    Follow Me question
    12 Posts 6 Posters 1.2k Views 6 Watching
    • hellnbakH
      hellnbak
      Ok, I'm using follow me on an object, but I need to use it like 30 times, and I have to select the same 7 edges each time. Is there any way around this, maybe a way to keep the edges selected while I'm using the follow me tool? My poor old fingers are cramping up πŸ˜„
      • BoxB
        It sounds like you should be using a Component, then you only have to do it once.
        Posting an example of what you are doing would help answer your question.
        • hellnbakH
          hellnbak
          Here's an example. I had to select the same 7 edges each time I used the follow me tool.
          • BoxB
            If they are all identical, create one, make it a component then make 30 copies.
            Select the component, use the move tool and Ctrl and move one copy, then type in 29X enter and you will have 30 copies spaced the same way.
              d12dozr
              In addition to what Ben said, you could also just select the face that is made from those 7 edges, then "follow-me" πŸ˜‰
              http://goo.gl/f7ooYh
              • GaieusG
                What Marcus says. And do you remember my example file? There I also "instructed" to (just) click on that face.
                See also SelectionMemory plugin (free):
                http://www.smustard.com/script/SelectionMemory
                or the commercial version:
                http://www.smustard.com/script/SelectionMemory2
                  d12dozr
                  ...and you can weld a set of edges together so 1 click selects them all, note that this may create unwanted smoothing but that is easily fixed with the Soften Edges dialog box when finished.
                  File Not Found
                  (www.smustard.com)
                    Seems Profil Builder at Smustard make the followme multiple πŸ˜‰
                    (not tested because I have not πŸ˜„
                      Before to know if the profil Builder makes the trick
                      You can select your 7 segments in a one selection rectangular πŸ˜‰
                      So just one mouse's move for selection
                      one move for select the Followme Tool
                      and one click on the face β˜€
                        another funny one πŸ˜‰
                        Copy Move the profil as group to each triangles
                        (easy as your triangles are equally positioned so a "copy move multiple")
                        Call the Outliner
                        Select a group in the Outliner
                        Right click explode
                        Follow me tool
                        select triangle's face
                        Click
                        etc... β˜€
                        PS I have also old fingers πŸ˜’
                          Instead of working from the outside in think laterally - work from the inside out...Capture.PNG
                            Tig wins! 😎
                            I have forgotten the power of "think lateral" β˜€
                            Have you try "Profil Builder" ? I don't know yet if "Profils multiple" is possible?
