    PolygonMesh behavior
    34 Posts 7 Posters 3.1k Views 7 Watching
    • mitcorbM Offline
      mitcorb
      Pardon my eavesdropping, but exactly how would I visualize a vertex normal? I can visualize a face normal, even an edge normal under some conditions. Or is it sort of like a tesseract?
        I did that for Vertex Tools, I take the average normal of the faces connected to the vertex.
        • AdamBA Offline
          AdamB
          You're missing a step with your averaging there. You need to weight by the contribution each face connected to the vertex makes - ie weight by the interior angle otherwise a cube constructed of triangles will end up with vertex normals not all pointing out exactly at 45 degrees.
            soldatino
            I am sorry but I use this topic because it seems to be about my question.
            I make a solid using the help example for smooth surfaces (6 sides), then I push for the elevation, then I select all the object, then I apply Soften edges angle 79,0 degrees, and the edge appear soft.
            But if I get the normals at each point I read always (0, 0, 0), that is not a valid vector.
            Sorry, where I am wrong?
            for np in 1..numpol do
              vertices=mesh.polygon_at np
              numvrtx=vertices.length - 1
              for eachvrtx in 0..numvrtx do
                x = mesh.point_at((vertices[eachvrtx]).abs).x*RatioPov
                y = mesh.point_at((vertices[eachvrtx]).abs).y*RatioPov
                z = mesh.point_at((vertices[eachvrtx]).abs).z*RatioPov
                nx = mesh.normal_at (eachvrtx+1) #index is base 1
                UI.messagebox(nx.to_s)
            r3nDer tools
              Which example?
              I think that .normal_at( index ) refer to the normal of a polygon - not point...
                soldatino
                Error 404 (Not Found)!!1
                (code.google.com)
                but this is about points "particular index in the mesh."
                Or it is for each face? In this case I have to calculate each angle between vertexes of adjacent faces?
                Anyway the vector that I get is 0,0,0, but the faces have smooting in SU.
                http://sketchup.google.com/support/bin/answer.py?hl=it&answer=114941
                the procedure is explained in the yellow window..
                r3nDer tools
                  I think "particular index in the mesh." refer to the index of polygons.
                  Normals in SketchUp does not relate the smoothing. Normals are always perpendicular to the face/polygon.
                  To find out of the mesh has smooth edges use PolygonMesh.polygon_at http://code.google.com/intl/it/apis/sketchup/docs/ourdoc/polygonmesh.html#polygon_at or PolygonMesh.polygons http://code.google.com/intl/it/apis/sketchup/docs/ourdoc/polygonmesh.html#polygons
                    soldatino
                    yes, thanks, pointing at the face I get the float values of the vector.
                    Now if it is a offset valid for all the points of each face, I have to find the common points of adjacent faces, and interpolate their offsets to get the vector for the points. A lot of work... do yo think it is right?
                    r3nDer tools
                      Think so - SU doesn't provide vertex normals.
                      When I wrote Vertex Tools I have to work them out manually from the connected faces.
                        Look at a vertex.
                        Get its faces.
                        Get the normals of the faces [lets say there are 3 of them].
                        Combine the faces' normals [vectors] using v = v1 + v2 + v3
                        Now 'v' should be the combined-vector at that vertex [the vertex-normal?]...
                        Test it using entities.add_line(vertex.position,v.to_a)
                        which should draw a line at the vertex along the direction of the combined-vector 'v'...
                          soldatino
                          thomthom, TIG, thanks. I will attempt to write this in Ruby, even if I dont know much of this language, to do it with a post editor would be very easy, storing the array of all the normals of every face as comments within the ouput of the points ...
                          note: Vertex.used_by? in a loop of all connected faces ? waiting for the eternity...
                          r3nDer tools
                              soldatino
                              @thomthom said:
                              I am worried because I think that with large model the time required will be huge.
                              Addictionally I would not repeat the calculation for the same point when the loop scans the already involved faces, but if I do not want to repeat I have to save an array for all the entities, containing normals already calculated, and to scan it also, which could be worse...
                              r3nDer tools
                                What are you doing? An exporter?
