    [Plugin] Coords Text Tag from Datum
    149 Posts 27 Posters 117.8k Views 27 Watching
    • W Offline
      watkins
      Dear TIG,
      Do you dream in Ruby? I will try out the plugin this evening.
      Many thanks,
      Bob
      • kenK Offline
        ken
        Another great plugin. Just a question, would it be possible to set and reset the "Coord Datum" just by left clicking a point after selection the menu option "Set Coord Datum".
        Thank you
        Ken
        • TIGT Online
          Thank you
          Ken
          This is v1.0 πŸ˜‰
          At the moment the Coords.Tags update every time you open the model or move one.
          [I still need to add some extra observers for opening a skp from the menu etc...]
          I could introduce a 'freeze' option where you'd remove the update observer/attribute...
          I felt that you'd set a Datum once [if even that] and then all you coordinates would be always relative to that?
          One thing I can see is that when you model in mm you might want the coords in meters ! or inches >> feet. Then 'freezing them might be useful ?
          I await user feedback to get this how 'we' all want it...
          • W Offline
            watkins
            Dear TIG,
            I tried the plugin last night, and I should like to make a few observations and comments.
            First, it either doesn't do what I should like it to do, or I'm not using the plugin properly. When I change the datum to say 5,10,10 (in mm), it adds these numbers to the x,y,z values of the points selected. So, if I hover over a cpoint at say 5,10,10 (the new datum) it reads 10,20,20, which is not what I need. The new datum point should read 0,0,0, and the origin of the World co-ordinate system (SU's default co-ordinate system) should read -5,-10,-10. The ideal would be as follows:
            • A dialog box that sets the datum either by entering the x,y,z values, or by clicking on a cpoint. The box should also have a Rest button to reset everything back to the World co-ordinate system. I think cpoints could be used for all points of interest as they make selection easier and unambiguous.
            • A dialog box that displays the x,y,z values of the point selected (point and click), with a counter to record the number of points selected, with a box to enter a three character identifier (A01, A02 etc), and a Save/Delete button to either save the data to a spreadsheet (identifier and associated co-ordinates) or to delete the point from the running total.
            Thank you for all your efforts.
            Kind regards,
            Bob
              Hi TIG,
              Excellent so far πŸ‘
              (don't listen to Bob - this is exactly what I need). πŸ˜„
              If I may also have some wishes...
              • Now there is this text tag but could you also add a guide point where it is so that I could snap geometry to it?
              • Also, it would be wonderful if (from a dialog) I could also enter points manually.
                Say I first set the coords datum to 100,100,100 then relative to this I want to enter a cpoint at 200,200,200 (that would of course just be 100,100,100 from the model origin).
              The case is (as it seems) that Bob and I are approaching the problem from different ends.
                I think what Bob would like to do is generate a table as shown on the right in this screen grab. In this drawing, 0,0 is at the upper right corner of the part. I would find that useful from time to time as well.
                http://farm5.static.flickr.com/4021/5147931667_8b6c417b76_z.jpg
                • W Offline
                  watkins
                  Dear David,
                  That is exactly what I should like my friend.
                  I suppose TIG's plugin would go half way there if I were to insert negative as well as positive numbers into the datum dialogue box. With reference to my previous example, if I had entered -5,-10,-10 instead of 5,10,10, then the point at 5,10,10 would have appeared as 0,0,0 instead of 10,20,20, and so perhaps it just a matter of using the plugin correctly. I will try out the idea tonight.
                  Another idea: If the datum dialogue box had a 'query' icon/button that one could click on and then query a point, and with the datum field automatically filled after selecting a point, then that would be really helpful. Now, how lazy can one get!!!
                  Kind regards,
                  Bob
                    Dear Bob,
                    I figured that would be your goal. So, while we're heaping work on poor TIG...
                    Suppose the plugin worked something like this:
                    Open the component for editing.
                    Select all of the geometry with a triple click of the Select tool.
                    Start the plugin.
