygon index.
                                            Tomaz: you got a working example?
