    [Plugin] Mirror
    211 Posts 72 Posters 485.8k Views 72 Watching
    • OxerO
      Oxer
      I have found the error!
      There is a conflict with SketchyPhisics 3.1, remember i work on Mac OSX.
      Excuse me, it not was a problem in the plugin there were a conflict.
      Thanks TIG¡¡
        It's no problem for me! Now it's no problem for you!
        ¡No hay problema para mí! ¡Ahora no es problema para ti!
        • G
          glro
          Thanks TIG¡¡
          i use windows XP SP3, and i noticed also a conflict between Mirror and Sketchyphysics3
          too bad, we'll have to choose between 2 excellent plugins...
          • cottyC
            cotty
            Thanks TIG¡¡
            Is there a solution to solve this conflict?
            my SketchUp gallery
              Here's v3.4 with some more code tweaks that might stop bugs...
              http://forums.sketchucation.com/viewtopic.php?p=276512#p276512
              • kenK
                ken
                I know this is an operator error. I have noticed if you press the delete key instead of the return, the plugin crashes. Is there a way to capture the delete key so it will not crash Sketchup.
                Yes, I know I should be more careful.
                Thank you for your plugin
                Ken
                  DIEGO-RODRIGUEZ
                  tig thanks for this new update.
                  but unfortunately continues to generate bugplat when ouliner window this open, and make mirror for a group or component.
                  use sketchup 8, windows xp sp3
                    It should roll up the Outliner in Windows ? 😕
                      davidlouis
                      I have replaced an archaic version of the Mirror tool with your new one and see that the right mouse context choice is now gone and only the icon in the toolbar is there. Could you please re-intoduce the necessary lines in the code to enable it to appear in the context menu....
                      Sorry but i am a creature of habit and the use of the icon interrupts my usual workflow...
                      Thanks in advance.
                      Dave
                        @davidlouis said:
                        I have replaced an archaic version of the Mirror tool with your new one and see that the right mouse context choice is now gone and only the icon in the toolbar is there. Could you please re-introduce the necessary lines in the code to enable it to appear in the context menu....
                        Thanks in advance.
                        Dave
                        Sorry about that...
                        I disabled it temporarily whilst I was doing something else!
                        Here's v3.5 that has it reintroduced...
                        • B
                          budz
                          thanks for sharing a great plugins like this sir,..
                          • L
                            LannorMov
                            Tig: Thanks for that gift so beautiful. I'm using a lot and it works well.
                              Dominance
                              thanks for your sharing
                              • dereiD
                                derei
                                @TIG: Could you make some loader for this ? I would like to have a folder with "MI.png, Mirror.rb and toggleWindows.rb" and a Mirror_loader.rb (or similar). Win32API.so I thinks it's best to stay in Plugins folder, as it is used by more plugins.
                                Thanks a lot.
                                DESIGNER AND ARTIST DEREI.UK
                                  Thanks a lot.
                                  If you want to move files you need to rewrite the menu/toolbar part of their code to ensure the files are found in the new sub-folder.
                                  A loader is a simply a file in the ../Plugins/ folder called perhaps myloader.rb containing this line of code
                                  load "mysubfolder/myscript.rb"
                                  The line can be repeated for multiple files to be loaded...
                                  Where mysubfolder is a folder in ../Plugins/ containing the script myscript.rb that you want loading...
                                    dedmin
                                    Today I noticed when I mirror a component the mirrored copy gets "Scale definition" active. When click to reset it rotates 180 degree, when choose to scale the original now gets "Scale definition"?
                                      The component instance will be scaled '-1' in the selected direction[s]. Resetting the scale should revert to the original scaling... 😕
                                        dedmin
                                        And may be this is the cause of my troubles with the components getting unique! I did a lot of models with the Mirror Selection - now I just copied instead of mirror and components don't convert to unique!
                                        • P
                                          paddyclown
                                          hello
                                          maybe i've missed something, but I tried mirror 3.5 with sketchyphysics and it won't do the mirror operation... Once the sketchyphisics has been removed no problem... I had thought I had understood that 3.5 fixed this (amongst other things)... shame as it's a great tool.
                                          (using v7 on a vista platform)...
                                          thanks anyway to TIG for all the time & trouble.
                                            This is a known bug caused by SketchyPhysics rewriting the code of some of the API's own Group class, which is used by Mirror. I'm not sure what the issue is.
                                            Perhaps if you bring pressure to bear on the SketchyPhysics side they could fix their code to stop the problem!
                                            AS SketchyPhysics loads after Mirror could you try renaming 'Mirror.rb' as 'zMirror.rb' so it loads afterwards -perhaps what SP breaks will stay OK this way and hopefully SP will still work... 😕
                                            • 11
                                            • 3 / 11