                                  <span class="syntaxdefault"><br />&nbsp;&nbsp;</span><span class="syntaxkeyword">for&nbsp;</span><span class="syntaxdefault">eachvrtx&nbsp;in&nbsp;0.</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">numvrtx&nbsp;</span><span class="syntaxkeyword">do<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">x&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">mesh</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">point_at</span><span class="syntaxkeyword">((</span><span class="syntaxdefault">vertices</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">eachvrtx</span><span class="syntaxkeyword">]).</span><span class="syntaxdefault">abs</span><span class="syntaxkeyword">).</span><span class="syntaxdefault">x</span><span class="syntaxkeyword">*</span><span class="syntaxdefault">RatioPov<br />&nbsp;&nbsp;&nbsp;&nbsp;y&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">mesh</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">point_at</span><span class="syntaxkeyword">((</span><span class="syntaxdefault">vertices</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">eachvrtx</span><span class="syntaxkeyword">]).</span><span class="syntaxdefault">abs</span><span class="syntaxkeyword">).</span><span class="syntaxdefault">y</span><span class="syntaxkeyword">*</span><span class="syntaxdefault">RatioPov<br />&nbsp;&nbsp;&nbsp;&nbsp;z&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">mesh</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">point_at</span><span class="syntaxkeyword">((</span><span class="syntaxdefault">vertices</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">eachvrtx</span><span class="syntaxkeyword">]).</span><span class="syntaxdefault">abs</span><span class="syntaxkeyword">).</span><span class="syntaxdefault">z</span><span class="syntaxkeyword">*</span><span class="syntaxdefault">RatioPov<br /></span>
                                  Change into this
                                  <span class="syntaxdefault"><br />&nbsp;&nbsp;</span><span class="syntaxkeyword">for&nbsp;</span><span class="syntaxdefault">eachvrtx&nbsp;in&nbsp;0.</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">numvrtx&nbsp;</span><span class="syntaxkeyword">do<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">pt&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">mesh</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">point_at</span><span class="syntaxkeyword">((</span><span class="syntaxdefault">vertices</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">eachvrtx</span><span class="syntaxkeyword">]).</span><span class="syntaxdefault">abs</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">x&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">pt</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">x</span><span class="syntaxkeyword">*</span><span class="syntaxdefault">RatioPov<br />&nbsp;&nbsp;&nbsp;&nbsp;y&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">pt</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">y</span><span class="syntaxkeyword">*</span><span class="syntaxdefault">RatioPov<br />&nbsp;&nbsp;&nbsp;&nbsp;z&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">pt</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">z</span><span class="syntaxkeyword">*</span><span class="syntaxdefault">RatioPov<br /></span>
                                  Should be a little bit faster.
                                    soldatino
                                    This is a part of my exporter to POV-Ray. Yes, now I apply your suggestion !
                                    r3nDer tools
                                      soldatino
                                      17/11/2010 10:03:00
                                      //Ending at 17/11/2010 10:03:18
                                      17/11/2010 10:09:00
                                      //Ending at 17/11/2010 10:09:18
                                      28935 faces
                                      Later I will check on largest files...
                                      r3nDer tools
                                        tomasz
                                        You are wrong Thomas!
                                        Check this :
                                        polygonmesh.normal_at(vertex_index)
                                        Soldatino, your exporter will work faster now 😄
                                        I think that is what you have been looking for, unless you want to do vertex welding.
                                          Check this :
                                          From the docs I see nothing that indicate vertex index. http://code.google.com/apis/sketchup/docs/ourdoc/polygonmesh.html#normal_at
                                          Saying that - it doesn't even say if it's polygon index.
                                          Tomaz: you got a working example?
                                            tomasz
                                            @thomthom said:
                                            Toma**s**z: you got a working example?
                                            Yep. SU2TH 😄
                                            You have to extract a triangle indexes using
                                            tri_indexes=polygonmesh.polygon_at(mesh_index)
                                            and then
                                            normal0=tri.normal_at(tri_indexes[0]) normal1=tri.normal_at(tri_indexes[1]) normal2=tri.normal_at(tri_indexes[2])
                                            The docs are .... terribly bad, you know that you can't rely on them 😄
                                            Now you know how to use it and speed-up your plugins.
                                            EDITED. I was terribly wrong 😄 It is correct now.
