    1.5k Posts 471 Posters 3.3m Views 470 Watching
    • jeff hammondJ Offline
      Hi all,
      Any upadte on this topic? Still have the same problem.
      Thanks julien
      I'm a bit confused because I use the plugin on three different macs (with various SU versions and operating systems) and have never had a problem with it.
      Fredo, can you think of any reasons why this may be happening to some people and not others such as conflicting plugins?
        hey julien.
        i do notice a slight delay in response with RoundCorner (though it's very slight.. nothing like you describe)
        as shown in this screenshot:
        does that speed things up for you? (you can still access the RoundCorner parameters with the palette closed by pushing the tab key)
        also:
        i noticed in your ruby warning that you're installing plugins in your user library..
        /Users/Ju/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/ROUNDCORNER_Dir_21/RoundCorner_Algo.rb:1186: warning: Object#id will be deprecated; use Object#object_id
        this used to cause a lot of problems on macs but most of the plugin writers have done something to fix it (there are still a few problem rubies out there)
        google instructs to install rubies in the system library:
        http://code.google.com/apis/sketchup/docs/loading.html
        that's where their sample rubies etc are upon a fresh SU install (did you create the user/plugin folder on your own?)
        here's a little automator app that will fix your install location:
        su7 and su8 version included..
        just double click the specific version(s) you have on your machine.
        it simply moves all the files out of your User/Library/Application Support/Google SketchUp 8/SketchUp/plugins folder ...
        and into the proper location of
        Macintosh HD/Library/Application Support/Google SketchUp 8/SketchUp/plugins ...then deletes the empty user plugin folder..
        you can do this manually if you choose but it should be done.. i don't necessarily think it will fix your RoundCorner problems but it will prevent problems down the road..
        • JujuSKPJ Offline
          JujuSKP Extension Creator
          Hi Jeff,
          Thanks for your reply, I'll check that and come back to you.
          Julien
          • fredo6F Offline
            Hi Jeff,
            Julien
            Julien,
            What I can do is to prepare a file with traces that you can run. The issue seems to be in the Palette drawing, but I don't see why it can take so long.
            • JujuSKPJ Offline
              Jeff,
              I have try to shrink the palette, but does respond for me (still same problem).
              However, I change the plugins folder as mention, and try out the roundcorner plugin. I still have the problem, but it responds a little more better.
              First improvement, we are on the good way -)
              Thanks julien
              • Z Offline
                Zacchia
                This is really a helpful plugin, with it it is easy to create sofas! Thanks a lot to give this for free!!
                  sasa
                  hi fredo
                  i can see that other people had succeeded installing and using the roundcorner plugin
                  i've extracted the folders into the plugin file and put it by the order u mentioned
                  when i tried to open the sketchup i'v got errors :
                  Error Loading File ZLoader__RoundCorner.rb
                  uninitialized constant LibFredo6::Traductor
                  i'm a mac user and i would be more than happy to have a solution !!
                  • fredo6F Offline
                    Sasa,
                    I think you forgot to install LibFredo6, which is a shared library used by my plugins.
                    see http://forums.sketchucation.com/viewtopic.php?f=323&t=17947&hilit=plugin
                    • 3 Offline
                      3D Sloth
                      Ok, so I have to wait for the next release?
                      I am sorry but I am not using Windows anymore -)
                      I was used to work with sketchup 7 and the round corner plugin without any problems.
                      I have download and install curviloft, it works really fine and quick.
                      I have retry roundcorner, still having the same problem.
                      thanks fredo
                      Then, it would be helpful if other Mac users could tell if they have similar performance issues.
                      Sure thing, I'm having exactly the same problem as JujuSkp. Just got pointed towards this thread for this!
                      • N Offline
                        N3MES1S
                        @cst said:
                        Fredo:
                        I use Mac OS 10.6 and SketchUp 8.
                        I have dropped RoundCorner%202 & LibFredo6%203 into the
                        plugins folder which is nested in the
                        Sketchup folder which is nested in the
                        Google SketchUp 8 folder which nested in the
                        Application Support folder which is nested in the
                        Library folder which is nested in the
                        Hard Drive icon
                        When I start up SketchUp 8 I see no new tools in the Tools drop-down menu.
