    [Plugin] SmartDrop Beta
    43 Posts 27 Posters 73.6k Views 27 Watching
      Works cool with the Chris Fullmer "Select Lines by Length" + "Components onto faces" ! โ˜€
      • majidM
        majid
        thanx for handy script. i tested old version and 1.4 version. old one workes fine , but recent one just unhides the component!!!! and nothing!
        what is wrong whit me? or something about the script?
        • C
          caddict
          very nice!! Thanks!!
          • X
            xrok1
            bump ๐Ÿ’š
            โ€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.โ€
            • bagateloB
              bagatelo
              I think about this:
              404 Not Found
              (forums.sketchucation.com)
              • C
                ckho1985
                i try to run it with Skup 8, however without success. anyone tried?
                • shuraS
                  shura
                  Hi ckho1985, maybe Chris Fullmers Components onto Faces works in SU8. It gives similar results.
                  xxx
                  • C
                    ckho1985
                    I tried, but i found it is really difficult to use... or am I doing something wrong? i selected a grouped object and the face I want to drop on, however its not doing it.
                    I miss smartdrop, just one click then it sits.
                    • shuraS
                      shura
                      Like the name says, it has to be components, not groups. ๐Ÿ˜‰
                      • Chris FullmerC
                        I just tried smart drop with SU 8, and it worked like a charm. What exactly about it is not working?
                        • C
                          ckho1985
                          that's very strange. I assume there would be just one file (smartdrop.rb) to copy right? However, on my SU8, the smartdrop function is not showing at all. any idea why?
                          • Chris FullmerC
                            You mean there is no command visible? You really need to specify what the problem is. For example, you try to run it, and SU crashes. You try to run it, and your entire model disappears. You try to run it and nothing seems to happen. You install it and SU no longer opens. You install it, but can not find how to start the plugin. Please help us understand what the problem is.
                            If you just can't figure out where to start it, it is in the right click menu when you have components selected.
                            Good luck,
                            • C
                              ckho1985
                              Sorry Chris as i didnt clarify the matter. What I have done was copied the rb file into the plugin file. However, when I loadup SU. I could not find the smartdrop function, not in the plugin list, nor right click, nor help. I though there was an icon for the smartdrop tool, back in su7 (maybe I am wrong), and it wasnt there. btw, everything else was find, no crash no nothing.
                              um... I think I should repair my su8 and re-download the rb file.
                                [flash=800,600:1qce6im4]http://www.youtube.com/v/qBmPEEOAIEY[/flash:1qce6im4]
                                • N
                                  Niffler
                                  @solo said:
                                  I agree.
                                  I never knew it existed, and what a great script it is.
                                  Hey Solo,
                                  You said you are for hire, is that right? I've been to your website and...how do you hire a god?!
                                  Niffler ๐Ÿ˜‰
                                  • brookefoxB
                                    brookefox
                                    For me there are some issues.... job does not complete, perhaps owing to component bumping?
                                    Merci, Pilou for your nice image tut, posted earlier. โ˜€
                                    ~ Brooke
                                    • brookefoxB
                                      brookefox
                                      Yes, component bumping appears to have been the problem.
                                      ~ Brooke
                                        Use the cool Thomthom RayTracer! ๐Ÿ‘
                                        Object must be in a box with an horizontal base : Drop by Bounds
                                        So will work with your example!
                                        careful than an inclined object yet droped don't block next following ๐Ÿ˜‰
                                        by Thomthom
                                        http://forums.sketchucation.com/download/file.php?id=53900&t=1
                                          mlefevre
                                          I'm trying to drop a solar array onto a surface using this plugin and having some issues. The panels are touching end to end, and when I drop them to the surface, either individually or all together, some of the components will turn up on end and others will lay plat on the surface. Any thoughts?
                                          I'm using SU 8 Pro.
                                            Mra
                                            Thanks for the plugin. But it changes the angle of objects?
                                            So if I have a pole, I drop it to the surface but this plugin in makes it no longer vertical. Is there an option to change this?
                                            • 1 / 3
