    [Plugin] Mirror
    211 Posts 72 Posters 474.0k Views 72 Watching
    • G
      glro
      @oxer said:
      I have found the error!
      There is a conflict with SketchyPhisics 3.1, remember i work on Mac OSX.
      Excuse me, it not was a problem in the plugin there were a conflict.
      Thanks TIG¡¡
      i use windows XP SP3, and i noticed also a conflict between Mirror and Sketchyphysics3
      too bad, we'll have to choose between 2 excellent plugins...
      • cottyC
        cotty
        Thanks TIG¡¡
        Is there a solution to solve this conflict?
        my SketchUp gallery
          Here's v3.4 with some more code tweaks that might stop bugs...
          http://forums.sketchucation.com/viewtopic.php?p=276512#p276512
          • kenK
            ken
            I know this is an operator error. I have noticed if you press the delete key instead of the return, the plugin crashes. Is there a way to capture the delete key so it will not crash Sketchup.
            Yes, I know I should be more careful.
            Thank you for your plugin
            Ken
              DIEGO-RODRIGUEZ
              tig thanks for this new update.
              but unfortunately continues to generate bugplat when ouliner window this open, and make mirror for a group or component.
              use sketchup 8, windows xp sp3
                It should roll up the Outliner in Windows ? 😕
                  davidlouis
                  I have replaced an archaic version of the Mirror tool with your new one and see that the right mouse context choice is now gone and only the icon in the toolbar is there. Could you please re-intoduce the necessary lines in the code to enable it to appear in the context menu....
                  Sorry but i am a creature of habit and the use of the icon interrupts my usual workflow...
                  Thanks in advance.
                  Dave
                    @davidlouis said:
                    I have replaced an archaic version of the Mirror tool with your new one and see that the right mouse context choice is now gone and only the icon in the toolbar is there. Could you please re-introduce the necessary lines in the code to enable it to appear in the context menu....
                    Thanks in advance.
                    Dave
                    Sorry about that...
                    I disabled it temporarily whilst I was doing something else!
                    Here's v3.5 that has it reintroduced...
                    • B
                      budz
                      thanks for sharing a great plugins like this sir,..
                      • L
                        LannorMov
                        Tig: Thanks for that gift so beautiful. I'm using a lot and it works well.
                          Dominance
                          thanks for your sharing
                          • dereiD
                            derei
                            @TIG: Could you make some loader for this ? I would like to have a folder with "MI.png, Mirror.rb and toggleWindows.rb" and a Mirror_loader.rb (or similar). Win32API.so I thinks it's best to stay in Plugins folder, as it is used by more plugins.
                            Thanks a lot.
                            DESIGNER AND ARTIST DEREI.UK
                              Thanks a lot.
                              If you want to move files you need to rewrite the menu/toolbar part of their code to ensure the files are found in the new sub-folder.
                              A loader is a simply a file in the ../Plugins/ folder called perhaps myloader.rb containing this line of code
                              load "mysubfolder/myscript.rb"
                              The line can be repeated for multiple files to be loaded...
                              Where mysubfolder is a folder in ../Plugins/ containing the script myscript.rb that you want loading...
                                dedmin
                                Today I noticed when I mirror a component the mirrored copy gets "Scale definition" active. When click to reset it rotates 180 degree, when choose to scale the original now gets "Scale definition"?
                                  The component instance will be scaled '-1' in the selected direction[s]. Resetting the scale should revert to the original scaling... 😕
                                    dedmin
                                    And may be this is the cause of my troubles with the components getting unique! I did a lot of models with the Mirror Selection - now I just copied instead of mirror and components don't convert to unique!
                                    • P
                                      paddyclown
                                      hello
                                      maybe i've missed something, but I tried mirror 3.5 with sketchyphysics and it won't do the mirror operation... Once the sketchyphisics has been removed no problem... I had thought I had understood that 3.5 fixed this (amongst other things)... shame as it's a great tool.
                                      (using v7 on a vista platform)...
                                      thanks anyway to TIG for all the time & trouble.
                                        This is a known bug caused by SketchyPhysics rewriting the code of some of the API's own Group class, which is used by Mirror. I'm not sure what the issue is.
                                        Perhaps if you bring pressure to bear on the SketchyPhysics side they could fix their code to stop the problem!
                                        AS SketchyPhysics loads after Mirror could you try renaming 'Mirror.rb' as 'zMirror.rb' so it loads afterwards -perhaps what SP breaks will stay OK this way and hopefully SP will still work... 😕
                                        • P
                                          paddyclown
                                          Thanks for yr speedy reply... I tried the workaround, but alas to no avail ! I guess you're right, we have to ask the SP guys to fix there stuff ! Thanks anyway, & meantime their stuff is out & yours is in as totally indispensable (I don't understand why the gogol people haven't put in a mirror command as a basic standard tool like in any other cad program !).
                                          • X
                                            xinxin
                                            Thank you!I have downloaded it.
                                            • 11
                                            • 3 / 11