                        Please tell me what I've done wrong.
                        Thank you
                        Cliff
                        cliff, those are the folders you're left with upon unzipping.. you have to open those folders to get to these files:
                        %(#FF0000)[ROUNDCORNER_Dir_21
                        ZLoader__RoundCorner.rb]
                        and
                        %(#FF0000)[LIBFREDO6_Dir_34
                        LibFredo6.rb]
                        those four items go in the plugins folder at the same path you stated in your post.
                        Hi, awesome plugin, a shame i cant get it to work. I placed the folders and the files under the plugins folder, as u say, there are 2 folders, the roundcorner plugin folder and the libfredo library folder. And 2 files, the roundcorner plugin file and the libfredo library file. But i cant see anything about the plugin in sketchup, neither in preferences neither in the context menu. Is this plugin working for sketchup 8.0 ???
                          LiveView
                          [b]RoundCorner performs the rounding of the edges and corners of 3D shapes along a 2D profile, in 3 modes: Round corners, Sharp corners and Bevel.
                          Hi Fredo6 ! πŸ˜„
                          This ruby made a strong impression on me ! It's very very very useful !
                          I have a small idea, could you resolve it ?
                          Image link broken, browser stalls thus link removed (poster never came back anyway).
                          Many thanks ! πŸ˜„
                            akigrimm
                            Hi Fredo
                            I desperately try to install your plugin, but I must have done something wrong: In the Sketchup 7.1 pro i put in the plugin folder:
                            LIBFREDO6_Dir_35
                            ROUNDCORNER_Dir_21
                            LibFredo6.rb
                            When starting SU it prompts:
                            uninitialized constant Traductor::Plugin
                            Why could that be?
                            Thanks for the help
                            • fredo6F Offline
                              HI,
                              For some reasons (may be the unzip operation), you do not have th right footprint and LibFredo6 has not been loaded.
                              I suggest you check again.
                              • I Offline
                                Ike
                                I am having similar problems installing this plugin.
                                Has anybody been successful installing it and using on a Mac.
                                If there is, can someone please send a screenshot of the hireacy
                                of the plugins folder so, we can have a visual reference
                                Your help is very much appreciated
                                Ike
                                • V Offline
                                  Vicspa
                                  The plugin I use the most.
                                  Thanks so much
                                    @ike said:
                                    Ike
                                    Ike,
                                    here's a mac installer for round corner which will work with su7 & 8
                                    http://web.me.com/jeffhammond/su/RoundCorner.zip
                                    • I Offline
                                      Ike
                                      @ike said:
                                      Ike
                                      Ike,
                                      That was easy πŸ˜„
                                      Thanks Jeff, I am so grateful
                                      Ike
                                      • StinkieS Offline
                                        Stinkie
                                        Does anyone know how the max amount of, er, bevel segments (? sorry - not a native speaker) can be upped? Currently the maximum amount is 30. I've been going through the code, but truth be told, I'm not much of a coder. πŸ˜„
                                        Help me out, and I'll send you gold, and curvy blondes. Really.
                                        • utilerU Offline
                                          utiler
                                          Hey stinkie, i don't know code either but you got me interested......!
                                          Just Curious...
                                            Look inside **RoundCorner_Commom.rb** find the line #150
                                            MYDEFPARAM.declare_:DEFAULT_Flag_Numseg, 6, 'I:>0<****30****'
                                            and change the 30 to something else like 72 [that's what I have mine set to]...
                                            Then in **RoundCorner_Tool.rb** find line #346
                                            @dlgall.field_numeric "num_seg", T6[:DLG_All_Numseg], 6, 1, ****30****
                                            and change the 30 to match - like 72...
                                            and line #1032 find
                                            if numseglock || numseg <= 0 || numseg > ****30****
                                            PM me about the delivery address πŸ˜‰
                                            • 73
                                            • 74
                                            • 8 / 74
