    [Plugin] SmartDrop Beta
    43 Posts 27 Posters 73.6k Views 27 Watching
    • FletchF
      Fletch
      Note it changes the definition of group to add a .definition method.
      This makes group more similar to componentInstance.
      from your google group link... I find this fascinating as it's one the many little annoying things about SU that would have been fixed if they hadn't been bought by google... makes no sense why the axes work the way they do in SU6... either they should work like SU5, or allow you to adjust the axes w/out making them a component. obviously could be done. ๐Ÿ˜’
      a tool simply in the SU shell called 'reset axes' that only appeared for Groups would be very nice... since you can't do that in SU now.
      Fletch
      • X
        xrok1
        this one definately deserves a bump ๐Ÿ˜„
        โ€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.โ€
        • soloS
          I agree.
          I never knew it existed, and what a great script it is.
          • X
            xrok1
            i noticed that ver.1.4 also lets you undo with one action. in ver.1 you had to undo each drop and each rotation.
            • N
              NewOne
              Wow !! that's cool!
              You did it ๐Ÿ˜„ It was a discution about this http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=14543&p=110383&hilit=+fish#p110359 but I never thought somebody will go on.
              I see that the script drops only if object have a face on bottom. I tried to drop vertical planes or lines and did not worked.
              • X
                xrok1
                @newone said:
                Wow !! that's cool!
                the original drop.rb will drop lines to intersection but they won't be rotated. ๐Ÿ˜‰
                  Works cool with the Chris Fullmer "Select Lines by Length" + "Components onto faces" ! โ˜€
                  • majidM
                    majid
                    thanx for handy script. i tested old version and 1.4 version. old one workes fine , but recent one just unhides the component!!!! and nothing!
                    what is wrong whit me? or something about the script?
                    • C
                      caddict
                      very nice!! Thanks!!
                      • X
                        xrok1
                        bump ๐Ÿ’š
                        • bagateloB
                          bagatelo
                          I think about this:
                          404 Not Found
                          (forums.sketchucation.com)
                          • C
                            ckho1985
                            i try to run it with Skup 8, however without success. anyone tried?
                            • shuraS
                              shura
                              Hi ckho1985, maybe Chris Fullmers Components onto Faces works in SU8. It gives similar results.
                              xxx
                              • C
                                ckho1985
                                I tried, but i found it is really difficult to use... or am I doing something wrong? i selected a grouped object and the face I want to drop on, however its not doing it.
                                I miss smartdrop, just one click then it sits.
                                • shuraS
                                  shura
                                  Like the name says, it has to be components, not groups. ๐Ÿ˜‰
                                  • Chris FullmerC
                                    I just tried smart drop with SU 8, and it worked like a charm. What exactly about it is not working?
                                    • C
                                      ckho1985
                                      that's very strange. I assume there would be just one file (smartdrop.rb) to copy right? However, on my SU8, the smartdrop function is not showing at all. any idea why?
                                      • Chris FullmerC
                                        You mean there is no command visible? You really need to specify what the problem is. For example, you try to run it, and SU crashes. You try to run it, and your entire model disappears. You try to run it and nothing seems to happen. You install it and SU no longer opens. You install it, but can not find how to start the plugin. Please help us understand what the problem is.
                                        If you just can't figure out where to start it, it is in the right click menu when you have components selected.
                                        Good luck,
                                        • C
                                          ckho1985
                                          Sorry Chris as i didnt clarify the matter. What I have done was copied the rb file into the plugin file. However, when I loadup SU. I could not find the smartdrop function, not in the plugin list, nor right click, nor help. I though there was an icon for the smartdrop tool, back in su7 (maybe I am wrong), and it wasnt there. btw, everything else was find, no crash no nothing.
                                          um... I think I should repair my su8 and re-download the rb file.
                                            [flash=800,600:1qce6im4]http://www.youtube.com/v/qBmPEEOAIEY[/flash:1qce6im4]
                                            • 1 / 3
