    Best way to get all Face's in model?
    25 Posts 5 Posters 3.7k Views 5 Watching
      draftomatic
      Thanks thomthom!
      • E
        exvion
        thomthom, I run your code on Sketchup 7.1:
        (eval);508; compile error
        (eval);505; syntax error, unexpected tIDENTIFIER, expecting ')'
        model.definitions.each { |d|
        (eval);508; syntax error, unexpected '}', expecting ')'<<< Process finished.
          Ther was a typo [a missing ')'...]
              model = Sketchup.active_model
              faces = []
              faces.concat( model.entities.select{|e| e.is_a?( Sketchup;;Face ) }
                next if d.image?
                faces.concat( d.entities.select{|e| e.is_a?( Sketchup;;Face ) } )
          • E
            exvion
            This code work:
                faces = []
                faces.concat( model.entities.select{|e| e.is_a?( Sketchup;;Face ) }    )
                  next if d.image?
              draftomatic
              @exvion said:
              This code work:
              >     faces = []
              >       next if d.image?
              It doesn't seem to be working for me. I put it as a method called get_face_array() inside a class called Tester:
              This is a 68.2MB model.
                faces = [] faces.concat( model.entities.select{|e| e.is_a?( Sketchup::Face ) } )
                Could be simplified to:
                faces = model.entities.select{|e| e.is_a?( Sketchup::Face ) }
                  It doesn't return the correct number because the code doesn't take into account instances.
                  <span class="syntaxdefault">def number_of_faces<br />  model </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model<br />  faces </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">entities</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">select</span><span class="syntaxkeyword">{|</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">|</span><span class="syntaxdefault"> e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">is_a</span><span class="syntaxkeyword">?(</span><span class="syntaxdefault"> Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Face </span><span class="syntaxkeyword">)</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">}.</span><span class="syntaxdefault">length<br />  model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">definitions</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">each </span><span class="syntaxkeyword">{</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">|</span><span class="syntaxdefault">d</span><span class="syntaxkeyword">|<br /></span><span class="syntaxdefault">    next if d</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">image</span><span class="syntaxkeyword">?<br /></span><span class="syntaxdefault">    next if d</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">count_instances </span><span class="syntaxkeyword">==</span><span class="syntaxdefault"> 0<br />    faces </span><span class="syntaxkeyword">+=</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> d</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">entities</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">select</span><span class="syntaxkeyword">{|</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">|</span><span class="syntaxdefault"> e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">is_a</span><span class="syntaxkeyword">?(</span><span class="syntaxdefault"> Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Face </span><span class="syntaxkeyword">)</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">}.</span><span class="syntaxdefault">length </span><span class="syntaxkeyword">*</span><span class="syntaxdefault"> d</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">count_instances </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">  </span><span class="syntaxkeyword">}<br /></span><span class="syntaxdefault">end</span>
                    Or - even easier if you can settle with SU7.1 or higher:
                    model.number_faces
                      Oh, wait - you actually need arrays of all the face entities?
                        draftomatic
                        Well, I really just needed to iterate through all the Faces in the model... the array thing is just useful for testing.
                        Bah, I should've realized the instances issue... So your code in the 2nd post isn't quite right 😃
                          It depends what you do with it...
                          If you need to count the faces you need to take into account all instances.
                          But if you need to just iterate over all faces you only need to process model.entities and the entities of each definition, even if a definition has multiple instances, a face in that definition is the same in each instance. It just exist in multiple locations.
                            draftomatic
                            As you saw a few minutes ago, I'm writing an exporter, and it doesn't keep Component information. I need every Face.
                              draftomatic
                              Closer, but still not working:
                              Here's the get_face_count() method I'm using:
                                def get_face_count()
                                  count = 0
                                  @model.entities.each { |e|
                                    if (e.is_a?(Sketchup;;Face))
                                      count +=1
                                  @model.definitions.each { |d|
                                    next if d.image?
                                    next if d.count_instances == 0
                                    count += d.entities.select { |e|
                                    }.length * d.count_instances
                                  return count
                                hm... instances inside other instance might throw the count of...
