    What SketchUp could/should have been like...
    extensions
    42 Posts 21 Posters 8.4k Views 21 Watching
    • jason_marantoJ
      jason_maranto
      Sketchup was created to look like a vector illustration (eg Adobe Illustrator)-- this is not even remotely near "Realism"... any realistic effects you can achieve in Sketchup are diversions. It is designed to be graphic in its visual effect on purpose.
      To say this is what Sketchup should have been is to ignore the very specific intentions of the creators. Sketchup will never be this and if this is what you want then you are able to use this product to get it.
      For my industry there is a great deal of value in the graphic vector style of Sketchup and it would not be nearly as useful to us if it were "realistic".
      Best,
      Jason.
      • F
        frv
        tx Pixero,
        I am sure all 3D modeling applications will work like this sooner or later. SU probably later or maybe too late. I just had a discussion on the Vectorworks board were I wondered if it was possible to model in a semi rendered mode or/and perspective view. It turned out it was not possible to do that really well.
        Many there answered that orthogonal modeling in wireframe was the ultimate way to work. That also seemes to be the programmers idea of Vectorworks. To me it just shows how old generations of software somtimes fade away rather quick.
        Francois
        • PixeroP
          Pixero
          New movie.
          The WHOLE video rendered in 12 minutes 27 seconds! 😲
          [flash=640,390:2vur6s6y]http://www.youtube.com/v/HoYervlEdsM?fs=1&amp&hl=en_US[/flash:2vur6s6y]
          • PixeroP
            Pixero
            Twinmotion 2 is now live.
            I've played a little with the demo and am a bit disappointed.
            Rather slow performance. I have a Nvidia 9800GT so that might be in the lower range for the application.
            Very cool to build something and see it lightened realtime.
            Quality so, so...
            No control over camera/player speed and smoothness.
            My main issue is the prize v.s. the quality/performance.
            € 1920 = $ 2662 is to high in my opinion.
            • soloS
              You have to explode everything in SU before exporting, then triangulate every face... yikes!!!
              That's gonna be some very heavy models.
                That is not a very nice workflow. Exploding a large model kills SU.
                • PixeroP
                  Pixero
                  Plus in one tutorial video I can clearly see SketchUp as a import option but he chooses fbx.
                  I read something about problems with SU import so thats not working at the moment.
                  • AdamBA
                    AdamB
                    My big problem with this kind of approach is that it cannot support anything but trivial light sources. ie PointLights (omni) and Direction (sun) lights. eg You cannot support Area lights with this tech.
                    Adam
                    • B
                      binouze23
                      Hi Sketchucationers,
                      I test it yesterday on an iMac running Xp with bootcamp (don't have all the specs here)
                      Exporting from Skp to Fbx > OK (and I didn't explode anything before)
                      Importing Fbx in Twinmotion > OK
                      Collapsing the group by material in TwinMotion > OK
                      BUT I don't get anything in the preview window.
                      I mean I can see my imported model with all the groups in the file tree on the left but the main window remain all black !!!
                      I will post this problem on their support forum as soon as they accept my account but I post it here in case someone else here got the same issue.
                      Nico
                      PS: the original sketchup file was around 30Mb (just to give you an idea)
                        MrWip
                        @adamb said:
                        My big problem with this kind of approach is that it cannot support anything but trivial light sources. ie Point Lights (omni) and Direction (sun) lights. eg You cannot support Area lights with this tech.
                        Adam, sorry but your assertion is false, there's area lights in TM2, and it works well (you also have spots and omni). The difference with, for example, light up, which bakes the lighting, is the fact that you cannot set a random surface of your model as an emitter (by applying it to a material)...it reduce a bit the range of possibilities, but still, it's quite efficient.
                        The importer works by splitting the object by material (just like Su2Thea actually), so you don't have to do anything by hand (exploding everything, and so on). I've beta tested the early versions, and it was rather slow with a full sketchup hierarchy loaded in real time. But, by using this method (which is automatic with the import preset "sketchup"), it's much more efficient.
                        http://www.wip-archi.com
                        • AdamBA
                          AdamB
                          I'll take a look at the App. I think you may be mistaken wrt Area light support because of the way their engine works.
                            MrWip
                            Adam, I've been in touch with the developers during the building of the software, and ask them the same question than yours, because usually, deferred rendering engine ( cryengine and such) never include planar lights, and are always limited to point elements. But actually, in twinmotion, they've fine a way to do so. I don't know how technically, or what trick they're using, but in the end, you're able to get a planar ceiling lamp for exemple (that you can't achieve with an omni or a spot).Isn't that what your looking for ?
                            • AdamBA
                              AdamB
                              OK, I've had a play with it. Its precisely what I knew it would be - had to be even.
                              Doesn't do area lights.
                              The way these engines work is creating a view of the world from the light position to create a "shadowmap" that can then be used in your shader to determine how much direct light falls on a surface.
                              For a small number of shadow casting lights this works great. For a real area light or hundreds of lights, its a none-starter.
                              (Mr Wip, the Area light effect is done by tweaking the shadowmap projection transform to create a orthographic projection, but ultimately its still a shadowmap. Its not really an area light the way most people think about the lighting effect of an area light.)
                              Summing up: Definitely an Interesting Application. The best advice I'd give is for people to try it out on your own models, if what it does is what you need, you've got yourself a winner. 😄
                              Adam
                                MrWip
                                ok, it's clearer now, thanks for the explanation Adam.
                                • jim smithJ
                                  jim smith
                                  [quote="Pixero"]Another teaser for "the rendering killer".
                                  I just saw the release announcement in the Daily CatchUp. looks like the rendering killer is also a budget killer at USD$2,990.00 😲
                                  Seems to be great fun, but I think I will stick to Chucks' new plugins for now. 👍 😄
                                  "Out of clutter find simplicity,
                                  from discord find harmony,
                                  In the middle of difficulty lies opportunity"
                                  Albert Einstein
                                  • C
                                    cadmunkey
                                    Link?
                                    • jim smithJ
                                      jim smith
                                      @cadmunkey said:
                                      Link?
                                      cadmunkey - sorry for the mixed metaphor - The "killer" announcement came out about the same time Chuck Vali announced his plugins. http://www.valiarchitects.com/
                                      I intended my comment to make a comparison of my sticker shock for the $2,900 renderer versus the very reasonable ($15 to $39 each for pro, free basic) and usefull Instant roof-road and grader plug-ins.
                                      Since then, there was the announced release of "Luminon" which seems to be a very cool, feature laden and similar rendering program at about 1/3 the cost of the "killer".
                                      Albert Einstein
                                      • PixeroP
                                        Pixero
                                        I tried the demo again and its really too slow to be usable. I might not have the newest top of the line grahipcs card but for an empty scene with a plane and a sphere I think you could ask for better framrate than it gives. 😲
                                        Now lets wait and see what Lumion is like...
                                        • C
                                          cadmunkey
                                          Thanks for the link Jim, the road from faces plugin I will definately get.
                                          • 2 / 3
