    [Plugin] Coords Text Tag from Datum
    149 Posts 27 Posters 124.9k Views 27 Watching
    • B
      Ben Ritter
      TIG, another BIG thank you.
        Thanks for the feedback... My new Uni lecturing commitments will delay things until say Wednesday next week - but please post any other comments / ideas in the mean while...
        • W
          watkins
          Dear TIG,
          What university and waht subject?
          Thanks for all your help.
          Bob
            @watkins said:
            Dear TIG,
            Bob
            At my old Alma Mata - Newcastle upon Tyne, School of Architecture - it's the 'SketchUp and Ruby Scripting' module for ~16nr year-5/6 'masters' students [I did a little bit last year too] ... it least until the new year... then the funding will probably evaporate with the latest round of 'cut-backs'...
            • JClementsJ
              JClements
              Hi TIG:
              1- Running SU8, PC, XP. My VCB doesn't display anything
              2- I already have models to which I have used #heightool.rb (and labels).
              Could one of the following be done?
              Change heighttool.rb so it uses the same model tag variable (converts the old tag to the new).
              or
              Combines both into one ruby with the option to display the Z value only in the labels? (converts any existing heightool tag to a coordinate tag).
              Regards, John
                Here's v1.2 http://forums.sketchucation.com/viewtopic.php?p=284829#p284829
                It totally revised and updated with many more options and settings.
                Please read the note in the linked post...
                  Here's v1.3 http://forums.sketchucation.com/viewtopic.php?p=284829#p284829
                  An additional option to Export all of the Coords-Tags to a CSV file is added.
                  See the notes in the linked post...
                    Excellent, TIG. This works quite nicely. I'll bet Bob will be pleased.
                    • GaieusG
                      Thanks TIG again; this CPoint enhancement is very essential for me! πŸ‘
                      (Now if I could also add CPoints/Coord-tags by inputting into a box the XYZ values...) πŸ˜’
                        OK, OK...
                        What format would the input be would you want it to reflect your current Coords-Tag Settings ?
                        • W
                          watkins
                          Dear TIG,
                          I have just noticed this post. Many thanks for all you efforts, and the continuing development of this plugin.
                          I will look at it more detail when I get home.
                          Kind regards,
                          Bob
                          • GaieusG
                            Well, when I have already set the co-ordinates (say for example) X=1000, Y=1000, Z=1000, I then wish to place guide points (maybe with an option to receive a tag - or a tag with the option to add a CPoint)) to say (again, with the above example) at 2000/2000/2000 which in this case would of course be only at 1000/1000/1000 relative to the model origin.
                            To make the example clear; when we have the chance to dig "cleanly", we generally work in a 10m x 10m (or 5mx5m or whatever) grid system (where we keep section walls between these rectangular pits). This grid system is set up according to our national orthographic grid system so whenever I find a Roman coin (again, for instance), we take the exact location with those surveying tools.
                            Now when I set up an excavation with a grid plugin (there are lots of fine ones) and I want to quickly display the (already) known location of this coin, I could then have an input box to enter the xyz co-ordinates (maybe a yes/no for an additional CPoint) rather than trying to guess where it is.
                            In other words; what the plugin already does just vice-versa.
                            And of course, I am already very grateful and would not "urge" you in any way...
                            πŸ˜‰
                              Here's v1.4 http://forums.sketchucation.com/viewtopic.php?p=284829#p284829
                              It fixes a glitch with incorrect reading of the Datum.
                              It also adds two new tools:
                              Import Coords-Tag from CSV [optional units and optional cpoint]
                              Add Coords-Tag by Dialog [input XYZ and optional cpoint, using current units' settings]
                              Please read the notes on the download page as linked...
                              • GaieusG
                                Hi TIG and many thanks again but what I would need is not exactly this.
                                First of all, the add coord tag by input seems to add the tags in inches (2.54x farther than needed).
                                The other thing is that these points are now added relative to the current origin (that would also be cool in fact but then I could simply use 0/0/0 as my origin). What I would need is to add the coords according to the modified origin co-ordinates. So if I am 800 kilometres away from our national origin (that is somewhere in Slovenia, Austria or Italy AFAIK πŸ˜’ ), and add a coord at 800.000.125 - or 800,000,125 on my Hungarian keyboard system (i.e. only 125 centimetres from my model origin), it would be just 125 cms from my origin.
                                • GaieusG
                                  Wait a minute, something else is also wrong here. My model origin is not at 100/100/100 but all negative; -100/-100/-100!
                                  I tried again and indeed it sets it to negative! πŸ˜’
                                  • GaieusG
                                    Some correction/modification...
                                    It only works in inches if I set the coords in model-units. Although I have centimetres in my template, it doesn't seem to recognise it.
                                    Then if I set the units to centimetres, it will correctly add the coords - except it swaps my origin from + to - (see screenshot) and does not add the coord tag where I wish (so what is written above is still valid).
                                      I'm sure this is 'fixable'... πŸ˜’
                                      Let's say you set your Coords-Tag Datum of X=100m, Y=100m, Z=0m.
                                      This then interprets the SKP origin SKP[0,0,0] as CT[100m,100m,0m] which is the text shown in the Coords-Tag that is placed at the SKP[0,0,0] ?
                                      If you add a Coords-Tag manually at SKP[1m,1m,1m] its displays CT[101m,101m,1m] in the Tag.
                                      If you want to Add a Coords-Tag via the dialog at say CT[102m,101m,1m] you enter those values three, and it then places a new Coords-Tag in the model at SKP[2m,1m,1m] - because its SKP[X,Y,Z] = CT[typedX - datumX, typedY - datummY, typedZ - datumZ].
                                      I fear I might have got my +datum/-datum calculations in a twist - I'll revisit the code and issue an update... πŸ˜’ πŸ€“
                                      • GaieusG
                                        Hm. Very interesting. If I set the origin to -100/-100/-100, the plugin puts the origin in correctly at 100/100/100 and works as intended (i.e. a point at 200/200/200 is at 100/100/100 from the model origin). So maybe yes, you twisted something...
                                        πŸ˜„
                                        Yet the centimetres need to be set otherwise it works in inches.
                                          Here's v1.5 http://forums.sketchucation.com/viewtopic.php?p=284829#p284829
                                          The balls up in the datum v. tag's values is now fixed πŸ˜’
                                          The Coords-Tag values correctly show the value relative to the set Datum - irrespective of the method used to input them - i.e. manual-pick/add-by-dialog/imported-CSV...
                                          Gaieus - the XY/Z units should be either the SKP's current-units or the XY/Z units you choose [or XY Lat/Long?] - please try and report back...
                                          • GaieusG
                                            Yes, this is it, thanks! πŸ‘
                                            Two more things: when I do not set the units (just leave it on "model units"), it still calculates in inches. I can live with this of course as that's just two clicks and I do not produce hundreds of models like this. So if you have anything better to do, leave it (although users may get confused if this is not working so for the time being, if it is too much to fix, I'd suggest simply deleting that option and force the user to select something).
                                            The other is just cosmetics; the tags are displayed in the "English" way; 100.00 while our decimal separator is the comma: 100,00 (and the dialog actually displays it that way - I guess automatically). But if it is more than a line in the code to adjust (if possible at all), please, disregard it as I really do not care too much.
                                            And did I say thanks?
                                            β˜€
                                            • 2 / 8