                                I think you need to traverse the model in a tree like structure
                                <span class="syntaxdefault"><br />def&nbsp;process_model<br />&nbsp;&nbsp;walk_faces</span><span class="syntaxkeyword">(&nbsp;</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model&nbsp;</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">end<br /><br />def&nbsp;walk_faces</span><span class="syntaxkeyword">(&nbsp;</span><span class="syntaxdefault">entities</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">transformation&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">Geom</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Transformation</span><span class="syntaxkeyword">.new&nbsp;)<br />&nbsp;&nbsp;</span><span class="syntaxdefault">faces&nbsp;</span><span class="syntaxkeyword">=&nbsp;[]<br />&nbsp;&nbsp;for&nbsp;</span><span class="syntaxdefault">e&nbsp;in&nbsp;entities<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">if&nbsp;</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">is_a</span><span class="syntaxkeyword">?(&nbsp;</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Face&nbsp;</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">faces&nbsp;</span><span class="syntaxkeyword"><<&nbsp;</span><span class="syntaxdefault">e<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">elseif&nbsp;</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">is_a</span><span class="syntaxkeyword">?(&nbsp;</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Group&nbsp;</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">faces</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">concat</span><span class="syntaxkeyword">(&nbsp;</span><span class="syntaxdefault">walk_faces</span><span class="syntaxkeyword">(&nbsp;</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">entities</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">transformation&nbsp;</span><span class="syntaxkeyword">*&nbsp;</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">transformation&nbsp;</span><span class="syntaxkeyword">)&nbsp;)<br />&nbsp;&nbsp;&nbsp;&nbsp;elseif&nbsp;</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">is_a</span><span class="syntaxkeyword">?(&nbsp;</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">ComponentInstance&nbsp;</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">faces</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">concat</span><span class="syntaxkeyword">(&nbsp;</span><span class="syntaxdefault">walk_faces</span><span class="syntaxkeyword">(&nbsp;</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">definition</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">entities</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">transformation&nbsp;</span><span class="syntaxkeyword">*&nbsp;</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">transformation&nbsp;</span><span class="syntaxkeyword">)&nbsp;)<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">end<br />&nbsp;&nbsp;end<br />&nbsp;&nbsp;faces<br />end<br /></span>
                                (Untested - but something like this)
                                  draftomatic
                                  Your code had a few lil typos; this one works:
                                    def process_model()
                                      return walk_faces( Sketchup.active_model.entities )
                                    def walk_faces( entities, transformation = Geom;;Transformation.new )
                                      faces = []
                                      entities.each { |e|
                                        if e.is_a?( Sketchup;;Face )
                                          faces << e
                                        elsif e.is_a?( Sketchup;;Group )
                                          faces.concat( walk_faces( e.entities, transformation * e.transformation ) )
                                        elsif e.is_a?( Sketchup;;ComponentInstance )
                                          faces.concat( walk_faces( e.definition.entities, transformation * e.transformation ) )
                                      return faces
                                  Thanks Tom, you're the best!
                                    There we go - got there in the end! 😄
                                      draftomatic
                                      One more question - I see you're messing with a transformation - if I ask a nested instance for, say, it's Face's vertices locations (assuming it's just a rectangle or something simple), will it give me the (globally) correct coordinates, or something relative to the Component's origin?
                                      I guess ComponentDefinitions have entities, so I can ask for their locations. But ComponentInstances are transformed somewhere... I don't have much experience with transformations...
                                      EDIT: Ah nevermind, I see now that you're carrying the transformation through each nesting of an instance. Gotcha.
                                      Thanks again Tom
                                        Had a feeling the transformation would be needed.
                                          soldatino
                                          I had the same problem, but I need to get the "material" of each face.
                                          So I had a lot of problems because the "material" is hereditary if there is (or not) in the groups of faces (or nested groups). So it is really difficult to get the tree of the materials of all the faces.
                                          So I wrote this inelegant recursive sub, and it works fine for me.
                                          def pov_ex()
                                             model=Sketchup.active_model
                                             entities=model.entities
                                             entities.each do |entity|
                                                  if entity.typename=="ComponentInstance"
                                                      entity.explode
                                                      pov_ex()
                                                  elsif entity.typename=="Group"
                                                      entity.explode
                                                      pov_ex()
                                          at the end, after material's extraction, I wrote a "model.abort_operation" so all the entities return to original state and are not corrupted by explode.
                                          But a question... this code works really slow, I'd like to find a better way....
                                          r3nDer tools
                                            There are two reasons your code is slow:
                                            1. You're comparing strings a lot. Don't use .typename to check for entity type. It's very slow. ( See more performance tips here: http://forums.sketchucation.com/viewtopic.php?f=180&t=25305#p217180 )
                                              Instead, test for its class: e.is_a?( Sketchup::Group )
                                            2. Exploding is very slow in SU. ( and if your script should fail at some point and halt - you're left with a broken model. )
                                            I have a plugin that transfer the group/component materials onto the faces with default materials - here's an extract from that plugin:
                                            <span class="syntaxdefault"><br />  def self</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">instance_materials_to_faces<br />    model </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model<br />    model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">start_operation</span><span class="syntaxkeyword">(</span><span class="syntaxstring">'Instance Material to Faces'</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> true</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">    self</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">instance_material_to_faces</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">selection</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> nil </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">    model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">commit_operation<br />  end<br />  <br />  def self</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">instance_material_to_faces</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> entities</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> material </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">    for e in entities<br />      if TT</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Instance</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">is</span><span class="syntaxkeyword">?(</span><span class="syntaxdefault"> e </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">        temp_material </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">(</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">material</span><span class="syntaxkeyword">)</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">?</span><span class="syntaxdefault"> e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">material </span><span class="syntaxkeyword">;</span><span class="syntaxdefault"> material<br />        d </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> TT</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Instance</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">definition</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> e </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">        self</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">instance_material_to_faces</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> d</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">entities</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> temp_material </span><span class="syntaxkeyword">)</span><span class="syntaxdefault"> </span><span class="syntaxcomment"># Recursive call<br /></span><span class="syntaxdefault">        e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">material </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> nil<br />      elsif e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">is_a</span><span class="syntaxkeyword">?(</span><span class="syntaxdefault"> Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Face </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">        e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">material </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> material if e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">material</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">nil</span><span class="syntaxkeyword">?<br /></span><span class="syntaxdefault">        e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">back_material </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> material if e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">back_material</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">nil</span><span class="syntaxkeyword">?<br /></span><span class="syntaxdefault">      end<br />    end<br />  end<br /></span>
                                            Note that I have to custom methods here, not explained:
                                            TT::Instance.is?( e ) returns true if the entity is a Group or ComponentInstance
                                            TT::Instance.definition( e ) return the definition of a Group or ComponentInstance
