    Method for drawing an antiprism with equilateral sides
    35 Posts 7 Posters 4.8k Views 7 Watching
      sketchup_roolz
      http://img813.imageshack.us/img813/9940/240pxsquareantiprism.png
      http://en.wikipedia.org/wiki/Square_antiprism
      I can easily create a version of this by rotating the top face of a cube by 45ยฐ and tweaking a few lines.
      However the resulting triangles are not equilateral, which is what I'm after.
      Any ideas?
      *PS
      Anyone know a way to construct polygons in SketchUp starting only with their "Nets".
      Without knowing the specific folding angle I haven't been able to do this precisely.
      http://img683.imageshack.us/img683/2056/netz.png
      • TIGT Online
          seven decimals of ยฐ ๐Ÿ˜ฒ
          That is precision ๐Ÿ’š
          • honoluludesktopH Offline
            honoluludesktop
            I think this is a way to do it without calculations, but because sketchup arcs are polygons, its impossible to do a perfectly accurate projection.Temp00.PNGI used a default arc (12 sides), if you did one with (say) 256 sides, you could get closer.
            • TIGT Online
              I didn't do calculations either [except for the angle that I added]...
              You'll need a Circle with 1000 sides and then just draw/group/copy/rotate stuff... see the 'Steps' illustration...
              [I removed the illustration here in favor the the 'steps' set - see the next few posts along...]
                sketchup_roolz
                Thanks for the detailed reply Tig. ๐Ÿค“
                Unfortunately I'm having trouble figuring out the proper sequence of steps to follow your instructions. ๐Ÿ˜ณ
                  sketchup_roolz
                  Hey what happened to all those steps you wrote out Tig? ๐Ÿ˜‰
                  Anyway I guess the circle approximation is the best we can do...
                  Thanks everyone
                  • TIGT Online
                    It works for any size 'cube'...
                      dedmin
                      TIG - This Is Google
                      ๐ŸŽ‰ ๐ŸŽ‰ ๐ŸŽ‰
                      • TIGT Online
                          sketchup_roolz
                          Thanks Tig. You're a genius. ๐Ÿ˜Ž
                            sketchup_roolz
                            woops! ๐Ÿ˜ณ
                            • TIGT Online
                              @sketchup_roolz said:
                              Not that anyone cares anymore but here's a my proper 2D method...
                              http://img573.imageshack.us/img573/272/68861221.png
                              I fixed your faulty link...
                              An interesting alternative approach... ๐Ÿ˜„
                              I am thinking how it might get converted to an 'algorithm'...
                              Which must be possible as it involves 45/30/15 degree triangles with known side length...
                              Sleeping on it now... ๐Ÿ˜‰
                                sketchup_roolz
                                  sketchup_roolz
                                  Very clever Jeff. ๐Ÿค“
                                  Much appreciation for all the hard work here.
                                  I don't really have a practical need to get this level of precision/accuracy but problems like this totally consume me.
                                  I figured the faster I could figure it out it the sooner I could move on to more important things! (or not)
                                  SketchUp is an amazing piece of software and maybe one day I'll have a more concrete use for it. ๐Ÿ’š
                                    Why anybody save the SKP file "save as SU6"?
                                    Like this anybody can reload easily any file! ๐Ÿ˜„
                                      PS :How many triangles must have the polyedra?
                                      On the first post there are 8 on "the plan"
                                      On the Xray Tig volume there are 7 ! ๐Ÿ˜ฎ
                                      Won't the file lose some of its v7, and v8 features. Did v6 have "dynamic components", etc.?
                                      there are rarelly dynamic component in "hard geometry" like in this post or exotic functions ๐Ÿ˜„
                                        honoluludesktop
                                        Like this anybody can reload easily any file! ๐Ÿ™‚
                                        Btw, am I sticking my foot in my mouth? I didn't read all of the posts.
                                        • jeff hammondJ Offline
                                          oops, i try to remember to do this prior to uploading at scf but i just forget sometimes ๐Ÿ˜„
                                          i added a v6 file to my earlier post
                                            honoluludesktop