                    The plugin identfies all of the circles and arcs in the selection and places a cpoint at center.
                    After that job completes the user clicks on the desired cpoints and the plugin places text tags. the text is A1, A2,...An. Perhaps you hit the up arrow to increment the leading letter in the tags.
                    All the while the user is clicking and placing tags, the tag and the coordinates are being collected by the plugin.
                    When the user clicks Enter or something the plugin pops up a message indicating that a CSV file has been saved to the same directory in which the SKP file has been saved.
                    As always, I can dream them up but it takes a wizard like TIG or Thomas or someone else that isn't me to figure out if and how it can be done.
                      Ben Ritter
                      TIG, another BIG thank you.
                      • TIGT Online
                        Thanks for the feedback... My new Uni lecturing commitments will delay things until say Wednesday next week - but please post any other comments / ideas in the mean while...
                        • W Offline
                          watkins
                          Dear TIG,
                          What university and waht subject?
                          Thanks for all your help.
                          Bob
                          • TIGT Online
                            @watkins said:
                            Dear TIG,
                            Bob
                            At my old Alma Mata - Newcastle upon Tyne, School of Architecture - it's the 'SketchUp and Ruby Scripting' module for ~16nr year-5/6 'masters' students [I did a little bit last year too] ... it least until the new year... then the funding will probably evaporate with the latest round of 'cut-backs'...
                            • JClementsJ Offline
                              JClements
                              Hi TIG:
                              1- Running SU8, PC, XP. My VCB doesn't display anything
                              2- I already have models to which I have used #heightool.rb (and labels).
                              Could one of the following be done?
                              Change heighttool.rb so it uses the same model tag variable (converts the old tag to the new).
                              or
                              Combines both into one ruby with the option to display the Z value only in the labels? (converts any existing heightool tag to a coordinate tag).
                              Regards, John
                              • TIGT Online
                                Here's v1.2 http://forums.sketchucation.com/viewtopic.php?p=284829#p284829
                                It totally revised and updated with many more options and settings.
                                Please read the note in the linked post...
                                • TIGT Online
                                  Here's v1.3 http://forums.sketchucation.com/viewtopic.php?p=284829#p284829
                                  An additional option to Export all of the Coords-Tags to a CSV file is added.
                                  See the notes in the linked post...
                                    Excellent, TIG. This works quite nicely. I'll bet Bob will be pleased.
                                      Thanks TIG again; this CPoint enhancement is very essential for me! πŸ‘
                                      (Now if I could also add CPoints/Coord-tags by inputting into a box the XYZ values...) πŸ˜’
                                      • TIGT Online
                                        OK, OK...
                                        What format would the input be would you want it to reflect your current Coords-Tag Settings ?
                                        • W Offline
                                          watkins
                                          Dear TIG,
                                          I have just noticed this post. Many thanks for all you efforts, and the continuing development of this plugin.
                                          I will look at it more detail when I get home.
                                          Kind regards,
                                          Bob
                                            Well, when I have already set the co-ordinates (say for example) X=1000, Y=1000, Z=1000, I then wish to place guide points (maybe with an option to receive a tag - or a tag with the option to add a CPoint)) to say (again, with the above example) at 2000/2000/2000 which in this case would of course be only at 1000/1000/1000 relative to the model origin.
                                            To make the example clear; when we have the chance to dig "cleanly", we generally work in a 10m x 10m (or 5mx5m or whatever) grid system (where we keep section walls between these rectangular pits). This grid system is set up according to our national orthographic grid system so whenever I find a Roman coin (again, for instance), we take the exact location with those surveying tools.
                                            Now when I set up an excavation with a grid plugin (there are lots of fine ones) and I want to quickly display the (already) known location of this coin, I could then have an input box to enter the xyz co-ordinates (maybe a yes/no for an additional CPoint) rather than trying to guess where it is.
                                            In other words; what the plugin already does just vice-versa.
                                            And of course, I am already very grateful and would not "urge" you in any way...
                                            πŸ˜‰
                                            • 1 / 8
